Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Setting #4 Food is freezing at #4 setting
  • 943 Answers
HI thanks for your question. try # 3 . let it sit at # 3 for at least 24 hrs to settle in with new setting. if still freezes, try # 2 . let settle again. thanks the appliance doc.
Posted on Oct 12, 2008
What can I try next to prevent my food from freezing?
The damper door may be broken. I had this problem in the past and the fresh food was too cold. I replaced the damper assembly and all was fixed.
Nov 10, 2014 | Refrigerators
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Fridge is set at 44 ,freezer is -4 and the food is frozen in the fridge. can't get fridge to stop freezing all the food,what temps do I need to set?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 01, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
The fridgerator keep freezing the food. it is on the lowest setting but still it freezed the food. whirlpool MODEL: ET18NMXAW03 SERIAL: ED3042768 have had someone tell me to clear the food so that it...
heatman101
Jan 25, 2011 | Whirlpool Refrigerators
Fridge side freezes even on setting 3 or 4 - top shelf milk down to lettuce in drawer. What's up?
heatman101
Jan 05, 2011 | Maytag 22.7 Cu. Ft. Side-by-Side...
Refrige freezes lettuce ( set on # 4)
heatman101
Dec 12, 2010 | Whirlpool GD2SHGX Refrigerator
Fridge is to cold when set on 4
heatman101
Aug 04, 2010 | Amana ABB1927DE Bottom Freezer...
Food freezing in refrigerator.
I have a side by side GE Refrigerator only about 4 years old, the setting on the Refrigerator is set at 37 degrees but it continues to go to 20 degrees and freezing my vegtables. Help.
PS - i did vacumn the back filter a week ago with no help.
Jan 27, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Food freezing in the refrigerator side
hi! you already the solution of the food freezing problem.the cause was occurs because the thermostat was not duly calibrated..it recommended for calibration.
Nov 19, 2007 | KitchenAid KSRP22FNSS Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
Top Refrigerators Experts
Gere knutson
KJ4QOB
Stan Ford
