Question about Toshiba 57H82 57" Rear Projection Television
Won't turn on. No click, no power light, nothing.
Won't turn on. Suspect lightning strike but TV cable and 110 power both surge protected. Is there a possible simple fix with fuse or circuit breaker, or other?
  • Steve33G Oct 12, 2008
    Have confirmed I need to check fuse. Where do I find it on my set?
    Amazing response time! Thanks for providing the help I needed.
    Master:
  • 505 Answers
1. Try a different wall outlet
2. Open the back panel of the TV. Replace the fuse and will resolve the issue.
As you have mentioned that a lighning has struck so there is a possibility that the picture tube may get damaged. If that is the case in that case it will be repaired by your vendor or you can contact Bestbuy for the same. They have the option of sending a technician at your place.
Thanks.
Posted on Oct 12, 2008
    Genius:
  • 1,011 Answers
Dear,
check its fuse first..yes, the basic thing is fuse..if its ok then we will do further..
regards,
  • SALMAN NASEER Oct 12, 2008
    dear,
    moreover, check the availibility of mains (volts). is it present there. check the breaker too.
    because, if all are fine and mains are at the switch but still the tv is not turning on then its internal fault.. but confirm the outer section as mensioned above..
    regards,
Sanyo tv won't turn on after a lightning strike.
Ask friend if broken when given to you. If not I would suspect the power supply is fubar..
Sep 16, 2017 | Sanyo Televison & Video
When and How Should a Surge Protector Be Used on a Fixed Switch?
Common Causes of Lightning Strikes
  • Outdoor network cables or power cables are routed overhead.
  • A switch is deployed outdoors but is not properly grounded.
Damages of Lightning Strikes
  • If power cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn the power supplies.
  • If network cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn interfaces of the switch.
When a switch undergoes lightning strikes, overvoltage is induced by lightning on network cables and transmitted to interior of the chassis. The surge protection measures, such as lightning rod and chassis grounding cannot prevent the damage. Therefore, surge protectors or surge protection circuits are recommended.
Surge Protector Use Precautions Take the following precautions to protect a switch from lightning:
  • Ensure that the ground cable is connected to a ground bar or a ground point on the cabinet.
  • Avoid routing cables overhead in an outdoor environment. Bury cables underground or route them in steel tubes.
  • To protect network interfaces against lightning, use 8-line surge protectors (or Huawei certified 4-line surge protectors).
  • When installing a network interface surge protector, connect the IN end to terminals and the OUT end to network interfaces of the switch.
If a fixed switch is installed in a network box, follow these instructions:
  • Connect the ground cables of the switch and surge protectors to the ground bar in the network box.
  • The maximum length of a ground cable cannot exceed 40 cm, and a length of smaller than 15 cm is recommended.
  • If the network box is located outdoors and power cables are routed aerially over a long distance (more than 300 m) to the network box, it is recommended that you install a power supply surge protector in the network box. The decoupled power cable must be at least 3 m long
S2300 Switch Thunder link com
Dec 08, 2016 | Office Equipment & Supplies
MY SANYO LCD TV MODEL 24 K 50 WAS OFF WHEN LIGHTNING STRUCK NEAR OUR HOUSE AND SINCE THEN IT DOES NOT TURN ON
Replace or have the powrer supply tested and eventually serviced.
Lightning strikes affect two types of boards in televisions - the power supply by means of entering through the AC line and main boards by means of entering from the external signal sources. External antennas are worst and can totally toast the main board whereas a signal entering through HDMI cable from another device is less likely to be affected by a power surge.
So naturally you start your quest with the power board , which is the usual suspect.
As of right now I do not believe we have an announced service for the power supply board of Sanyo LCD-24K50, but if you do not have any other options you can always try and send the power board for examination/repair through
http://www.coppelltvrepair.com/newservice.
Sep 29, 2013 | Sanyo 42 in. LCD TV
Our electricity went out for a few minutes, and since then the TV will not turn on. The green light is flashing. We tried resetting it by pushing a pen point into the reset hole, but it does nothing. ...
