Panasonic PT-47wx49e My Panasonic PT-47wx49e has developed a problem. When I turn it on (either with the remote or the on tv power button, the tv shuts off about 5 seconds later. The power light is steady, until the TV shuts off, then it goes out. No blinking light like others have reported. It won't respond to attempts to turn it on unless I unplug it from the wall outlet & plug it back in...but it does the same thing after 5 seconds. One tech said (after just looking at it not turn on) that it's the High voltage transformer & estimated $500.00 to repair. Is he right about the problem? Is he right with the estimate? I really don't want to dump the TV, as it isn't that old. Any suggestions?
  • 8,617 Answers
The repair tech is wanting to take alot of your money, you can get the entire deflection baord which has the flyback on it remanufactured for about half of what he wanys to change the flyback. Heres alink leave them a email with your model number they will send you a quote to have your deflection D board rebuilt which carrys a full warranty. heres the link.
http://servicemanuals.vstore.ca/
Posted on Oct 12, 2008
Tip
Panasonic PT-61LCX66 Lamp Timer Reset Models No. PT-52LCX66 / PT-56LCX66 /...
Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Here are the steps to reset the Lamp Timer for your Panasonic Multimedia Projection HDTV:
  1. Plug your Television in.
  2. Press the POWER button on the TV or the remote control.
  3. Press and hold the VOL- button on the TV, while holding the 0 button on the remote control for at least 5 seconds.
  4. When the reset procedure is complete, a confirmation screen will appear.
  5. Release the buttons and the LAMP indicator will go out.
Download the TYLA1001 Replacement Lamp Installation instruction guide here.
I hope that helps.
on Apr 11, 2010 | Panasonic PT-61LCX66 Television
Tip
Panasonic PT-56LCX66 Lamp Timer Reset Models No. PT-52LCX66 / PT-56LCX66 /...
I hope that helps.
on Apr 11, 2010 | Panasonic PT-56LCX66 56" HDTV
PT-47WX49E just shut off
maybe the convergence resistors? sometimes when the ics blow a resistor or a few blow
Jan 04, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Help please
called h.v. shut down call tv repair shop
Sep 18, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49E will not power on
Thats a power supply module going bad. Dont use it until a person with knowledge on TV see that. Or if you feel you can DIY open the back panel to see if there is a toasted or foreign object near the power supply area. Its located when you follow the main plug going into the back panel of your TV. Look for a dying Fuse too. And watch out for Capacitor that has still current, you may electicuted with that component. That parts its only for qualified servicemen area only.
Aug 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WX49E Doesn't work
This is for sure a safety shutdown circuit that is shutting down this TV set. It is a hard call to pinpoint a problem such as this without first doing some troubleshooting on the TV set. You could have a short in the sweep power supply, the horizontal output transistor could be bad, therefore then the flyback is probably bad, or the vertical IC could be bad, there could be a regulator problem in the main power supply that could be bad, and also the convergence IC's can cause this problem. Almost any circuit inside this TV set can be detected and staop the set from starting up. Good Luck
Jun 07, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
Electro Med Services...
