WASTE TANK IS FULL ON MY MP130/11O PRINTER - Office Equipment & Supplies
  • 352 Answers
Do you want to know what this is or how to fix it?
Posted on Oct 12, 2008
I have a samsung clp500 color printer but it is not working .it show only waste tank is full/ not instaled what should i do.
The "waste tank" is located behind the front panel that has the SAMSUNG name on it. Press on the upper corners of this panel and it will open up to reveal a clear plastic tank on the right side.
This tank pulls out easily and has two holes for excess toner to flow into it.
Look at the side of the tank that has the holes. You should see a part of the tank that extends out from the tank but ends in a clear square. The waste tank sensor "looks" thru this clear plastic square to determine if the tank is full. I.e. if toner is in this area and you cannot clearly see thru both sides, the sensor will tell the printer that the tank is full and needs to be changed.
If the tank is not full, use a long cotton swab and clean out the inside of this area. Once you can see thru both sides, carefully replace the tank back into the printer and turn the printer back on.
If done properly, the error should go away and you should be able to continue printing. I have doen this and it works fine.
(Some posts have had people cut this part of the tank off and simply tape over the hole that is made with strong tape. This bypasses the sensor and would allow the printer to run again. I have not done this as I do not want the possibility of toner spilling in my office.)
The sensor could be bad and causing the issue. If this is the case, it may be cheaper to purchase a new printer - CLP-620 ND is a duplex, networked color laser jet that is selling from for $315.
Apr 30, 2010 | Samsung CLP-500 Laser Printer
I own a canon w8200 pigment large format printer. I replaced two cartridges, Magenta and Yellow. The printer did a nozzle check that seemed to take too long. I then received a 'waste ink tank full'...
1.Waste ink absorber
Use SERVICE MODE>COUNTER>PRINTER>W-INK to check the waste ink
absorber. Replace if the waste ink level is near the limit (14400).
After replacing the tank, perform SERVICE MODE>INITIALIZE>W-INK.
Apr 04, 2010 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
I have a problem with my printer epson stylus C90. may i know what todo when parts of my printer are near the end of their life service.?how can i fix it?
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
Jul 23, 2009 | Epson Office Equipment & Supplies
I have a Ricoh G7500 printer that is giving me an ERR-990 when I turn it on. I don't see any documentation on Ricoh error codes.
990 A Waste Tank Full Sensor Defective
The waste ink tank full sensor (a
photosensor) on the corner of
the waste tank is not operating.
• Waste ink tank sensor on the corner of
the ink waste tank is defective.
• Replace the waste ink tank.
Aug 23, 2008 | Ricoh Office Equipment & Supplies
My i350 printer is telling me its waste ink tank is nearly full. What should I do?
pls open up your printer and you can see a small container that is full of waste toners, throw the toner and saved the container, vacuum the remaining toner and gently put it back into your printer, turn the machine on and off.
all printer have waste toner in time they became full and you need to clean the tank or container
Jul 24, 2008 | Office Equipment & Supplies
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
Printer not printing
On the machine there is a sensor that looks trough the waste tank even though you have wiped it clean the likely thing is that the sensor cannot see through the plastic waste tank.
I suggest vacuum the waste tank out until all the toner has gone then install it. If you cannot get rid of all the toner then wash the tank out and leave to dry then install it.
Hope this helps you
Thanks J
Jan 05, 2008 | Samsung CLP-500 Laser Printer
Waste ink tank full
please help me for repair waste in tank full canon ip3300.
Nov 01, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
129 people viewed this question
