Question about Whirlpool Washing Machines
Black mold growing on rubber gasket and under rubber gasket in Whirlpool Duet front loading Washer
The solution? Plain old bleach.
Scrub rubber seal on door. Run the bleach through the machine once a month to keep clean.
Keep door open after each wash to ensure that it dries out properly.
d
Posted on Mar 16, 2009
Duet washer is stinky.I leave the tub door and the soap dispenser door open when not in use. Even so, epecially after doing several loads in a row I have a very stinky machine There is mold growing on the...
are you on a well??
do you use bleach in with your whites??
some well water untreated can cause exceptionally stinky machines, especially if no or very little bleach is used during white washing..
usually if you use bleach in with your whites in normal amounts and leave the door open in between uses there should be very little stinky odor or mold growth.
the mold growing on the gasket is a sign of to little bleach or none being used, and/or a really damp environment for the unit to reside in.
they do make several cleaners designed just for stinky front loader washers..
they might help..
i've been using a front loader for 13 years, leave the door ajar between uses, and use bleach in every white load and have had no issues with stinky unless i or someone else doing wash forget and close the door for a couple days, then it gets stinky but goes away after white load with bleach and hot water..
hope this helps,
best of luck,
ttfn
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mold on the gasket of kenmore duet front loader. have run the clean cycle, and scrubbed the gasket and inner liner also
This is a common problem with front loading washers. To prevent this issue leave the washer door slightly ajar after use. It will promote air circulation and prevent mold.
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stale odor in machine and on towels and clothes. I have used the affresh, Bleach, baking soda, use powder HE detergent, no liquid fab softner, I am at the end of my rope with this stinking machine ready to...
Towel mildew smell is being transferred from the washer. The washer must be cleaned first. The problem is not "brand specific" all clothes washers have mold growth to a certain degree. Bleach or vinegar will kill the mold inside your washer but won't remove it or the residue it grows on thereby making the situation worse because it leaves a "base" for more detergent to collect on and more mold will grow.
Washing machine mold / mildew odor is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet front loading washer has mold and mildew growing even though I clean it out often. It makes the laundry room smell.
yes they are very good for that... and for the bad news it is almost impossible to get it out.... sorry for the bad news but all of them do it
May 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Black mold growing on gray rubber boot inside door.
Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
Apr 10, 2009 | Frigidaire Affinity ATF7000E Front Load...
Black mold growing on and under rubber gasket
it should be a fairly straightforward replacement, these door seals attach to the inner tub and the front case by clamps or straps -view these to check whether its within your capability. these seals should be around the £25 mark. note the chances are these marks may start soon on the new seal !!
Mar 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Rubber Seal Holds Mold!
This is a problem that seems to show up on almost every front-loading washer due to the design of the rubber boot that attaches to the front of the machine. It is extremely important to wipe down the rubber after usage but even this doesn't always help. There are a couple of products out there that claim to get rid of the mold and smell, something called Purewasher that you could look up on www.smellywasher.com and also something that whirlpool sells for this purpose.
Mar 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washing machine
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Good luck!
Aug 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
379 people viewed this question
Dan Webster
Dan Webster
Sal De
