Question about Refrigerators
Kenmore refrigerator wondering with my model of refrigerator, can i switch the doors so i can open it from the left?
  • shotbuc Oct 12, 2008
    There is caps on the other side of the refrigerator but I dont see any caps on the doors itself
  • 943 Answers
Hi thanks for your question. yes you can only if on the other side you have caps covering the screw holes if caps are not there then no you cant. but if they are then yes you can.
Posted on Oct 12, 2008
  • john gagnon
    john gagnon Oct 13, 2008
    IF no caps the it cant be changed. sorry
How to make the freezer door on a kenmore elite 74033 tilt
Refrig of the year: Kenmore Elite 74033 Refrigerator
Consumer Reports Rated: Excellent
Hello Charles,
Just when I'm thinking Sears SERVICE is NOT some sort
of sad/bad joke... you put in a Kenmore Elite Model number...
continued search found your Owners Manual... Pages 10 & 16 are what you want
The front should be slightly higher than the rear to aid in door closing... (page 10)
Your refrigerator has two front leveling legs-one on the right and one on the left. Adjust the legs to alter the tilt from front-to-back or side-to-side. If your refrigerator seems unsteady, or you want the doors to close more easily, adjust the refrigerator's tilt using the instructions below: NOTE: Tools Required: 11/16" wrench or flat blade screwdriver.
1. Turn the leveling leg to the left to raise that side of the refrigerator or to the right to lower it. It may take several turns of the leveling leg to adjust the tilt of the refrigerator.
NOTE: Having someone push backward against the top of the refrigerator takes some weight off of the leveling legs. This makes it easier to adjust the legs.
2. Open both doors again and check to make sure that they close easily. If the doors do not close easily, tilt the refrigerator slightly more to the rear by turning both leveling legs to the left. It may take several more turns, and you should turn both leveling legs the same amount... (page 16)
`` After that...
All you have to do to maximize that efficiency is keep the closure area free of pizza boxes, ice cubes or errant frozen food bags.
Hope this was helpful...
Kenmore Elite 74033 Refrigerator Review Kenmore com
Feb 12, 2016 | Kenmore Refrigerators
On a Kenmore side by side refrigerator that has two light bulb sections, what causes the lights not to work?
The door switch provides a source of power to two things. Yes the door switch can be bad. What is your model number? There was some models that left the lights on when the door was closed and people would unscrew the bulbs just to sell them to people unaware. That problem was related to a bad relay on the motherboard
APPLIANCE 911
Nov 28, 2015 | Kenmore Refrigerators
Freezer fan is noisey and can t find serial number
The number you will need is the model number. On side by side models there are a few places to look. 1- inside fridge on right or left wall. 2- Open fridge door and look up near the top front lip. 3- Open both doors and look on body of fridge under the doors. 4- Fridge door sometimes there is a sticker right when you open. Mostly you are looking for a silver sticker or silver plate. It gives you a model number and serial number. If you need further assistance please mail me back.
May 26, 2011 | Kenmore Side by Side Refrigerator
Wondering if the kenmore 29313 freezer has a way of regulating the temp. can not find a control button or dial please advise Thank you
My Kenmore model 29313 upright freezer's temperature control knob is located at the base, below the door. Check out the left hand side and see if you see the knob there.
Nov 19, 2010 | Refrigerators
I want to change the direction of the opening on my kenmore from right to left. Is this difficult?
Hello and Welcome to FixYa!
What I understand from your query is that you want to alter the door opening direction If I'm right... Altering the door such that it opens on the counter side is possible. but in most cases, it ruins the working of the device completely.. actually changing the direction causes many things to go wild from the refrigerator light switch. to the refrigerator doors gasket. Also it requires some new holes to be drilled at the other side... That turns the alteration to more complex and tricky.. In a nut shell, I would not suggest to have such changes to your equipment.
Have a nice day,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Sep 18, 2010 | Kenmore 64823 Top Freezer Refrigerator
Alarm no longer sounds when fridge door is open
Chances are that you will have to replace the buzzer. That part is available at Sears Direct. J
May 28, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Open door warning signal not working
Your warning signal switch has gone out on this unit. This is a simpe repair to make. You will need to provide us with the complete model number so we can get the correct part out to you.
This is a great feature to have on your unit and it saves the compressor from going out by the door being left open over an extended period of time.
We hope this answers your questions and we look forward to assisting you with other appliance repair issues.
Nov 05, 2009 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