Your power outage may have been caused by a nearby lightning strike, or any number of
1000 different reasons that cause power surges, brown-outs, voltage spikes, inductive loading,
and/or utility pole breaker trips and resets (this accounts for your power loss (a pole breaker trip),
followed by restoration of power (the pole breaker automatically reset) - even plain old high electrical demand causing an overload due to air conditioning demands caused by hot weather.
When the pole breaker reset, your TV caught a power surge.
Whenever a power outage occurs, quickly power off (or better, unplug) any/all computers, TVs,
etc. that are not protected by surge-protection.
As an electrician, when someone loses an item of electronics concommitant to an electrical
anomaly, its almost
always traceable to a nearby lightning strike (or the power company provided equivalent), accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360/Nintendo Wii.
Surge protection can
be provided by the consumer at the power strip (a good one with builtin MOV protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house surge protection where a whole-house MOV-based (metal oxide varistor) surge protector, or per-circuit protection can be installed with
a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed and/or fuse blown), other than renters insurance or homeowners insurance.
Your only real hope for an economical fix is to look for a blown fuse, and replace it.
If desperate to attempt a fix on your own, you could try replacing the entire TV power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
Sep 05, 2011 | Mitsubishi WS-55511 55" Rear Projection...
We had a thunderstorm with lightening in the area. The LG was plugged in at the time, but NOT turned on. after the storm, the tv will not turn on. the little green button turns from red to green...
As an electrician, when someone loses more than 1 item of electronics in a day, its almost
always traceable to a nearby lightning strike, accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360. Surge protection can
be provided by the consumer at the power strip (a good one with builtin protection and a
Your electrician can provide whole-house protection, or per-circuit protection at
the breaker box, where a GFCI breaker (or better, an AFCI breaker) can be installed.
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed), other than renters insurance or homeowners insurance.
The converter box may be replaced by DirecTV, you'd have to contact their customer
service at http://www.directv.com/DTVAPP/content/customerservice
If desperate, you could try replacing the entire TV power supply as a module, but even this provides
Aug 17, 2011 | LG Televison & Video
Both of my tv's died yesterday. My apex wont turn on anymore an the panasonic has no picture. Whats wrong.
As an electrician, when someone loses more then 1 item of electronics in 1 day, its almost
always traceable to a nearby lightning strike, accompanied by a lack of surge protection for
If desperate, you could try replacing the entire power supply as a module, but even this provides
Aug 15, 2011 | RCA F36450 36" TV
AOC Envision L32w761 TV. Lightning strike. Now nothing. Power light won't come on. Checked power to the Power Supply board and have it fine. Replaced TV and everything in the system looks OK. Bad TV...
If you are certain you have a lightning surge, almost anything can take down your TV. First check the obvious, do you have power coming out of the wall. Is the surge protector good, if you used one? If you have answered yes to the these questions, you may have acquired a power surge in your TV. You may not find it in your TV. As I have said it may be anywhere in the TV. You will need to take this TV to an authorized service center. It would be difficult for anyone out side a technician to find the problem. Thanks for asking and show all hands of support!
Jun 18, 2011 | Televison & Video
27r410t no power
did you check that you are receiving a good hot (a consistent 110 ac) check the tv on a different outlet otherwise the chassis board has malfunctioned inside the tv. Probaly the flyback transformer which converts the 110 ac to thousands of volts to power the CRT (picture tube) which has failed more than likely. Usually the culprit after sustaining a surge from a lightning strike. Not worth the repair just replace go to your local pawn shop for a great deal on another used tv
Aug 15, 2009 | RCA F27664 27" TV
Killed by lightning, have power, no picture...
The warranty does not cover lightning, check if your insurance covers it.
A lightning strike on such panel ( HDMI ) is very difficult to repair and if not impossible.The HDMI connector is hooked to the ground of the TV set so everything could be damaged.
My advice is not to repair.
Aug 10, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Tv hooked to cable system and next door neighbor had a lightening strike. After that, the tv does not work any longer--no power light at all.!
Your TV got fried when the lightning struck. Time to get another one.
This time be sure you plug it into a surge protector power bar, available at radio shack, walmart, any TV or computer store.
Jun 15, 2009 | Insignia NS-LCD22-09 LCD HDTV
Toshiba 57H82 57" Rear Projection Television Logo
103 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
