Question about Brother Office Equipment & Supplies
Unable to get a wireless connection
My Brother MFC885CW is showing that is connected to the router (by wireless) but I am unable to print from my MacBook
    Sergeant:
  • 352 Answers
Create a new folder on your desktop and name it . Un-intall printer and printer software completely. Go to Brother's website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Posted on Oct 12, 2008
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
Hp printer 7510 will not print or scan
mac or pc
try connecting hardwire to router to see if it sees the ip address or you might need to update drivers
Mar 22, 2012 | Office Equipment & Supplies
We have Brother 7840w wireless printer. unable to connect to router - connection ng
Try:
Log into wifi router D-Link dir-615.
Change: security mode to WPA-Personal, WPA Mode to WPA Only, and Cipher Type to TKIP.
Then try connecting again.
Aug 09, 2011 | Brother MFC-8870dw Wireless Multifunction...
:unable to print the wireless printer hl2170w
This is one of the common connectivity issues marring the benefits of having a wireless printer. In this situation your printer will not print when connected wirelessly but would need you to set it up with your system using a USB cable. Try resetting the IP of your system to what is mentioned in the printer and in case there is a router connecting your printer and system then use the IP address of router and put it in your system. This should help you fix this printer issue.
Apr 06, 2011 | Brother HL-2170W Mono Laser Printer
Unable to connect to the laptop computers
dear Sure there is, but it's supposed to connect via a LAN switch. Since it worked at your old place, did you miss a step? Was the printer plugged into a router and the computer also plugged into the same router?
Start with the wired network setup section in the quick start guide. It might give you an idea on what to do http://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_MFC_490CW_EN_1578.PDF
Thanks.
May 07, 2010 | Brother MFC 490cw Color Inkjet...
Unable to print on wireless network or send e-mail
Recheck that the printer is shared by the computer it is connected to and that all PCs are on the same network. If no success try disabling the firewall on the pc that your printer is connected to. (If printing now works readjust the firewall permissions).
On the second open Internet Explorer; Tools; Internet Options; Connections and make sure that there is a selection for... Never dial a connection.
Jul 08, 2009 | Acer Computers & Internet
Unable to setup wireless print server with wireless router
The issue was the wireless print server not properly connecting to my home network and thus being unable to see my modem/network. This was because my linksys wireless print server generates its wep key with a different algorithm than the Motorola surfboard SBG900, this also explains why when I was using my old linksys wireless g router, things worked without any issue (same wep key algorithm). Once I figured out how to manually configure the print servers wireless settings and manually enter the wep security settings I was able to connect to my network and the configuration found the print server and I was able to finish setup.
Nov 27, 2008 | Linksys WPSM54G Print Server
I am unable to set up wireless.
What model router do you have? Are any other computers connected to this router? Can you see the SSID for your router when you attempt to connect?
Dec 20, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
154 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
