Question about Bosch Vacuums
Bosch terrossa 1700w vacume cleaner make load noise when turn up tp high setting and the motor make a shorting out noise
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: high pitch noise
Most likely it is coming from the motor bearings, you will have to replace the motor.
Posted on Jan 06, 2008
  • 44 Answers
SOURCE: vacum won't ****
Do you have good suction right out of the canister without the hose attached? If so, AND your hose isn't plugged, you must have a pretty good sized hole somewhere in the hose. If you don't have suction at the canister, pull the filter cover off the top-back of the machine and remove the filter. This is where all of the air that the machine pulls in is exhausted. If something is plugged here, it will greatly reduce your suction. If you still haven't found the problem, you could have a problem with the fan assembly on the motor. But usually this is accompanied by some noise from the motor, but not always. Good Luck!!
Posted on Jan 03, 2009
  • 61 Answers
SOURCE: Where is the reset button in the e series Rainbow vacum cleaner?
Wait 12 hours empty unit and restart.
Posted on Apr 15, 2009
  • 175 Answers
SOURCE: Bosch terrossa vaccum cleaner hose won't connect
It may be missing a locking piece on the hose or the body housing. See your dealer for parts.
Posted on Nov 28, 2009
My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Jan 18, 2015 | Hoover Vacuums
Where can I get a repair manual for a bosch powermax 1700w vacuum cleaner?
You won't likely find one anywhere. Bosch pulled the plug on vacuums several years ago. Take it to your local vac repair shop if you need repair. I'm not allowed on here to give you my store info as it's seen as self promotion, but do a search in your area for former Bosch vac dealers and you should be able to find a qualified expert near you.
Jan 08, 2015 | Bosch Vacuums
Loud high pitched noise from Electrolux Vitesse petlover 1700w
We had a vacuum cleaner that did that and it was the signal to say the bag was full. So to test this remove the bag and see if problem goes. If it does- replace the bag.
Dec 28, 2011 | Vacuums
Electrolux Vitesse petlover 1700w loud noise
So all that is left is a blocked filter, ie paper like the ones in a car, remove- wash bash out the dust etc- I use compressed air to blow them oput backwards. If it is bagless there has to be a filter somewhere otherwise everything comes straight out.
I would also be looking at hose obstruction and leaks in the body of the system - assuming it still sucks well enough. I often remove the hose and drop a heavy steel rod or the like down to shake out the hose. I have a lot of this with saw dust on the shed cleaner.
If it were mine I would then pull it apart to look for bockages or bits caught in the fans. But do not do this if you are not confident of reconstruction safely or if there is a warranty available.
Dec 28, 2011 | Electrolux Vacuums
Hi My Electrolux Oxygen Z5530 stopped working from one second to another. No lights - nothing - totally dead. What can I do? Is there any fuse? Sincerely Eva
I have same problem and I check it out.
The special requrement of Electrolux for his vacum cleaner motors is that they working with high reliably approx 800 hours working time and no more!!! (it should stop safe with no danger for users...)
7 years has past (2 h/week x 52 x 7 = 708 working hours) so it is time for us consumers to buy new vacum cleaner...
Jan 05, 2011 | Electrolux Vacuums
POWERMATE HEAD DOESNT SEEM TO HAVE GOOD SUCTION AND IS LOUD
suction wise have you checked the internal pipes on your vacum as for the load noise if it is quite a load noise a humming noise it is ure motor so not worth fixing motors r pricey for a vacum
Feb 03, 2010 | Kenmore Vacuums
Bosch terrossa vaccum cleaner hose won't connect to main body
Nov 28, 2009 | Bosch Vacuums
Fuse auto shut off
Find the current rating for the vacuum cleaner motor (on a plate somewhere on the machine). Is it somewhat less than the breaker rating in the panel? If so, then either the motor is overloading the breaker due to bad bearings or a shorted winding in the motor or the breaker is failing. Check the current draw of the running motor with a clamp-on ammeter (a friend with one or an electrician). It should be close to the rating on the plate. If in excess, then the motor needs to be repaired or replaced. The motor normally works harder when it is pulling full vacuum--it speeds up if the air flow is plugged.
Sep 08, 2009 | Hoover S5620 Vacuum
Electrolux vitesse pet lover 1700w. Keeps cutting out and electrical sparks in front vent
Hi there SmartAlec from NelsonVacuums.com.au here. I am sorry to be the bearer of bad news but if you can visibly see sparks and its cutting out then i would say that the motor brushes are nearly worn out. On this particular vacuum cleaner they are not sold as a spare part so i think it would need to go to a repair center for a new motor or to vacuum heaven for a replacement.
Regards Alec
Aug 23, 2009 | Electrolux Vacuums
I want dismont the rainbow vacum cliner to see the engine
Finaly, I find the screws and I desmont the vacum cleaner. Afther that I find in short circuit the rotor of the motor. Now I must fix the rotor.
That it.
Thankyou very much.
Leon NICA
Jan 10, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
181 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
Billy Detlefsen
ray gallant
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
