Question about Kenmore 24902 Top Load Washer
Just a trickle of water during rinse cycle
I have a 90 series top loading kenmore washer. The water flows fine during wash cycle, but there is only a trickle of water during rinse cycle on any water temp.
  • Anonymous Mar 14, 2014
    wont change cycles, and just trickles the water in.
  • Anonymous Mar 15, 2014
    water trickles during rinse cycle
  • Kenmore Master
  • 5,568 Answers
You write that the water flows fine during the wash cycle; if you mean while the machine is washing, then it is the pump  making the water flow. You need to watch the water flow while filling for any cycle since it could be slow filling and not running.
Since the same valve(s) control the water intake during washing and rinsing, what you describe doesn't make sense. I suggest your remove both ends of both hoses and inspect them and the mating connectors on the machine for clogged screens.
If these are clear of any sediment, then the flow control valve is failing. This is located on the rear of the machine and the screw connections for your hoses are part of the valve body. This assembly is pretty easy to remove and replace, is a common and not very expensive failure.
If you are in the US, check to see if you have a Johnstone Supply in your area. They sell mostly wholesale to tradesmen but have never turned a private sale away and are far less expensive than dealers with pricing ranging from 30-50% of dealer price.
Posted on Oct 12, 2008
  • 943 Answers
HI thanks for your question. the cold water valve either has a clogged screen or a faulty water valve. remove the cold water hose and clean out the screen, try again. could be all you have to do. if its acting the same. replace the water valve. thanks the appliance doc. please rate my answer. thanks.
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Hot water just trickles in both of my Kenmore top loader washers
Try reversing hot for cold hoses and see what happens. That will test your valves, hot water pressure, etc. As far as I know, the valve screens are right where the hoses hook up.
Apr 30, 2009 | Kenmore 22422 Top Load Washer
Cold water in the rinse cycle of the washer just trickles
Sounds like cold water solenoid is not opening all the way, its easy to replace, and is found inside the wash machine where the hose connects
Apr 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Kenmore 90 Series fills so slow on rinse cycle
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside where you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 09, 2009 | Kenmore 15944 Top Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
Washer fills slow only in the rinse cycle
ck and clean screens first both sides be sure hoses are not reversed timer has no affect on fill rate if screens are clean replace valve
Sep 19, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24902 Top Load Washer Logo
232 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
