Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSS26SGRB SS small water seep
I have a GE Profile PSS26SGRB SS (4 yr old). Recently I have noticed that water is seeping throught the bottom of the water despenser side cover even though there is not collection of water in the water collection tray or the area below on which the tray sits on. The cover when pressed seems to be not flush with the door. Is this a problem with the gasket seal between the side door & despenser side cover ? How can I fix it. Please help.. TIA
  • 1 more comment
  • bigben1966 Oct 14, 2008
    It is comming out from the bottom of the rectangular SS trim which frames the water/ice dispenser. Not sure if it is a leak, as it is so slow and the color is milky/sticky like mixed with glue.. Thought it might be condensation. How do I remove this SS trim?
  • bigben1966 Oct 19, 2008
    Thanks for your help, for some reason it is fine now.
  • Rosendo Madero
    Rosendo Madero May 11, 2010
    need more info to help but it seems like the water is leaking thorugh door and it might create rust if not taken care of asap
Under the trim there are 2 openings on on each side insert a flat head screw driver and twist so it will unlock and then it will be off hopefully you dont have to remove all insternal parts inside dispencer i will try one tomorrow at work and let you know
Posted on Oct 15, 2008
Dark particles all over clothes once washed. I cleaned the washer, ran a tide washer cleaner through, checked and cleaned the screen filters that hot and cold hoses pump water through. Is there anything...
sounds like you may need to check your hot water heater for deterioration. since you have done all that you need to check your water supply. a water heater can deteriorate on the inside for a time before you will notice it. good luck
Sep 06, 2011 | GE Profile WPRE6100G Top Load Washer
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
2 yr old spayed approx 60ml of windex over the
The windex may have seeped up into the screen. It should dry in a few weeks.
Oct 03, 2009 | Joy Toshiba M105 S3002 Notebook
GE Side by Side Refrigerator seeping water onto door
Hey, thanks for the photos. Have seen this problem before. Seal the recess area, at the front edge and the front corners, with a little clear silicone, to prevent water from getting behind the stainless steel door panel. I've heard people say to seal the rectangular holes along the bottom side of the door panel recess cut out also, but that shouldn't be necessary, as if you still had water behind the panel, it would just then seep down behind the SS door panel and continue to cause problems. The real cure is to keep water from getting in there in the first place.
May 03, 2009 | GE GSS25QSTSS Stainless Steel
GE Profile Side By Side leaking water on to floor
there must be a hole in the lower back of the freezer compartment that carries the water to the drip pan when the fridge goes through the defrost cycle. Water on the floor means that hole is plugged and the water seeps through the doors. See the owner's manual - it will describe this issue. The fix is to have the blockage removed by squirting a solution of hot water and baking sode with a turkey baster or a similar injector.
Mar 13, 2009 | GE Profile PSI23NCR Side by Side...
Power is on but nothing is working, not cold ,no water, no ice
Sounds like the unit needs a reset of sorts, Get your food into another refrigerator or ice chests and unplug the unit. let it stand open for several hours (just in case the vents are iced) and then plug it back in.
Jan 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Front Load washer problem
replace the water inlet valve it is seeping water through the valve even though the cycle has finished
Apr 28, 2008 | GE WSXH208A Front Load Washer
GE (PSS26MSRSS) Side by Side Refrigerator Logo
392 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
