Question about Cameras
My camera says i have a lens error - Cameras
    Master:
  • 383 Answers
Did u drop it .... and also what make is it
Posted on Oct 12, 2008
Camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
I have a canon Powershot A480. It keeps coming up with the faultLens Error Restart camera. How do I do this
Service & Support Issue: Camera displays "Lens error, restart camera" on the LCD monitor.
Solution: Possible solutions for a Lens Error message PowerShot A480.
The "E18" or "Lens" error message indicates an error that involves the lens unit or lens cover.
This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution
Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area:
  • Hold the camera so that your fingers do not touch the lens unit when you are shooting.
  • Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred. Please click here to set up service for your camera online.
Jul 25, 2010 | Canon PowerShot A480 Digital Camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 14, 2009 | Canon Cameras
Camera felled to floor lens tries but cannot retract camera turns on and off fine, error message "lens error, restart camera" it appears that until lens can function properly and error message is resolved...
Jun 29, 2009 | Canon PowerShot A630 Digital Camera
Jun 28, 2009 | Canon Cameras
Lens error= restart camera - this is the message I am receiveing from my cannon SX110 IS
May 24, 2009 | Canon PowerShot SX110 IS Digital Camera
Lens error
May 02, 2009 | Canon PowerShot A570 IS Digital Camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Apr 16, 2009 | Canon PowerShot SD600 Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Cameras Logo
99 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
