Ncr 5633 currency dispenser
This unit was bought from a casino and the cabinet is labeled "BILL BREAKER" when you insert a bill ($5,10 or 20) the "change" aka bills only disperses the first denomination. the rest go to the discard bin and the display shows "error 22 track error". the bills are coming out straight and evenly spaced. your help would be most appreciated. the unit was recently cleaned and the vacuum pads and belts were checked out OK. Jim
Sounds to me like it is only configured for one bill type, in diagnostics is a menu choice called "learn bills" to teach it the bill types ie. type 1, type 2 and type 3 etc. but you'd need the advanced diagnostic access disk or usb to go there.
Posted on Nov 06, 2008
When I open the refrigerator the freezer pops open
I appreciate your inquiry, Tammy McAninch!
Based off the information you have provided your Frigidaire freezer door pops open when you open your refrigerator door. This can happen with new refrigerators because the seal is new. I understand your question is labeled under model FGHB2866PF. It could be issues with your door not aligned properly and hitting your freezer door to open. I would check the gasket to make sure they are creating the proper seal on your freezer in order to check that you can use a dollar bill. Place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket. If you continue to experience issues with your freezer door I would recommend reaching out to a professional for further assistance. I hope this information helps to some degree. -Matt
Nov 17, 2014 | Frigidaire Gallery Series FGHB2866PF 27.8...
We have a Gallery model refrigerator/freezer. I opened the freezer this morning and everything was covered with excessive frost.
Thank you for your post, friend!
I see that you are receiving an excessive frost buildup on the inside of your Frigidaire refrigerator. I would check the gasket to very it is sealing properly. You can do that by using a dollar bill. Place the bill between the body of the fresh food and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet then the gasket may need to be replaced. I hope this information has been beneficial. - Matt
Oct 11, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
How can we get the counter to know when a different bill is mixed in
We consider the semacon a throw away machine. That being said, the s-1625 is not capable of detecting different bills. It is just a unit counting machine. It does have the option of counterfeit detection using magnetic or UV sensors if you have that version. A true counter that can find the wrong bill in a pack is at least a $3,000 machine and are very nice. Good luck.
May 22, 2014 | Semacon S-1625 Premium Currency Counter
How o we get the s-25 to seperate bills?
It is not capable of separating bills. You need a different machine to do that. Like a Shark 100N for example. Good luck....
How do I repair a samsung french door refrigerator rf 265,266 with interior water dispenser that parts fell into cabinet?
The parts are readily available for your repair, however, you should contact a qualified Samsung technician. If the dispenser is not assembled correctly, the water flow may not shut off. The resulting water damage could be very expensive compared to a service bill of $150.
May 01, 2014 | Samsung RF265AA Bottom Freezer French Door...
Looking for owners manual
Call me at 985 893 52four one. I can email you one.
Give me the model and serial number to get the correct manual.
Nov 08, 2013 | Bramdt Brandt DeLaRue 8625 Desktop Note...
What is the maximum amount of bills a bill counter can count?
From what I have read, it seems that what matters the most is the speed of the counter. In this article I found, the fastest counter can count 1500 bills per minute:
http://www.abcoffice.com/office-equipment-news/tag/bill-counter-reviews/
Apr 29, 2013 | Retail Supplies
My freezer has condensation inside
Hi - From what you have described it sounds like the freezer has a poor door seal. When cold air and warm air outside is entering it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit.
Oct 06, 2012 | Frigidaire Freezer 16.7 Upright Freezer,...
My side by side refrigerator is not cooling
Inspect the gasket for dirt or debris that could prevent it from sealing. If you find any, remove the large debris, then wash the gasket, using a scrub brush and warm, soapy water.
Check the gasket for cracks or tears that can let cold air escape. If you find any, replace the gasket. If the gasket appears to be solid, go on to step 3.
Check the seal: Open the door, insert a dollar bill partway and shut the door on the bill. Try to pull out the bill. You should feel some resistance. Repeat the test at several points around each door. If the bill slips out easily, replace the gasket.
If there is any circuit breaker, reset it.
Check for thermostat problems. It could be off or won't cool properly (too warm,). If it can't be fixed with a simple adjustment, call a professional.
Check for coil problems. The compressor can overheat due to dust buildup on condenser coils. If so, vacuum the coils.
The above are the likely problem and the solution.
Take care.
Jun 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Computers & Internet Logo
794 people viewed this question
David Payne
David Payne
