Question about Dell Dimension 4600 PC Desktop
Computer won't turn on unless I unplug the Ethernet Cable
Every time I push the power button on my computer it won't respond. If (after pushing the power button) I unplug the ethernet cable it will start up immediately. Additionally, it will occasionally turn on if I unplug the power cable, plug it back in, and quickly push the power button.
  • 2 more comments
  • EMJeney Oct 12, 2008
    Let me clarify, once I unplug the ethernet cable, I can plug it back in and it will work fine. So, I can still use it, I just have to unplug it (then the computer boots) and put it back in.
  • Anonymous Oct 25, 2008
    I have the same machine and the same problem. It's been this way for at least six months. Starting more recently when I do get it restarted it takes about 30 minutes to load. Not looking to good. I intitally thought it was the Power Supply Unit but I no longer believe that to be the case. With the machine off, a green button will still flash.
  • jaymenator Dec 12, 2008
    I have a Intel DG965WH mobo with integrated nic with the same problem except it won't work at all with the network cable plugged in. I unplug it, power on and all is fine....plug the cable in and it immediately turns off.
    I bought a Linksys gigabit PCI card a month or so ago and things have been fine until yesterday. I now have to unplug the network cable to turn it on then I can plug it back in and it works fine. Really annoying when you find your media center pc can't record tv because windows update had a patch that needed a restart.
    The only other thing I can think of is maybe my workgroup switch is having some power fluctuations and the mobo doesn't like it. I think it's a stretch since my xbox and ps3 havn't had any issue but I'll try swapping out the switch and post my results.
  • Anonymous Mar 30, 2014
    when the power button was pushed the computer would not come on. I unplugged and waited for several minutes then pressed the power button on the tower again and it came on. this is the second time this has happened.. What could cause this problem?
  • Dell Master
  • 4,338 Answers
Is the Ethernet built-in on the system board? I would go to BIOS (hit F2 while booting the PC) and disable the ethernet. then restart the PC. See if it stays on with or without the Ethernet cable plugged in. If it does. The built-in Ethernet circuit is the problem. I would buy a Ethernet adapter ($20).and install it. and leave the built-in ethernet disabled.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 12, 2008
  • JDTec
    JDTec Oct 12, 2008
    What I am saying is that there may be a problem with your PC's built-in Ethernet circuit. And the only way to isolate it is to follow my instructions in the solution I sent.
    Joe
  • JDTec
    JDTec Oct 12, 2008
    Joe
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
Power button not turning computer on
this is most likely a short in a computer component, You need to unplug everything from the computer incl CPU, Memory, Add on Cards, Hdds, the lot, just have motherboard plugged in and push power, if it powers up (there won't be a pic but you will know it's working) start replacing parts one by one until it won't start and that is the faulty part. If it does nothing with just motherboard plugged in the motherboard is at fault and needs to be replaced, If you have had the motherboard out make sure no of the metal mounts in the case are shorting out anywhere under the motherboard as this will also cause the same fault.
Mar 06, 2012 | Acer Aspire Z5600 PC Desktop
Hwr08xc5 won't turn on. Pushed the test button and the reset with no response
TRY UNPLUGGING THE POWER FOR ABOUT 5 MINUTES , IT MAY JUST HAVE A BRAIN FART. THIS WILL REBOOT ITS MASSIVE INTERNAL COMPUTER.. LOL.. HOPE THAT HELPS .. IF SO HIT THE YES BUTTON.. JAY
Jun 23, 2011 | Heating & Cooling
Someone gave me a wireless g router and im not sure how to connect it to my computer and modem?
First, since this router was used by someone else, you'll need to reset it. After you plug the power in, push in the little button on the back (you'll probably have to push it in with a pencil or pen). Hold it in for about 15 seconds until the power light on the front begins to blink.
Now you're ready to hook up the router. The router probably has 5 ethernet ports on the back. The ethernet cable that comes out of the modem goes into the WAN port on the router. This is the one port that is separate from the others. The computer has an ethernet cable that is currently plugged into the modem. Disconnect it from the modem and plug it into one of the 4 remaining ports on the back of the router.
Now the router is in the middle. Modem connected and computer connected.
If you have a cable modem, you'll need to unplug it for about 15 seconds and plug it back in. Trust me on this--you just have to do that. If the cable modem also powers your phone, you'll need to take the battery out of the modem and then put it back in.
Now turn on your computer. You should connect to the internet. If not, the router will need some setup, but unless I know more details, I can't help you. You'll just have to ask again.
Feb 24, 2011 | Computers & Internet
I have a arris tm602 modem, HOW DO I CONFIGURE MY NET GEAR ROUTER FOR INTERNET CONNECTION
Cable modems bond to what they are plugged into, so you have the modem plugged into a computer and it is working fine. Then you want to unplug the ethernet cable from the computer and plug it into another device such as a netgear router. Then you find no matter what you do it will not work.
Now normally to break this bond to the computer so that it will bond with the router you would simply unplug the electrical power from the cable modem, wait for it to sync back up with your ISP's CMTS, power up your router which you would have connected via the internet or wan port, and you would be up and running.
You may have even did this with your Arris TM602. Why isn't your router pulling an IP address? The reason is simple, pulling the power cord did not really remove power since the modem has battery back up.
In order to make it release its bond to your computer, so it can bond with the router you need to either push the reset button on the back of the modem while still powered up or remove its battery pack while unplugged from power.
So try again, this time push reset on the modem. This question was posted in January so I am sure buttercup is all fine by now but maybe this will help someone else.
Jan 08, 2010 | Arris Touchstone 300a (CM300) Modem
DVD Drive door will not always open. No obstructions. DVD Drive light flashes, but door will not open. Is ther some software conflict?
The door drive motor may be frozen.
  1. Shut down the computer and unplug it.
  2. Open the computer casing to access the DVD drive from inside.
  3. Disconnect the cable on the DVD drive leaving only the power supply connected to it.
  4. Turn on the computer.
  5. Push the OPEN/CLOSE button on the DVD drive. If it does not open, the drive is broken or the door drive motor is defective. If it opens, push the button repeatedly to open and close the door repeatedly to release any frozen part.
  6. If the door does not stuck anymore, shut down the computer.
  7. Reconnect the cable and turn on the computer.
Oct 30, 2009 | Sony Computers & Internet
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Linksys reset
You dont need to connect your computer to the router to reset it,, There is a small push button on the router , unplug it and press the push button for one minute with a pen and thats it your done.
BTW the router came with and ethernet cable, connect one end of the cable to your pc and then oter end to the lan port (lan1) on the router. thats how you connect the two
Jul 10, 2008 | Linksys Wireless-G WRTP54G Router
My psp wont charg
If it won't charge and wont power up then same thing happened to me. If you are willing to open up your psp there is a video on youtube that can show you whats wrong. The cable that connects the buttons on the right side most likely disconnected from the main board and the right side of the psp including the buttons, the power switch and the top right trigger won't respond. When you try to turn on the psp and when its charging if the light won't come on then you might have this problem.
May 10, 2008 | Sony PlayStation Portable (PSP) Console
Dell Dimension 4600 PC Desktop Logo
2,704 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
