Question about Palm TX Handheld
Crash after Hotsync
I hotsynced and then my palm is powering off and keeps trying to reboot but won't ----- i think it crashed! I tried a soft reset - no luck and then a hard reset - no luck - it was charged before the hotsync. I had a few errors previously during a hotsync that seemed to be problems syncing with the date book. Of course I have Vista on the pc. Any ideas what to do? Is it fried or what? Thanks.
  • sue_sg Jan 19, 2009
    I did a hotsync with my TX on Vista and all the data has gone, calendar, address book, everything. How do I get it back?
  • 2,794 Answers
There were some problems with the hotsync working with Vista. I don't know if they fixed them yet. Best bet is to look on Palm.com and see if the current hotsync program supports Vista.
If it isn't listed, it may not support it.
Posted on Oct 26, 2008
Suddenly it will not take activity by screen. Pressing or drawwing on the screen gives NO results, as if screen is dead. Buttons still work. Just cannot add, change, or access entries. Can the database...
Welcome to Fixya
Sounds like the problem is the LCd screen already. Have you tried doing a hard reset to your palm? The data in your palm can only be transferred using Hotsync. Try uninstall/install the software again to the new computer. May i know the Windows OS of the new computer and what is the model of your Palm.
Thank you for using FIxya!
Sep 06, 2011 | Palm Zire 21 Handheld
On Palm TX Hotsync Manager will not open
check whether the power supply is proper
Jun 21, 2008 | Palm TX Handheld
My computer crashed. I have a backup of all my Palm files but am having trouble recovering them. Does anyone have instructions on how to restore backup files on a Palm Tungsten E2?
Hello.
Palm backups are located in the following directory: C:\Program Files\Palm\username>\ED\Backup\
When you HotSync a PDA that has undergone a hard reset, HotSync will compare the two devices. When it sees that the PDA is empty, it will attempt to reload any backup that exists on the PC. Once this data is reloaded, the PDA will ask to do a soft reset. This is simply a restart of the device and doesn't affect any of the newly installed data. This returns the PDA to working order, with all the data and programs functioning as they were before.
Hope this resolves your problem.
Jan 23, 2011 | Palm Tungsten E2 Handheld
I'm having the same issue with my palm centro that everyone else seems to complain about (trying to HotSynch continuously). With all of these customers experiencing the same issues, surely there should be...
Hello shalen,
Make sure bluetooth is turned off and the usb cable is not connected. Then do the following:
•Tap the hotsync icon
•Notice the words 'Local | Modem' side by side on the screen
•Tap 'Modem'
•Select 'Standard Modem' in drop-down list
•Enter any phone number (eg. 800-525-6452 *this is a non-working number)
•Press the Home button
Now hotsync should stop trying to sync automatically. When you want to run a hotsync Tap on 'Local' in the hotsync screen.
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jan 16, 2010 | Palm Treo 500 Centro
It won't hotsync, it start to than stops when I get to the what should I do I have a tx
Here are a few things to try:
Check that the HotSync icon in showing in the system tray (bottom right hand side of the screen, next to the time).
Check that USB connections are enabled in HotSync - In HotSync V7.0.2, Right click the hotsync icon in the system tray, Click "Settings...". Click "Connections" on the menu on the left hand side and ensure that the USB option is checked.
Try rebooting your PC and also resetting the device (use a paper clip to reset the device).
You could also try reinstalling Palm Desktop, maybe even remove Palm Desktop, reboot, then reinstall Palm Desktop.
Jul 31, 2009 | Palm Computers & Internet
Treo 7550 - Recovery from crash without Palm Desktop Sync
no u must always hotsync every weekend, he will loose his data completly!!
srry
May 11, 2009 | Palm Treo 755p Smartphone
Palm Tx problem after hotsync
I had the same issue, the palm is stuck in a loop,
I got mine out of this by pressing the power button while the palm was on the screen where the bar goes across the bottom, it asked me if I wanted to erase all data, I said yes, and it reboot normally, I went thru the setup, and all is o.k.
I did have to try this several times, but it eventually worked. Hope this helps, although it looks like this is an older question. I hope you have resolved it.
Oct 12, 2008 | Palm TX Handheld
Treo659 reboots constantly
Try a reset first but you more likely a hard reset will take care of this but it will wipe your palm. Anything you have added since your last hotsync will be gone and there is no way to get it back.. After you do the reset the next hotsync should put your info and programs back on.
Jan 04, 2008 | Palm Treo 650 Handheld
MY TREO 650 KEEPS TRYING TO HOTSYNC(and its not connected to computer)
Did it actually reset when you did a hard reset ..or does it stay powered up?
Dec 31, 2007 | Palm Treo 680 Smartphone
USB device not recognized or has malfunctioned on hotsync
Last week, windoze started barking the same complaint at me. A hard reset (of my Tungsten E) solved the problem. Caution: A hard reset (keep the power button pressed while performing a normal reset. Only release power button, when Palm logo screen appears. The press up-key) delete ALL data (even the identity, i.e. hotsync ID) from your palm - so be sure to have a recent backup!
Nov 23, 2006 | Palm Tungsten E Handheld
Palm TX Handheld Logo
102 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
