Question about Bernina Virtuosa 160
When the needle comes down and enters thestitch plate, the needle strikes the hook or hook race cover and bends to the left. When I was sewing, the locking lever that holds the hook race cover in place vvibrated loose and the hook and race fell out. When I put everyting back and snapped it in place, it is like the timing of the needle position and the roatation of the hook are not in sinc any more. Can this be fixed?
Thanks, but I took it in for an overhaul. He said the timing was off. I had it cleaned and repaired.
Posted on Oct 15, 2008
How do I set the timing
You don't give the make and model number, so I will just give you the quick and dirty answer.
Before you begin, make sure you have the correct needle size for your machine.
1. take off the presser foot,
2. take out the plates that cover the bobbin case/race
3. determine where the hook is.
4. using hand wheel, turn it so the needle is at it's lowest point
5. The hook should be just at the needle while it's at the lowest point.
6. loosen and adjust the hook so it is right there. So as the needle starts too go up again the hook catches the loop that is formed.
7. Tighten it down again. And attempt to sew.
Good luck
Sep 14, 2014 | Sewing Machines
Needles break when embroidery carraige moves to sew new area
Check your needle for burrs or bends. If your needle is bent it will hit the plate. Try changing the needle
Mar 19, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
Singer 2263 instruction manual does not show where to lubricate or how to adjust the hook which keep jamming
First make sure that the needle is fully up. Then you need to open the hinged front cover and unscrew the needle plate screws. Remove the bobbin. Brush out any lint now. Remove the bobbin case. Then snap the hook retaining arms outwards. Remove the hook cover and hook. Put no more than 2 drops of sewing machine oil on the the case (center right hand side). Then turn the hand wheel until the hook race is in the left position. Replace the hook and then the hook cover. Snap the hook retaining arms back into position. Replace the bobbin case and bobbin. Then replace the stitch plate.
Test the machine on a piece of waste fabric. If the hook keeps jamming, take the machine in for maintenance. The parts that may need to be replaced are the race or the shuttle hook. However without seeing the unit I do not know if there is not another problem. Some parts for the 2263 are available here: http://www.sewingpartsonline.com/singer-2263-sewing-machine-parts.aspx .
Singer has a second manual available with the oiling instructions for the 2263 here: http://www.singerco.com/uploads/download/1213_oiling-2263.pdf . See the diagrams on this page for where things line up. The rest of the instruction manual is also online here: http://www.singerco.com/uploads/download/1180_2263%28eng_spa_fre%29.pdf .
I hope this helps.
Oct 08, 2011 | Singer 2263 Mechanical Sewing Machine
Needle is getting caught in hook. i scarred the hook after sewing over a pin and breaking the pin below the plate. I removed the bobbin and race cover and the hook to discover the big scar on the hook. I...
If the plastic on the hook has been scarred / burred by a needle break, it is best to replace the hoo - they're not that expensive on this model and can certainly be purchased on-line. You can polish out some marks using very fine emery paper (>1200 grit), but if there are any deep grooves/holes in the plastic, the thread can get caught when its moving around the hook during sewing and it'll cause inconsistent stitch formation or broken threads. If the needle is still hitting the hook when rotating the handwheel, it could be that the hook driver has skipped a few teeth on the gear wheel when the pin got broken, in which case the machine's timing/synchronisation will have been affected and the only solution is to have it readjusted by a Bernina Service Agent - it's not something you can do yourself without the correct tools.
Aug 20, 2011 | Bernina Activa 140
While sewing, the needle suddenly hit the side of the foot-plate which bend the needle, but now the entire machanism is stuck and won't move up or down. How can I fix it and what is the cause of the...
hi there
1- how old your machine ? please check needle par play left and right or no? maybe lower needle bar bushing need to change.
2- maybe ur presser foot played need to change it but check firist.
3- sometimes when needle is broken there is small metal goes insaide the hook and make it dosn't move up or down, if you can adjust timing for hook please remove the hook and check your machine by hand move or not?
4- maybe some thread goes insaide the finger ( stopper for hook ) check this earia .
Best regards
ashraf abozid
aabozid@hotmail.com
Aug 28, 2010 | Sewing Machines
Sewing machine arm wont come down
You need to remove bobbin case and turn hand wheel backwards and forwards by hand till needle comes up and remove race hook cover and hook....remove all thread remands.. and reassemble.
Apr 01, 2009 | Singer 3116 Simple
My brother PE-400 sewing quit sewing
The "race" on your machine needs adjusting. Remove the bobbin cover, bobbin, & case. What you have left is the race, it moves when you turn the large wheel on the top right of machine. The needle also moves up and down. There is a hook on the race that catches the needle thread. Try moving the race to the line up with the needle. It may take a couple of trys but it should do the trick. Also clean any threads that may be caught on or arround the race. Hope this helps!
Jan 02, 2009 | Brother Disney PE-400D Computerized Sewing...
Needle hitting bobbin plate
Is the needle inserted correctly with the flat side at the rear and fully up into the holder ?
If yes, take off the needleplate, remove bobbin case and slowly rotate the handwheel towards you watching the relationship between needle, and the "hook" of the moving "race".
Set on wide zig zag........when the needle is fractionally past it's lowest point, and starting to rise, the hook should be level with the left side of the needle when on the right hand stitch of the zig...the eye of the needle will be below the hook, and ready for thread to be picked up for the stitch to form.
Any other result will mean your timing needs adjusting.
Feb 09, 2008 | Singer 7422
Singer 7442 - Needle hitting bottom
FIRST DETERMIN NEEDLE BAR POSITION TURN STITCH REGULATOR TO LARGEST STITCH, THEN TURN HAND WHEEL TIL' NEEDLE IS ABOUT TO ENTER NEEDLE PLATE.
AT THIS POINT THE FEED DOGS SHOULD BE JUST AT OR JUST UNDER PLATE. IF SO NEEDLE BAR IS, IN CORRECT POSITION,AND TIMING WILL BE SET AT THE HOOK.
TO SET TIME REMOVE NEEDLE PLATE TURN HAND WHEEL SO NEEDLE IS IN LOWEST POSITION. USING A SMALL RULE RAISE NEEDLE BAR 3/32 OF AN INCH ( OR 3 MM FOR A METRIC RULE) .HOOK POINT SHOULD BE IN CENTER OF NEEDLES WIDTH. LOOSEN THE 2 SHAFT SCREWS
SLIGHTLY,TURN HOOK TIL CENTER OF NEEDLE. TIGHTEN SCREWS. IF NEEDLE BAR IS OUT OF TIME. BRING HOOK TO CENTER OF NEEDLE AND LOOSEN SCREW IN LEFT COVER. RAISE OR LOWER NEEDLE BAR TO SET 3/32OF AN INCH. THE 3/32 MUST BE VERY VERY CLOSE.
Nov 26, 2007 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
301 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
