Question about GE Washing Machines
GE washer WHSR2070VWB about 9 years old does not spin dry clothes. All of the cycle works except the final expulsion of water
  • GE Master
  • 19,396 Answers
If the cycle stops when it is supposed toi drain , that means that there is a problem with the drain pump.
Posted on Oct 12, 2008
  • Ginko
    Ginko Oct 12, 2008
    Start checking the drain hose, see if it is obstructed.
    Parts to be checked are:
    Drain lines
    Drain pump.
    Drain pump belt and pulley (depending on model)
    Timer selector (unlikely from description)
    Here are specific diagrams for drain hose and pump on your model:
    See Part # 304 Drain hose on diagram.
    See Part # 655 Drain Pump on diagram.
    See External panels assembly diagram.
    See all parts for your model here
    Here you find a generic diagram for your washing machine Front Load Frigidaire/GE/Kenmore Style
    See also the following suggestion from repairclinic:
    It won't drain
    If your washer won't drain, check these:
    It spins, but doesn't pump
    It doesn't spin or pump
    It pumps, but the water returns
    If
    your washer spins but doesn't pump the water out, the drain line is
    probably clogged. In many washers, a small sock or other piece of
    clothing can get between the clothes tub and the outer tub that holds
    the water. If the clothing gets between the tubs, it may then get into
    the drain hose that's attached to the pump--or even into the pump
    itself. If it's in the pump, you need to remove the hoses from the pump
    and pull the item out.
    To remove the sock from the outer tub
    port, open the washer's main access panel and remove the large-diameter
    rubber hose that connects the pump to the bottom of the outer tub.
    Then, using needle-nose pliers, try to grab and remove the clothing
    through the port.
    Sometimes you can't remove the stuck
    clothing from below. Then you have to remove the agitator, top of the
    outer drum shield, and inner clothes tub. This isn't easy to do--and
    you may need special tools--so you might be happier getting a qualified
    appliance repair technician to do the job.
    If the drain line
    isn't plugged, the problem may be with your pump. Even if the pump
    appears to be turning, the internal impeller may be broken. If so, you
    need to replace the pump.
    If
    your washer doesn't spin or pump water out but the motor is running,
    your washer probably has a frozen pump pulley. If so, you need to
    replace the pump. To check the pulley, remove the pump from the washer
    and try to rotate the pulley manually. If it doesn't turn freely--if
    it's frozen or stiff--replace it.
    If
    the water that pumps out of the machine goes back into the machine
    after the spin cycle, your washer may be siphoning the water from a
    laundry tub that has a slow drain, back into the washer. The usual
    remedy for this is to improve the draining of the laundry tub. (Is
    something stuck in the drain?) Also, check for these problems:
    • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
    • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
    It doesn't spin
    If your washer won't spin, check these:
    It doesn't pump or spin
    It pumps, but doesn't spin
    It spins only with the lid closed
    If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
    • If
      the motor is running, your washer probably has a frozen pump pulley or
      a broken pump belt. To check the pulley, remove the pump from the
      washer and try to rotate the pulley manually. If it doesn't turn
      freely--if it's frozen or stiff--replace it. If the pump belt is broken
      or looks quite worn, replace it--but be sure to check the pump pulley
      before you change the belt.
    • If the motor isn't
      running, the lid switch may be defective. If so, the washing machine
      can't spin and may not function at all. The switch is inside the
      washing machine main housing near the door frame. Often you have to
      raise or open the top or front of the washing machine to get to the
      switch. If it's defective, you need to replace it.
Water in clothes after spin cycle
need to open washer and check the DRAIN MOTOR PUMP , usually gets clogged with lint and debris , usually located at the bottom side , small motor w/ propeller ,where the drain hose is connected, AJ
Nov 11, 2009 | GE WJRR4170E Top Load Washer
GE washer will NOT spin, but does all other functions.
You need to have the fan belt checked. It must have been loose or broken.
Jul 22, 2009 | GE WSXH208A Front Load Washer
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Cold water pours in during final spin
No - the timer is the likely suspect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
There is something clogging your pump, dismantle it to clear it. Plug off the wall socket mains first.
Jan 15, 2009 | GE WDSR2080D Top Load Washer
Kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Dec 06, 2008 | Roper RAB2121KW Top Load Washer
Washer pauses at various points in all cycles
Peace friend,
ngfam1 at your service
Tell the dealer you want a different make!
IT'S EASIER TO KEEP CUSTOMERS THAN TO FINED NEW ONES!
We have been selling appliances for over 65 years!
And you will only see one GE appliance on my showroom floor!
Whirlpool or SPEED QUEEN! ARE THE BEST!
HERE IS MY STORY FOR YOU!
AFTER 6 YEARS AND THREE repairs.
I threw GE in the trash and bought a Speed Queen Commercial grade washer and, I AM 53 YEARS OLD AND THIS IS THE LAST WASHER I WILL EVER BUY!
tHEY ARE TESTED AT 8 loads a week for 25 years!!!!!!!
The washers and dryers today use so much less water,electricity,and detergent that they pay for them selves after a only a few years.
My advise is, it is cheaper to buy, run, and operate a new efficient machine! You will see you water and electric bill reduced!!!!!!!!!
Speed Queen commercial grade top loader uses only 34 gallon of water compared to the others at 48-54 gallons!
THE FRONT LOADER,
(GET THIS) ONLY 13.9 GALLONS of water and washes in 35 minutes and the clothes are cleaner and last longer cause it uses water agitation instead of a vain to wear out your clothes! How about spinning at 1000 RPM and the clothes come out so dry they are only in the dryer half the time than all the other machines! Thus half the gas or electric bill!!
All my employees have replaced their laundry pairs with Speed Queen!
My Guys call it the, "No brainier Machine!"
I hope you can utilize the good advice I so enjoy sharing with all the good people we talk to!
ngfam1
Bless You
Please give me a good rating before you sign off here at fixya.com
Aug 31, 2008 | GE WCVH6260F Front Load Washer
Washer does not spin
I have a GE WSSH300G0WW washer and it is doing the same thing except I can not go to any other cycle to get it to spin. The water is just sitting in the machine right now.
Dec 12, 2007 | Washing Machines
Old GE Washer WNSR2100T8WW will not pump out water nor spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Sep 12, 2007 | GE WJSR2070B Top Load Washer
Washing Machines Logo
121 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
