Question about KitchenAid KGST307 Gas Kitchen Range
Model YKGRT607HS4 KitchenAid Gas Range Oven Door Glass Needs To be Replaced.
Need technical drawings. Have taken door apart but can not put back together!!
  • 833 Answers
SOURCE: KESC307 Oven Door
Hi Mcrae...
Generally, the procedure is a straightforward mechanical one.
First, check below the door for screws and remove them. Next, open the door and find the screws on the side and inside of the door. Remove them. Careful...when the door panel comes off, the door will be much lighter and will slam closed if not restrained. The panel should 'fall away' from the door. Have someone assist you here! At each stage, take a digital picture of the disassembly so you can assist yourself in putting it back. Clean the glass with a blue cleaner and buff out. Use a scrubby or very fine steel wool to gently remove any stains from the old glass you're reusing. Do this on a bedding of newspaper. Always handle glass by the edges.
When installing the glass, it should generally be apparent which way it goes in. Some glasses have patterns on them which correspond to the door opening...if it is the outer which is being replaced. Note them. There may be an up or down as as a result. Any foils or patterns are positioned to the direction you won't have access to later.
You'll likely need a second pair of hands to put it all back together. Take your time. Don't force anything. Tighten screws evenly.
Posted on Dec 03, 2007
reg501
  • 413 Answers
SOURCE: How to replace inside glass on KitchenAid KERC608 Type 30P Range
Open the door fully and with a small screw driver, look closely at the hinge area on the oven cavity. There you will see a small lever that will rotate down and lock the door in place. Once in the lock position, begin closing door, you will feel the door 'catch' then lift the door off of the oven.
Posted on Jun 16, 2008
SOURCE: Kitchen aid double convection oven - glass needs cleaning!
Had to remove the screws on the BOTTOM of the outside door, then panel came off after all the screws (inside oven door included) were off...
Reversed the order to put back on.. Cleaned (all) three glass pieces nicely... Now after reading the problems with the self cleaning part (doors getting stuck!) - I'm afraid to try mine!
Posted on Jan 22, 2010
  • 254 Answers
SOURCE: Interior door glass cracked on my KitchenAid oven
thers the inner most glass then some inner glass packs then the outer determine waht u need take ur model and go to sears.com go to there parts direct or parts research link lookup ur model find the part number and a normal price ........anyways u are gonna have to take the door off and replace it, kinda hard to describr just have to get acesss inside and replace the glass... might need service might be cheaper if u have a local repair shop for u to take the door off and bring it in to them... to get that dooor off most have lil flappers or metal locks open the door fully inspect down by the hinge pulll those flappers back towards glass then move door to brooil position 3/4 way closed and lift striaght up... hope this helps reply or rate me if posible k thanks
Posted on Jan 28, 2010
heatman101
  • 43501 Answers
SOURCE: KitchenAid KGRT607 - Oven won't light reliably, can smell gas.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on May 15, 2010
On whirlpool microwave mh6141xkq-1. How does one clean between the glasses? Do you have to take off the microwave door? Thanks Martin Vacca
Martin,
Coming from someone that has dismantled many different microwaves, taking apart a door from your microwave would not be an easy task. There are usually many small plastic tabs that hold different components of the door together and usually several of those will break off when trying to take the door apart. The door is also designed to keep the microwave radiation from coming out the front and if you did not get it put back together correctly, you could expose yourself to that radiation. If it is a problem for you to have the glass dirty, I would recommend taking it to someone professional to have the door taken apart so that they can check afterward to make sure there is no radiation leakage. Hope this helps!
Aug 02, 2015 | Whirlpool Microwave Ovens
How can i clean the glass between my oven door,i noticed streaks and it makes the oven look dirty
Whirlpool door are a bit difficult to remove from the stove. the owners manual may tell you what you need to do to remove it. Once you have it off then the door can be taken apart by removing tye screws that hold it together. This should be done on a flat surface and taking a lot of care. Remember how it comes apart and reverse the procedure when putting it back together. If you break a glass they are expensive to replace if available.
May 30, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Replace inner door glass in a Maytag CWE900 built-in oven?
There is a poor diagram on Searspartsdirect.com, but no instructions. A diagram might help.
Feb 18, 2015 | Maytag Microwave Ovens
I would like a wiring diagram for a Merc 190E right-hand front door window
Hi,if its that you have taken it apart and forgot how to put it back together,if so,take the opposit door card off and copy it.
have a good day.
Jan 04, 2015 | Mercedes-Benz 190-Class Cars & Trucks
OVEN GLASS INSTALLATION
MODEL #TES356TD SERIAL RWO0415338 ESTATE
Jan 17, 2014 | KitchenAid KDRP407HSS Dual Fuel (Electric...
We put our KitchenAid oven onto self cleaning mode, now the display is blank and the door will not unlock. It has been over 15 hours, and the oven is cool. How do we reset it?
Is this a built in wall oven or a freestanding oven/range combo?
If its a wall oven the problem is going to be a high limit thermostat that went out. If it is a older model the high limit t-stat has a red reset button that can be pushed and power will be restored to controls. If it is newer once the high limit goes out it needs to be replaced. Now heres the tricky part on wall ovens, the high limit thermostat is inside control panel and it needs to be taken apart to get to that t-stat and that can be a problem trying to get it pulled out enough to get to control panel with the door being able to open. On that i wish you luck
Thier is also a high limit on the freestanding range its going to behind the back panel and easier to get it since your not dealing with something built into a cabinet
Good Luck,
Gene
Aug 18, 2011 | KitchenAid Ovens
I need help trying to put this bassinet back together i need instructions
i got a bassinet given to me and it was taken apart and washed and now i cant get it back together and dont no what kind it is
Oct 17, 2010 | Delta Enterprise Snoopy Deluxe Crib
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
KitchenAid KGST307 Gas Kitchen Range Logo
181 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
