Question about Kenmore 62602 Electric Dryer
Dryer problem when i hold the buttom in the dryer works fine but when i let it go it stops running. It's not the way it works. you just push the buttom to start and now you have to tape it down so it stays running. Help please.
  • 550 Answers
With power disconnected
follow the wires from the start button, to a relay,
check the wires (both ends) of all leads to the relay and reconnect any that have fallen off. (crimp tighter if they have fallen)
Check door switch function and connection.
check timer connections
the relay start-button timer and door switch comprise a latching circuit, when the start button is pressed the relay is supposed to latch closed and supply current to heater and motor. if the latching circuit disconnects the relay does not latch closed, and only runs as long as the start button is pressed.
if nothing has disconnected one side of the relay has usually failed, and the connection is not being made to latch the circuit
replace relay
dryer problem - cd48320.jpg relay is shown at right, 2 switches connected by a dashed line.
Posted on Oct 12, 2008
Will not turn on.battery tested and was fine.
Bad push buttom, or something inside the buttom, like any cola or kool aid between the push buttom.
Try to check if the push power buttom it´s working.
Dec 07, 2015 | Cameras
I have a Candy GOU218 when I push the start button it does start the dryer but as soon as I release my finger from the button it stops, It started doing it around a week ago so I had to push and hold
There are push to start circuits used for motors and then there are holding circuits that keep the unit running. This way the dryer stops if the circuit is open due to high temperature or end of the cycle. It seems as if the holding circuit (could be a rotary switch that stays closed while the dryer is running) or a holding circuit relay (stays closed until circuit is broken by the control) has failed.
Jan 09, 2014 | Candy Dryers
Dryer worked earlier today. A drying cycle stopped and the signal sounded. Clothes were not dry so I set the dryer again, pushed the start buttom and dryer would not start up.
first check and see if the fuse in the breaker box has flipped or blowed. If that is not the problem then you need to check the fuse inside the dryer, it may need replacing. This fuse to some is known as the bullet fuse!!!!
Jul 17, 2011 | Dryers
Dryer won't stay running after pushing the button.
that isn't the model number,it will start with 110. or 417.send the full model number and i can look up your dryer,most likely it's the even heat board or the motor relay but without the model number i can't look it up for you,these parts are in the top console,call the parts store give them the model number and they'll give you the right part or send it to me,let me know what you find
Jul 20, 2010 | Kenmore 63942 Dryer
Dryer won't stay on
The motor centrifugal switch is not switching from the start winding to the run winding. The switch should stay in the run winding when the motor picks up speed unless power to the motor is interrupted or cut off. The switch is replaceable on most dryer models but sometimes it is an integral or built-in part of the dryer motor and failure of the switch requires the replacement of the motor. Indicate the exact model number of the dryer for more accurate troubleshooting and repair advice.
May 24, 2010 | Kenmore 63932 Electric Dryer
The dryer (electrical) stop working every couple of minute and i have to push the start buttom over and over till having the load dry
If your dryer is more than 3 years old, this issue may be caused by a broken motor. Regardless it still working, the motor may continue with this problem until it stops working.
The only solution for this may be replacing the motor.
Oct 10, 2009 | Kenmore 62602 Electric Dryer
Compaq 6458cl. Just changed DVD drive and added 1gb memory . Will not power on. Push and holding on/off buttom causes the green and yellow LEDS on the button to blink. Also both fans will run while bu
Most likely your motherboard does not like the ram you installed.. remove one or both of the ram chips leaving the one that was in originally.. test with that chip .. if it works something is wrong with the new ram: it's either the wrong speed or voltage for your motherboard or possibly defective.. you can consult your motherboard manual or motherboard manufacturers site for a complete list of approved RAM.
Keep in mind, most gaming memory requires a higher voltage than generic memory and some motherboards just dont produce it..
Apr 19, 2009 | Computers & Internet
Kenmore gas dryer doesn't stay running have to hold button down.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Dryer won't start all the time. can hand start unit.
hate to be the bearer of bad news but it sounds like ur motor is going out. Had this happen to my last dryer. If this is the case it will eventually just stop. Try running it without any laundry in it. if this works, then load it and see if it still works. (poor little motor has to work a bit harder with a full load) good luck.
Feb 17, 2009 | GE DBXR463EBWW Electric Dryer
Kenmore 62602 Electric Dryer Logo
77 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
