Question about Cameras
Panasonic Lumix FX-01 lens bent to the side
My Panasonic camera turned on by accident (because it's too easy to hit the On switch), and somehow I the lens extended and bent to the side - very tightly. Panasonic wants too much to repair it and I wanted to see if you have any ideas to DIY fix it.
Or would the optics be too messed up?
Thanks!
  • fixtitmyself Oct 12, 2008
    Not currently. It's at Panasonic and they're going to ship it back.
    The lens is pushed to the side at an angle. Thanks for asking!
    Master:
  • 383 Answers
Can u somehow upload the pic of the camera condition ......
Posted on Oct 12, 2008
  • Parshiv Luthra Oct 12, 2008
    kindly upload the pic before i can comment
My camera lens isn't working, how can I reset it?
it sounds like there is dirt, dust or something else in the lens mechanism. I'm assuming you don't want to take the camera to a repair shop. I've had several cameras and this issue comes up periodically.
You can try:
1. using compressed air (with as thin a nozzle as you can find) to blow out the dust,
2. try powering on the camera and zooming the lens at the same time, 3. gently knocking the camera on a hard surface to loosen the lens mechanism,
4. manually forcing the lens to go back in. This can potentially damage the camera, but it's not working now, so you don't have a lot to lose.
5. Googling the camera model to see if you can find instructions on opening the camera up to clean the lens mechanism.
Oct 09, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic FX-01 Lens zoom ring (around shutter release) loose on
must to open ur camera and completly open that lense and clean well all gears then fix it back it will work
Jul 11, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic DMC-TZ3 Damaged lens rings
i think the colours have gone behind the screen can it be repaired lumix tz7
Jun 20, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic dmc fx-10 digital camera -
The lens may be broken(barrel)replacing kost you about 175,00 euro
May 11, 2009 | Panasonic Lumix DMC-FX10 Digital Camera
Lense stuck out and can't take pictures
In all probabilities, the lens barrel must have tilted, preventing the lens from retracting into the barrel. It could also be possible that some dust particles got stuck in between the segments of the lens barrel. Check for these. Try to straighten the barrel without using much force, and try to remove any dust particle that got stuck between the segments.
Jan 14, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Lumix lens retracts and extends
Belikes, any external object is trapped in between your Lens Motor and Camera Body. You should consult Authorized Service Personnel to handle this trouble.
Jul 28, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Paansonic FX-01
u don't touch CCD contact near service center this is simple repairable
Mar 25, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
DMC-FX8
If the lens is jammed in the out position you can try holding the camera firmly and tapping/hitting it against your hand with the camera on. The lens should then retract. If this doesn't work or if you are afraid of dropping it (do it on your bed, that way it doesn't hit the floor if you _do_ drop it), you can drop it on a wood/firm surface from an inch or so up and it should retract the lens. This solution ONLY WORKS IF THE LENS IS JAMMED.
Sep 30, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
Cameras Logo
75 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
