Need an instruction manual for a black & decker P1400AB inverter
SOURCE: Describe your Black &
I have a black and decker 100 watt power inverter. When the led turns red you are ethier overloading it or it overheated. to fix it unplug it and let it sit for 5 minutes. Plug it in. Plug in an item rated for 100 watts or less. Or try to charge somthing on the usb port.
SOURCE: Black & Decker P1400AB fuse change
lift the two side of the sticker of the power button and indicator lights to unscrew the two tiny screws to remove the top black plastic bracket of the inverter. next unscrew all the side 4 corners and remove the soldered wire from the outlet then u can easily slide out the pcb parts of the inverter. hope that would help you.
