Question about Kenmore 62872 Electric Dryer
Kenmore dryer Front load kenmore dryer elite only runs if the on button is pushed continuously. the moment you release the button the dryer stops
  • 550 Answers
The start button is a low current signalling device that supplies power to a relay, the relay latches, to supply heavy current to the heater and motor, until the timer switch or door switch interrupt the latching circuit and disconnect the relay.
Relays fail
the connector for the latching circuit may have come off
examin inside the control panel for a device that looks like
kenmore dryer - 8d35bce.jpg, may be opaque or mounted vertically with wires connected to the bottom.
trace the wires from the start button, it should be the first device connected.
If any wires have come off relay, or other terminus of wire reattach and test operation of dryer
If no wires off, -replace relay
label carefully wires as they are removed, or replace one wire at a time, from old to new
generic dryer circuit looks like this
the relay is the two switches at right connected by a dashed line to show linked operation. Circuit diagram has no relevance to physical position of components
Posted on Oct 12, 2008
Kenmore Elite Gas Dryer starts/runs/drys only w PTS held on?
push to start button needs replacing,sometimes you can jump that out if you have another switch that starts the dryer when you close the door
Jan 15, 2013 | Kenmore 73952 Gas Dryer
Have a kenmore elite quiet pak ll gas dryer start buton doesn't start. when release the button dryer stops
if the dryer runs when you push the botton in and stops when you stop pushing on the button you have a bad even heat board or a bad motor relay.these parts are located inside the top console,if you send me the model number i can look up your dryer and tell you the part you need to change out
Jul 02, 2010 | Kenmore Dryers
Dryer will not stay running
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Apr 21, 2010 | Kenmore 63942 Dryer
Button starts dryer, but stops as soon as button is released
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
Apr 09, 2010 | Kenmore Elite HE4 Electric Dryer
Runs when PTS held but shuts off when released/no heat
No problem at all.The motor has a start and run winding.Your run winding is bad.The reason you have no heat is the run winding has to run to close the contacts on the motor switch.Replace the motor ,both problems solved. Hope this helps Please rate my response :)
Dec 13, 2009 | Kenmore Washing Machines
My Kenmore Elite dryer starts, but stops running when the start button is released. Do you know the possible problem? Any suggested solutions?
it is one of 2 things either the motor switch is not working right or the control board is out check the motor first if you have a multimeter check the centrifugal switch on the motor
Dec 10, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite dryer
possible interface bd(front controls)there is a lot of electronics on the back side the relay bd on top left receives most of it's commands from front controls if your husband knows how to ck things pull bottom panel off there is a tech sheet on backside..may even ck thermistor on blower housing for correct readings
Jul 30, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 62872 Electric Dryer Logo
132 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
