Question about Cameras
I have a canon powershot sd630. The camera works find but when I plug it in to my USB port on the computer (via the canon cable wire that came with the camera) the computer does not recognize the camera. I have been using this camera for two years and this is a new problem. Its as though the usb port on the camera is problematic. I am able to use the port on my computer's tower for other electronics without any problems.
MY CAMERA IS A CANON POWER SHOT S400 DIGITALELPH AND IT HAS A MEMORY ERROR. WHAT IS WRONG?
Posted on Oct 12, 2008
Lost my cannon powershot sd360 cd
I hope you mean the Canon SD630.
You can download Canon software from
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd630#DriversAndSoftware
(If the formatting's screwed up, it's
You might want to consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
Mar 05, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
Hi, I have problems with downloading pictures from my Canon PowerShot 200IS. The PC is not recognizing the camera any more (used to work before). It doesn't work using the UBS-cable nor insering the...
I hope its usb cable my have some problem..... try to purchase a new car reader to insert memory card into it and plug it to pc via usb port..... then also if you face same problem then check you usb port drives and install them......... to rectify this problem.... some times firewall also will not accept usb so switch off firewalls while plug in device cable........
Oct 17, 2010 | Canon PowerShot SX 200 IS Digital Camera
My pictures are not downloading onto my desktop. How can I fix that?
Connect your camera with the data cable and the other end to the computer usb port.Now your camera will detected if not install your driver cd which given with your camera.Then the camera can detected and you can import your photos by copy paste or cut paste your photos from camera to your desired path in computer
Sep 09, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
How can i connect my canon sd630 to the MACbook
Try using a separate card reader to download your pictures to a folder you create on your desktop.
Sep 21, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cant transfer pictures
TURN CAMERA ON FIRST, PLUG IN USB, GO TO MY COMPUTER, YOU WILL SEE A DRIVE THAT HAS YOUR CAMERA ON IT. YOU SHOULD BE ABLE TO DOUBLE CLICK AND OPEN THAT DRIVE.
ANOTHER THING YOU CAN DO IS TAKE MEMORY CARD OUT OF CAMERA, PUT MEM CARD IN COMPUTER, GO TO MY COMPUTER, FIND DRIVE WITH MEMORY CARD. DOUBLE CLICK AND OPEN FILE.
YOU CAN CLICK AND DRAG PHOTOS FROM THAT DRIVE AND DROP THEM IN ANY FOLDER OF YOUR CHOICE.
YOU MUST HAVE THE LATEST USB DRIVERS FOR YOUR EXACT CAMERA FOR YOUR COMPUTER TO READ IT.
Mar 31, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera not connecting to pc
on your computer go to the control panel and click on scanners and cameras. there u can connect with your camera.
Feb 14, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Not uploading to Mac with USB cable
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Sep 08, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera No Longer Being Recognized
Does it connect to the PC via a USB cable? Then try connecting to a different USB port or if you have try a new USB cable. I had the same problem with my IXUS 400 and changing to a new USB port, directly to the PC - not a USB hub, it worked. However now I have several issues with my camera - no sound or image on the LCD screen, but I think these are unrelated.
Jan 27, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Lost my installation disk
I lost my cd rom for a cannon powershot s10 and I can't down load pictures. What do I do?
Dec 09, 2007 | Cameras
Help
either your usb-port or usb-cable... I had the exactt same problem //LaN
Apr 02, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cameras Logo
95 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
