Question about Jandy LAARS LX250 - PROPANE, DIGITAL READ-OUT, LOW NOX
High limit my heater is flashing a high limit
  • 125 Answers
That means you need to replace the high limit assembly
Posted on Mar 04, 2009
Jandy Lars LT fans doe not turn on and error flashes hi limit
check safety circuit and see if high limits are corroded also see if fusible links are tripped
Nov 27, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I have a 75000 kerosine heater that only runs a few min and shuts off and the led has a steady flash, (high limit switch open circut)
Jump the 2 yellow wires together if it stays running replace high limit switch under hood against the chamber
Feb 18, 2013 | Mr. Heater MH75KT
Four flashes open high limit explain
Blower is probably bad. Dirty filter or not enough air flow
Nov 17, 2012 | Emerson Furnace Control Board Lh33wp001...
GMP125-5 four flashes replaced high limit and board. when powered up the blower comes on even with the T-SAT in off position.still getting four flashes from new board
when a high limit opens it tells the board that there is to much heat. The board shuts down the gas valve and turns on the blower. Find the limit that is open, sometimes you can reset them but most of the time you replace it. When you either change it or reset it, after power down then up, it should go back to normal.
Oct 06, 2011 | Goodman GMS90703BXA Heater
Service indicator light flashes 4 times. High limit switch?
There should be a diagnostic chart on the reverse side of the front panel. If in fact it is a high limit issue, check your air, condensate hoses and blockage of return air from the ductwork.
Jan 08, 2011 | Goodman Heating & Cooling
Heater code is flashing HLS Open What do I need to do?
The high limit switch either needs to be rest or replaced...the heater got too hot and tripped the high limit open...
heatman101
Jan 06, 2011 | Mr. Heater MH125KT Utility
My furnace blows cold air constantly even in heat mode. It's led light flashes 4 times in a set, what could it be?
On Goodman furnaces, 4 flashes usually means open high limit. Look for any burnt or loose wires or any resettable limits, they should have a red button that clicks when you push on it and wire going in and out of it with spade clips. If the open limit is not resettable, jump it out to verify its open and if that fixes the problem, replace the defective limit. Best of luck.
Mar 18, 2010 | Goodman GDS80703ANA Open Flame Mid-Size...
Heater Code is flashing HLS open What is this?
High Limit Switch, look for a bimetal disc somewhere near the elements and apparently this is a manual reset. Should be red button in between two wires on a flat round disc.
Always turn power off when attempting electrical
Feb 15, 2010 | Mr. Heater MH125KT Utility
Electronic ignition is not working on my goodman heater
it means the high limit switch is staying open , it is there to keep the unit from over heating. it have went bad , it is the small square peice with two wires going to it on the heat exchanger could be black or brown
Nov 11, 2008 | Goodman GMS90703BXA Heater
Jandy LAARS LX250 - PROPANE, DIGITAL READ-OUT, LOW NOX Logo
253 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
