A 20 foot piece of string is cut into to two pieces so that the longer piece is 5 feet longer than twice the shorter piece. If the shorter piece is x feet long, find the lengths of both pieces.
Find out how much shorter one is than the other.
    President:
  • 720 Answers
Using standard Algebra:
Long piece = 15 ft
Short piece = 5 ft
Posted on Jan 13, 2012
Testimonial: "thank you!"
SOURCE:
How to lower my 2011 Harley Davidson FLHTCUI Electra Glide Ultra Classic
smaller rim diameter
special made shorter springs ( have to fit shorter shocky)
talk with bike modifiers for more ideas
Nov 21, 2017 | 2011 Harley Davidson FLHTCU Ultra Classic...
Can I get shorter shock absorbers for my Honda cb 400 super4 as I am short in the leg
There are a few things you can do.
1. Get lower (shorter) rear shocks.
2. Move the forks up an inch or two. Make sure you sure measure and move both the same.
3. Get shorter springs for the forks (this is the ideal solution but it takes more work and effort to do)
Apr 16, 2017 | Honda Motorcycles
Size of drive belt for HU700F walk-behind mower
belt lengths are printed on the back of the belt
so if it reads as an example 645 that will be the length so if you want one that is 1" shorter then the belt reading will be 644
if it is in mm the 1" shorter will be 25 mm shorter than the printed number
Sep 01, 2016 | Husqvarna HU700FH 22-in Self-Propelled...
Why is the high band wi-fi connection limited?
If you mean the 2.4Ghz Vs. 5Ghz, The 5Ghz is a shorter range system compared to the 2.4Ghz.
Reason is that the higher frequency signal is effected more by objects in it's path. Also higher frequencies have a shorter range just due to it's shorter wavelength.
Hope this helps.
May 10, 2015 | Zyxel 122976 - Wireless Router NBG-5715...
Increase height of pulsar 150
Hi, Anonymous here are some options for lowering your bike depending on your needs and wallet:
1. Rear shock lowering kit.
2. Front fork lowering kit.
3. Shorter rear shocks.
4. Shorter front forks.
5. Thinner padded seat.
6. Lower profile tires.
Please be aware that some of these options or a combination of options will require a shorter kickstand or your stock one modified. For more information about your issue, please visit the websites below. Good luck and have a nice day.
http://88.198.249.35/d/Pulsar-150-Workshop-Manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 20, 2014 | Bajaj Pulsar 150 Motorcycles
Can you bypass the ac compressor on a 2003 envoy with a shorter belt?
Yes, it wont hurt anything by installing a shorter belt and eliminating the AC compressor from the loop
Jan 09, 2014 | Cars & Trucks
Lowering the bike
DOWNLOAD 2004 Aprilia Rst 1000 Futura
Nov 24, 2013 | 2004 Aprilia RST 1000 Futura
Seat height i need to lower 1995 suzuki rm250
Hi Mike, here are some options for lowering your bike depending on your needs and wallet:
Suzuki Motorcycle Suspension
Dec 24, 2012 | Motorcycles
Bypass ac compressor 2006 saturn vue
I doubt it but I would have to see it in person to say for sure.
If nothing is in the way between the pulley before and the pulley after the compressor, you could use a shorter belt. How much shorter would be something you would have to try to measure.
On the rare occasions when a vehicle comes without ac, the factory puts a dummy pulley in the place of the compressor. I think all Saturn Vue cars had ac.
You say the compressor won't turn, but you really mean the clutch on the compressor ??
Jul 27, 2012 | Cars & Trucks
Plank of wood 2 metres long. cut into two lenghts. longer piece is four times the lenght of shorter piece. how long is each lenght?
It is solved by writing an equation
If the shorter piece is y cm, then the the longer piece would be 4y which is four times the shorter length. The total of these 2 together is 2meters or 200 cm, Now write the equation (2 pieces together is 200cm)
y + 4y = 200
5y =200
y =40
Since we have taken the lengh of shorter piece as y,
Shorter piece=40 cm OR 0.4m
Longer piece =160cm OR 1.6m
I have written the steps in detail for you to understand the process
Good luck
luciana44
Longer piece= 160cm
Feb 28, 2010 | Mathsoft StudyWorks! Middle School Deluxe...
Open Questions:
Computers & Internet Logo
107 people viewed this question
Ekse
Alun Cox
