Question about Brother IntelliFAX 2800 Laser Fax
Can't find my manual.......
I went with a different phone company and now I can not receive my incoming faxes. They say it's not their problem since I do have a dial tone. Said I need to contact Brother to find out how to set my fax machine for a distinctive ring. I misplaced my manual so I need help (I'm not tech savy at all:(
Bottom line: I have one phone line with 2 phone numbers and need to set machine for distinctive ring. They are saying this should work.
  • 94 Answers
To receive a fax there you have to have an open “COM" port to receive the fax through. You may download the manual here:
Posted on Oct 12, 2008
  • 2,712 Answers
THIS is a link explaining how to set distinctive ring tones. You can download the user manual HERE.
You will need Adobe Reader to view the document. Download it HERE for free.
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
I can send faxes but can't receive. Phone company says lines are fine.
look up the manual to your specific fax machine. There are different settings and the manual will tell you what to put it on in order to recieve faaxes....good luck!
Aug 06, 2012 | Brother IntelliFax-4100e Fax
Epson Stylus CX5700f I have just setup fax. I am having problems receiving faxes and telephone calls
You need to do two more steps.
1. contact the phone company about distitive ring. This will have a different ring for incoming faxes.
2. set the fax up for distitive ring once the phone company sets you up. This will cause the fax only to answer when another fax is calling, due to the distictive ring set up.
Feb 14, 2012 | Epson Stylus CX5700F All-In-One InkJet...
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
Brother MFC-240 will not receive faxes...
I cant get my MFC-290 to receive incoming faxes
Sep 21, 2009 | Brother Multi-Function Center MFC-240C...
I want the fax to work with an identa ring. How do I program this? As it is now I have to turn on the fax to receive. Does this HP work with identa ring?
The following set up assumes you have one conventional phone line, but two different phone numbers. One being your regular phone number and the other a distinctive ring for your fax machine
If that is what you have then this is how you set up the phone. Its important to know what type of distinctive ring your phone company will send to your phone. If it doesn't work you can talk to them about getting a different one than their default distinctive ring.
2 Set the HP all-in-one to answer incoming calls automatically.
Press the Auto Answer button until the light is on.
3 Change the Answer Ring Pattern setting to the pattern that has been assigned to your fax number by the telephone company, for example, double rings or triple rings.
For information on changing this setting, see Change the answer ring pattern
(distinctive ringing).
Note Your HP all-in-one is factory-set to answer all ring patterns. If you do not set the correct ring pattern assigned to your fax number by the telephone company, your HP all-in-one might answer both voice calls and fax calls or it might not answer at all.
4 (Optional) Change the Rings to Answer setting to one ring or two rings.
For information on changing this setting, see Set the number of rings before answering.
5 Run a fax test. For information, see Test your fax setup.
Your HP all-in-one will automatically answer incoming calls that have the ring pattern you selected (Answer Ring Pattern setting) after the number of rings you selected (Rings to Answer setting). Then it will begin emitting fax reception tones to the sending
fax machine and receive the fax.
If it is easier or you want to know other options which may be more applicable to your phone setup. You can find that information here.
Jul 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Cant send faxes or recieve
Do you still have the problem?
Did you go through the entire setup procedure according to the manual including the fax/tel set up? Fax/tel setup tells the fax machine how you are using it. For example is the phone line used for just receiving faxes or is it used to receive phone calls AND receive incoming faxes OR is there a telephone answering device (TAD) attached to your phone line. If there is one, set it to 2 rigns. If you have it set to 4 rings the fax could disconnect before receiving the incoming fax. If you cannot send, then it has to be a line problem assuming you went through all the set up procedures correctly. Short of this you may have a bad unit and need to return it.
Apr 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X6170 Has a shared phone/fax line with different numbers
Open the Lexmark "Fax Printer Setup Utility". Click on the "Connection/Dialing" tab. In the "Interact with Phone Line" section, "Answer Incoming Calls:" should be set to "If fax tones are detected".
If this is turning out to be too unreliable for you, you will need to either manually receive incoming faxes (by changing the setting to "Manual"), or you will need to at least spring for a separate phone number with a distinctive ring for incoming faxes.
Apr 05, 2009 | Lexmark X6170 All-In-One InkJet Printer
Brother Intellifax 2820
It could be a compatibility issues between the two faxes. If the other fax is particularly old its communication speed could be too slow for your fax.
Also don't rule out the line on there end. Many times in my job I've had Telephone company's check the line remotely and say its ok but its not until they come out to site that they find an actual fault.
Do a manual reception. Put your fax reception mode from automatic to manual. When the fax rings in pick up the line with the hook or speaker phone button and then press the start button. This rules out a fair part of the line correction. If you can receive of course.
Feb 06, 2008 | Office Equipment & Supplies
Incoming fax
Oct 15, 2007 | Samsung SF-531 Plain Paper Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
65 people viewed this question
James Cagle
James Cagle
Jim Keysor
