Question about Rockford Fosgate T10001BD- Car Audio 500watts Mono Power Amplifier Car Audio Amplifier
Amp makes loud noise, why?
Amp makes different sounds on woofers, but when ground to negative on battery it stoped, but now still does it no matter wha is ground to
  • soundaddix May 11, 2010
    Does it do it with the car off also?
Make shure you are using good quality shielded wires for carrying low level signals from your radio to your amplifier.
Posted on Feb 10, 2009
    Problem Solver:
  • 12 Answers
Make sure its a good ground. Make sure your audio cables running from your radio are not running on the same side as your power cables running to your amp. Sometime that can cause alot of noise in the lines
Posted on Oct 23, 2008
Loud noise from subs amp is grounded well
Check the output of the amplifier with the input connections disconnected. Does the sound go away??
If it does, then connect each input one at a time and see what happens. If the sound appears, then do the following:
The ground connection on RCA connectors don't always make a good electrical connection. This is the outside ring. If the RCA connector goes in easily, the the outside ring should be compressed slightly to garantee a snug fit. Do all of the RCA connectors, at the amplifier end and at the radio end.
It could be the way that the amplifier was installed. the ground lead should run directly to the battery NEGATIVE terminal. This will greatly reduce noise produced by other equipment.
Jan 31, 2015 | Car Audio & Video
What's the best way to hook up my jl audio 13" w 7 sub to my jl audio 1000/1 amp
the best way? hmm. i would start off with some wire. Keep in mind that you will need to separate the positive (usually red or has a stripe or marking on it) from the negative (Black usually is the common color for this wire) and hook the up according to your amps positive and negative hook ups / terminals following your sub-woofers terminals. then depending on your sub woofers Voice coils (Duel or single voice coils) yours are duel or quad coils but i\'m sure they are duel (2 of each positive and negative equaling a total of 4 posts on each sub-woofer). figure out your amps ohm load handling and does your amp run hot (1,2 or 4 ohm stable some are even less like 0.5 or lower) i would run at a 1 or 2 ohm load as that is usually standard on 1 channel amps. make sure to check your wiring and if your not sure about ohm loads just Google wiring for sub-woofer ohm loads such as 0.5 ohm, 1 ohm, 2 ohm or 4 ohm loads. also make sure your box is not sealed do to the fact they are siht and cant produce sound like a vented / ported enclosure keep the size as big as you can fit in your car or truck the bigger the better. i had one 8\'\' sony sub pounding like a 15\'\' sub real loud . Also MDF particle board is garbage it causes port noise and absorbs water
Apr 28, 2014 | Car Audio & Video
1994 nissan pathfinder engine make low whining noise when excellerating
It sounds like a ground issue. If you have an amp connected to your stereo check the negative ground and remount to a different spot. If not it could be the belts or possible wheel bearing.
Jun 06, 2012 | 1994 Nissan Pathfinder
Tweeter works but not the woofer
Take out the woofer (disconnect it from all wires). Take a 9V battery and connect two leads to it. Tap the positive lead to the positive on your speaker while touching negative to negative. You should see the woofer move a little and make a little noise. Don't do it for longer than a second or two or you can burn up your speaker. If it doesn't move or make a noise, your woofer is blown.
Jan 14, 2011 | Mackie SRM-450 System
Hi, I'm driving a 04 honda accord euro, and I've replaced the old standard speakers with a new one, sorry that I forgot the brand of the it. Recently I heard some high-pitch noise coming out of the...
sounds like alternator whine, can be a hard thing to fix or something really simply. here are some things to try: check your ground at the battery first, make sure it's a good connection on the battery and the bolt it's grounded to on the car, make sure the battery connections are clean, positive and negative. make sure you have a "good" ground on your amp/amps and radio. you can also try grounding the radio and amp at the same location to avoid "ground loops" don't run a long ground from amp, but run a wire from the radio to the amp ground. hope it helps. dave
Oct 05, 2010 | Car Audio & Video
I wired my alpine sws-1243d and in a matter of 3 minutes it burned up now the speaker wont even turn on so dont know if its blown or what but im getting no sound whatsoever from the woofer i wired positive...
The polarity of speaker connections verses the connection to the amp should have nothing to do with situation. The sound reiforcement would be weaker in one direction is all.
Make sure the amp was not rated for more power than your speakers. If you overdrove the speakers you may have fried the voice coils.
Feb 08, 2010 | Alpine Car Audio & Video
Jl audio with 2 12kickers cvr
it sounds like you don't have enough power to run the amp, or else it is a built in (MOSFET) overload device inside the amp. the woofer is from your discription blown. when you choose a amp and woofer you need the woofer to be able to handle more watts (MAX) than the amp can give or you will blow every woofer you connect up. you can solve the power outage by fitting a "CAPACITOR" which stores power and provides it to the amp as and when it is needed, or you will need to install another battery for the amp alone.
Jan 15, 2009 | Jl Audio 250/1 Car Audio Amplifier
Sub woofer making a screaching loud noise when powered on
The pop from other electrical items makes me think it's a ground problem but I am do not have a clue as to what type of setup you are running over there. Did you try a surge protector?Is it 110volts with a seperate ground wire?
Have you tried running a UPS?
Sep 26, 2008 | Logitech X-230 Computer Speakers
Diferent sound
The entire difference may be due to the vehicle.
He could check things like the B+ reaching the amps when driven hard. It should remain well above 12v. If it's dropping below 12v, that could be part of the problem.
He also needs to check to make sure that all woofers are in phase. If he has one woofer connected improperly, it would only be approximately as loud as one woofer because one would be cancelling another out.
Dec 22, 2007 | Mmats SQ-2150 Car Audio Amplifier
Woofer making horrible noise! HELP!
Think as an expert... Probably from my experience repairing woofers etc... the cone (1) or the spider (2) isn't well glued onto the woofer skeleton(or both???) The woofer cone must be absolutely centered or else you will get those clicks in low frequencies(you also get them in higher frequencies but you can't hear them!) I must say that it is very difficult to repair a woofer by your own. I suggest to return it back where you bought it and take another one (i suppose that you have a guarantee ha?).
Aug 10, 2007 | Alpine SWR-1542D Car Subwoofer
Car Audio & Video Logo
144 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
