Question about Amana Dryers
Dryer shuts it self off after running for awhile. you can restart it after it sets for awhile.
  • 943 Answers
HI thanks for your question. first i would clean the lint, from the inside, and the venting to the outside. try that. if the motor just over heats, because of lint on it. this could solve your problem. if not then the motor needs to be replaced. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 12, 2008
My whirlpoool dryer runs but shuts down before clothes dry and won't start back up untill it sets awhile
oh oh sounds like a bad motor with burned windings? let me guess it shuts down after about 20-30 minutes?
May 26, 2014 | Frigidaire FER311FS Electric Dryer
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
Runs for awhile shuts down and will restart but will run awhile and shut down
Check your oil, you have a low oil sensor on your unit and if the low oil sensor will shut the engine down,
Aug 28, 2011 | Dewalt DG6000 Heavy Duty 6000 Watt Gas...
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
Runs for awhile and shuts off weight awhile you can turn it back on
Motor is defective. The windings get hot and it shuts off.And comes on later when it cools.
for questions send email
Leo Ponder
imufo2@sbcglobal.net
Jul 26, 2010 | Whirlpool LER4634J Electric Dryer
Dryer starts drying but shuts off after awhile
I'm having the same issue....also sometimes it will run all night...can anyone answer this post
May 29, 2010 | Maytag SDE4606A Electric Dryer
Heat shuts off after few minuets of running
Normal 0 Hi, You need to change the coils on the top of the gas valve. This is a very common problem with the newer gas dryers. We have them for $29.95 on out web site www.whilpoolpartssurplus.com
If I can assist you further on how to replace them, please let me know.
Thanks
Vic
May 24, 2009 | Dryers
Dryer quits after about 10 min and won't restart for awhile.
Sounds like a bad motor. I could help further if I had model #
May 09, 2009 | Dryers
Dryer runs for awhile, then shuts down.
I can think of two possibilities, the first one you should do regardless.
1. If the vent is blocked, the dryer will overheat and there are temperature sensors in the dryer that will shut it off. Make sure that the vent is clear all the way to the outside. If it has a plastic hose at the dryer, throw it away and replace with a metal one. Make sure that the vent hood on the outside is clean and the flap is opening freely.
2. The black shavings could be from the drive belt or the bearings on the drum. If either are bad, it could cause the motor to overheat, which would then shut off.
David
Mar 22, 2009 | Whirlpool Dryers
Dryer starts then shuts off
it seem like your motor could be faulty (overheating) causing the thermal overload to open, stopping the motor after awhile it will cool down and the thermal will reset, if this the case the bearings or the windings could be faulty
Dec 13, 2008 | Dryers
Dryers Logo
56 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
