Question about Sony Cyber-Shot DSC-W5 Digital Camera
Sony w5 battery chamber removal?
Can you please tell me how to remove the battery camber so I can replace it. Thanks Paul
Push in and hold the little grey button on the bottom of the right hand side of the camera, then push hard (slide) to the outside -- slide the bottom peice off to the right. The bottom 1/3 should pop open.
Posted on Feb 20, 2009
How to reset sony dsc-w5?
  • To reset turn off the camera and remove the battery. Hold down the power button for 15 seconds then release. Reinsert the battery pack and power on the camera.
Feb 25, 2015 | Sony Cyber-Shot DSC-W5 Digital Camera
How do i delete all the pictures from a Sony Cyber-shot DSC-W5 at one time, it's laborious to do them individually
To delete all files in one click, please format memory card as this will delete all data at once.
Format option is available in camera Menu.
Thanks.
Mar 09, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
My Sony Cybershot DSC W5 turns off when I turn it to camera/picture mode. What should I do?
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, it may be time for new batteries, or the camera may have a problem that requires professional repair.
Dec 27, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Sony DSC-W5 camera and the LCD screen is blank (white)
Remove the Battery pack from the Camera then press and hold the power button for 30 seconds.
Next, reinsert the Battery pack in the Camera and try to turn it ON. Make sure that the Battery pack is fully charged. If the LCD remains white then the LCD screen needs to be serviced or replaced.
Nov 25, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
My flash doesn't work? how do i turn it on?
Have you tried resetting your camera? Powerdown and take batteries out. Then hold "power" button for 30 seconds, release and repeat couple of times.
Jul 08, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
USB Device Not Recognized
try downloading the drivers from sony first http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C116935&fes=true&mdl=DSCW5 that is if you have already downloaded the proper usb drivers for your system in which case other usb device are still working also it is possible that the usb port itself has gone bad or is in conflict with another driver assuming your using windows to check this you can start by telling me which version of windows you are using but more than likely the proper camera drivers will solve the issue
Apr 26, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
My lens is not going in or coming out in sony w5
    The lens block assymbaly being malfunctioning, Therefore you have to replace the complete lense block assy.
Thanks for using fixya.
Jan 27, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Chambers parts
need a part for a cambers electric cooktop model # AT-33-A
Jun 13, 2008 | Kitchen Ranges
Sony Cyber-Shot DSC-w5 "MEMORY Stick LOCKED" ??? please help!
take your memory stick out of your camera and theres this sliding thing on the back...slide it so that its not on the lock side? does that make any sense? well..good luck!
May 11, 2008 | Sony Cyber-Shot DSC-W5 Digital Camera
DSC w5 has a spot in every picture
Assuimn there is nothing on the lens[I would not think this is the case as it would not show as a distict spot Not ne fora DIY or a repairshop this is a a failure of the CCD. Depending on the age of the camera and model this may qualify for replacement, as there was a reported CCD issue at one time Either that or Sony may offer a replacement at a good discount.
Aug 05, 2007 | Sony Cyber-Shot DSC-W5 Digital Camera
Sony Cyber-Shot DSC-W5 Digital Camera Logo
74 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
