Question about Maytag Neptune MAH5500B Front Load Washer
Washer does not drain
Help! My Maytag Neptune front loading washer is not draining - I have checked the lines and all is well there. The display shows"nd".
  • Maytag Master
  • 19,396 Answers
ND error means no drain. When this happens it is usually a problem with the drain pump assembly, located under the bottom panel, inside the machine.
check the drain hose and the drain lines, ensure they are not obstructed. Probably the drain pump need replacement.
Posted on Oct 12, 2008
Neptune 5500bww isnt draining has new drain pump now power going to new drain pump everything else seems to be working fine
You need to check the drain lines to make sure that they are clear. Don't forget to check the discharge line that it is clear as well. Some units have a filter as well that may need to be cleaned.
Apr 26, 2014 | Maytag Neptune MAH5500B Front Load Washer
What is error code n d on Neptune front load?
Hello & Welcome to FixYa
ND error in your Maytag Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Maytag Neptune MAH5500B Front Load Washer
My washer stopped working and is displaying the code nd, what does this mean?
Kevin
Feb 15, 2011 | Maytag NFW7200TW Front Load Washer
Nd in the display
nd stands for no drain check for a restriction in your drain line and in your pump assembly
May 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer won't drain
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune front load washer displayed ND with 19 left in wash cycle. Door won't open, what can I do?
Not draining,throw rugs tend to clog this unit as do bobby pins and under wires I'm giving you a link to the repair manual it covers the 3000 through 5500 it will help you get the door open and the clothes out so you can start bailing...
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Sep 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old washer....gold....I have had it for...
Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
  1. Boot change helps
  2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
  3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
  4. How to access the console on the mechanical timer models
  5. How to access the workings of the washer
  6. My washer door is locked and it will not open up...HELP
  7. My washer will start when I push the start button, but a few seconds later, it will shut off
  8. My washer will not pump out + pump noise problems
  9. My washer will not spin
  10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
  11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
  12. Problem chart for MAH3000 & 4000 Neptune washers
  13. Readers repair tips
  14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
  15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
  16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
  17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
  18. Washing one item in a front load washer
Apr 01, 2009 | Maytag Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
577 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
