Question about Nikon D70 Digital Camera
Dark block appears on some pictures in lcd display
Today i noticed a black block appears in the lcd display when i take pictures. it appears in the top and sometimes only covers a small part of the display but sometimes covers most of the image. I have reset my camera, removed and replaced the lenes, formatted my memory cards... It doesn't appear in all my pictures, just most of them and seems to be worse when i take pictures of something with a lot of light. It is not the same as a highlight (which flashes to indicate a point of too much light) it just looks like something's covering the lens horizontally... Can you help please?
  • eturk5 Oct 12, 2008
    I am having a similar problem with my D50. When I take photos, especially at a zoom, there is a dark shadow on the bottom of the picture. It doesn't happen all the time. It seems to happen only in low light situations, outdoor or indoor. It's ruining a lot of good pictures. I reset my camera to factory settings, reformatted my memory cards and it hasn't helped. Any ideas?
    Erika
advance
  • 107 Answers
SOURCE: Black Lcd and pictures.
The problem you are experiencing is due to the shutter being stuck closed. Normally the shutter is kept open while you compose the image, and then when you push the button it closes and the CCD records what it was seeing at that moment. When the shutter is stuck the image is blocked from reaching the CCD at all times so you can see nothing. Unfortunately the shutter is a tiny delicate component buried deep within the lens assembly and is not accessible without complete disassembly. I would suggest finding a repair center to ship the camera to, or replacing the camera. I would definitely not _gently_ tap the camera on a hard surface to possibly dislodge a slightly stuck shutter blade. This could easily cause further damage to the camera. However, you are not me. ;) David Millier Advance Camera Repair
Posted on Feb 24, 2007
  • 13 Answers
SOURCE: nikon coolpix s1 dig camera ,no picture
With the power off, hold the camera in your palm and smack the front of the camera on your leg or arm. You might have to smack it a few time to get it to work. It has to do with the camera CDD lense (shuttle) being stuck. By smacking it around, it will free up the lense. Being extra gentle with it though. It worked for me. Hope this help.
Posted on Nov 11, 2007
  • 13 Answers
SOURCE: Nikon Coolpix
  • 5 Answers
SOURCE: system error
turn on and off 6 or 7 times while banging on the body beside the lens, worked for me, apparently coolpix lenses tend to stick, as my girlfriend says " a good bang will solve many problems"
Posted on Dec 04, 2008
  • 3 Answers
SOURCE: NIKON D100 LCD DISPLAY FLASHING CHA ERROR WITH ANY CF 1 GIG
I had the same problem and thought I had looked closely at the pins in CF slot but after finally taking it to a repair shop, the tech showed me a bent pin. It really wasn't that apparent first time around. He told me its a common problem as long as they use the CF cards. I had the pins replaced and my D100 is working great. Best of luck.
Posted on Mar 30, 2009
I have a phillip magnavox big screen tv it works fine but the color is too dark i think i need a picture tube
If its the one indicated here or one like it :
The picture tube type (CRT) rear projection tubes require annual cleaning.
With set off and back removed locate the three large black lens atop the chassis--hard to miss them.
The are the red, green, and blue tubes and are your light source for the picture---------if dark and they are dirty or dusty the picture will be darker and not as sharp or clear as it once was..
spray some glass cleaner on a paper towel and wipe them clean.
Do not touch anything else in set and do it with set unplugged.
put back cover on and see if picture is noticeably improved; if so do it once a year or more if in a dusty place.
Let me know if you have questions.
Mar 16, 2012 | Philips Magnavox 51MP392H Rear Projection...
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Dull laptop screen back light
You may have a faulty CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Dec 30, 2009 | Dell Latitude C610 Notebook
My screen is dark, totaly black, what should I do ?
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 28, 2009 | Everex StepNote VA2000T Notebook PC
Monitor went dark
www.lcdparts.net
Sep 25, 2009 | Toshiba Satellite A135-S2386 Notebook
Is on but black screen
www.lcdparts.net
Sep 24, 2009 | HP Compaq Presario CQ50-110US Laptop
E1705 Monitor is black also, but can see this screen fine on tv
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 09, 2009 | Dell Inspiron E1705 Notebook
IBM R50
You could have a defective LCD screen, If the laptop appears to be running and the hard disk is spinning but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 22, 2009 | IBM ThinkPad T23 Notebook
My screen is dark
Check out
www.lcdparts.net
Jun 21, 2009 | MSI M670 Notebook
Pictures are black
My 4300 works fine until this week. No picture display on the LCD screen. Settings like date, exposure, etc.. are fine on the LCD screen. Able to get into setup mode and the colour menu selection box is fine. This shows that the LCD screen is working fine. Prior to this happening, I notice that when I took pictures in zoom mode, the picture turn out to be orange. I suspect this is caused by electronic failure. Light entering the lens cannot be transmitted to the LCD screen. Some photoelectronic stuff had reached its MTBF (mean time between failure)? Is there a way to save this camera?
Mar 17, 2008 | Nikon Coolpix 4300 Digital Camera
Nikon D70 Digital Camera Logo
49 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
