Question about Nokia 6600
Nokia 6600 Keeps turning off?
My nokia 6600 keeps turning itself off. Phone starts and goes to main page but shows no reception signal then goes off after about 10 seconds. Only just started doing this. Phone is fully charged. Will only stay on if no sim card in. PLEASE HELP!
  • tigerdebs123 Oct 12, 2008
    If you have nothing interesting to say say nothing at all !
    GET A LIFE !
Get a new phone
duuuuuuuuuuuuuuuuh
Posted on Oct 12, 2008
My mobile has a special problem. The mobile shows a weak signal and sometimes zero signal at my home even though the other nokia mobile signals are very high at my home.(same network other nokia mobile...
Are they the same models?
The phone's capability to sustain a stable network coverage may vary even in model types.
While at your home,remove the phone's battery and simcard and fit them again.
Note how the phone's network signal registers.
It may start very high and then drop drasticaly to very low or no signal at all or sustain a constant signal reception.
If the reception's good in other areas,then your home area's network coverage may not be that good.
Hope this helps.Thanks!
Oct 31, 2011 | Nokia Cell Phones
Hi there i have a problem in my Nokia 6600 when i've tried to read my msgs and also goin to my contacts the screen shows System Error (-25) what should i do
There are times that this system error comes from memory. try to remove it first or replace another memory card and test.
if this problem keeps on showing,just format or reset your phone by doing this Hard Rest;
1. turn off the phone, remove simcard and memory card.then put the battery back
2. long press ( * ) ( 3 ) ( call key ) simultaneously then power it on. (keep holding the three buttons) wait until the formatting message appear (you can now released all buttons) wait until the process is finish and it will restart automatically.
* Be sure battery is in full charge when doing this method
* also back up all important files before doing so.
Good luck...
Jun 26, 2011 | Nokia 6600
Net work problem
- make sure your phone is open line, so all sim you insert can be use,
- make sure you are using your phone in the area with a network signal
- try to check with celphone technician, some nokia phones have problems with their network when its coming of age.
Aug 25, 2009 | Nokia 6600
Not having good reception on my 6600 slide
if your phone is in warrenty go to customer care of nokia..
Aug 03, 2009 | Nokia 6600 slide Cellular Phone
Forgot code
Got this from a blog. It received a good response. See if it works for you.
On the main screen type in:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.) Press and hold "0" on the main screen to open wap browser.
Jul 25, 2009 | Nokia 6600
Nokia 6600 Bluetooth, gallery problem.
yez.,, its a hardware problem, you just have to replace the bluetooth module of your phone, or go to a near repair cellshop and ask them to do that,, when you open gallery it only stuck up on opening and when u use your camera, it says temporary overload ryt?? and some application won't work, the only thing is to replace the bluetooth module of your phone
Aug 24, 2008 | Nokia 6600
Problem of my nokia 6600 please solve
try formatting the fone 1ce....if the prob stil permits get the blue tooth module replaced
Mar 21, 2008 | Nokia 6600
How can i fix my nokia 6600?
Try a reset:
First turn it OFF, take the SIM card out.
Press * 3 send at the same time and turn phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Jan 17, 2008 | Nokia 6600
My nokia 6600 gallery does not load. It shows "opening" and keeps showing the opening message and hangs. The bluetooth. First it said Unable to connect , when i click pair to device it says "system Error". and Now when i click bluetooth it doesnt load options. Other than that the speed of my phone is very slow.
if u have facing this prob. then switch off the phone and then switch on the phone do this procudure 3 times
Dec 07, 2007 | Nokia 6600
Nokia 6600 Logo
197 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
