Question about Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Deluxe -- Coffee weak weak weak
Thank you in advance to anyone who might assist me with my recent problem -- had the coffee maker for about two years now and it has started to make my coffee like a weak tea, no matter what I set the grind on.
I notice that the stream starts brownish, but very quickly changes to almost clear... am wondering if perhaps the water/grounds are not being held properly in the brew unit.
One more thing I noticed is that the grounds do not seem to change size, no matter what I put the setting on?
    Genius:
  • 1,124 Answers
You have to clean the coffee grinder this will be fixing your problem with the ground size and brewing cycle.
Posted on Oct 13, 2008
  • Saeco Master
  • 19,396 Answers
When the coffee is weak, that is often because the water is not at adequate temperature.
Check if the coffee is in right quantity and pressed in the right way. If it is than it means that the water was not hot enough.
Check water temperature, if water is completely cold, the element mus be replaced, if water is hot, but not enough, then replace thermostate activating the pump.
  • Ginko
    Ginko Oct 13, 2008
    Check also the grinder, idf it is obstructed, and not enough coffee is being loaded, then that can also be a reason for a weak coffee.
Weak coffee saeco vienna "not digital "
Hi
Has the size of you ground coffee changed? If it is not the size of granulated sugar then its your grinder. Check ebay completed listings. Saw one there couple weeks ago.
Nov 24, 2009 | Saeco Vienna Digital Coffee Maker,...
Change the grind in Saeco Vienna Deluxe coffee maker
Hello kgspco.
You will need to work the 'dial knob' untill it free's it-self.
The higher the number the Coarse(r) the grind.
If you want rich - dark - strong coffee, set number between 4 - 8.
(if you can free it up - keep trying
Jul 06, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Deluxe Repair Manual
Try here:
http://www.saecoparts.com/SaecoViennaDeluxe.html
Apr 07, 2009 | Starbucks Saeco Italia Digital Barista...
How do I turn off the "descale now" warning on my Saeco Vienna Deluxe espresso machine?
After performing the descale, use the menu buttons to get to descale and set to reset.
Dec 05, 2008 | Saeco Vienna Digital Coffee Maker,...
Saeco Vienna Deluxe
http://cerinicoffee.com/Saeco_User_manuals_free.asp
Apr 26, 2008 | Saeco Vienna Deluxe
Saeco Vienna Deluxe odd burning smell
gears are probably broke. Happens when to much coffee and coffee ground too fine get compacted into the brew drive unit.
Shreds the plastic gears like butter.
Machine has to be sent out for service, gear replacement is long and impossible for anyone untrained. Trained techs it takes at least an hour if not more.
Apr 21, 2008 | Saeco Vienna De Luxe Espresso Machine
Slow coffee drip
did you change coffee different coffee different setting lower our coffee setting move it only when it grinding only cheers
Dec 07, 2007 | Saeco Vienna Deluxe
Grinder setting i
0 is the finest setting. If you read the manual, it advises to adjust your grinder ONLY when the grinder is actually working. Also, you should only adjust it gradually from one setting to the next (ei. from 2 to 3), and wait about 5 cups before adjusting the setting again.
Oct 22, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna De Luxe Espresso Machine Logo
515 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
Shehu Pro
Shehu Pro
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
