Question about Whirlpool Refrigerators
FREEZER PART FOR WHIRLPOOL 1EED251MMWRO
TRYING TO FIND PART FOR SIDE BY SIDE REFRIGERATOR FREEZER, NEED A FAN FOR FREEZER
    Genius:
  • 1,122 Answers
Go to sears .com click on parts puit in your model number and you will find everthing you need,let me know more-mike
Posted on Oct 12, 2008
My whirlpool side by side is getting warmer. Freezer was up to 45 F yesterday, today 55 F, Refrigerator getting warmer too. Fan on freezer and refrigerator vents blowing, but isn't that cool. What's...
check and clean the condenser coil under the ref , remove the back to the ref if the compressor is real hot you need to put a fan behind the ref for a couple of hours until the compressor cools down then plug it back in.
Nov 21, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
My whirlpool ART 900G fridge freeser, the freezer works but the fridge wont chill
Check the fan that moves the air from the freezer side to the refrigerator side. It is either stuck in ice or not working. Defrost the refrigerator for 24 hours and then restart it Listen for the fan operation be aware that the fan may shut off when you open the door, so listen closely. Defrosting it may fix or the fan may need to be replaced.
Nov 12, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Whirlpool refrigerator side by side freezer won't freeze
your over-load/contactor is defective, un plug it from compressor and shake it if it rattles its bad
Oct 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gs2shaxnl00 freezer working but not fridge not
The possibility is that the freezer fan is not working or the passage from the freezer to the refrigerator where the fan blows the cool air from the evaporator is blocked. Also if you say you manually defrost it could be that it is not self defrosting which can also cause this problem because the evaporator will build up ice and block the flow of the fan air
Jul 15, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Refrigerator Freezer Fan
yes you can unplug refrigerator remove carry it to appliance store or model #
Apr 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH
You need to look inside the freezer at the rear wall cover and see if it is frosted over. If your refrigerator is not defrosting that can cause the refrigerator side and the freezer side also not to cool to the desired temp.
Mar 30, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Whirlpool refrig not cooling
is the fan in the freezer working when compressor is on? if not you need to replace it. do you have a large frost build up on the back wall of the freezer? if so you have a defrost problem, or back to the evaporator fan. If the fan is working you have a defrost problem which could mean a bad heater, timer, or bad defrost thermostat....
Jan 03, 2009 | Whirlpool GS6NBEXR Side by Side...
Have a whirlpool side by side american fridge freezer,,
If the fan in the freezer is working.
You can hear this fan running when you open the freezer. Then I think the noise you hear is the fan hitting an ice build up.
This is a failure of the defrost system.
Dec 21, 2008 | Whirlpool ED2FHSS Side by Side...
No air flow to refrigerator section
hi thanks for the question yes lots of times i would check the fan motor in freezer you should be able to hear the fan going with the freezer door open if not replace the fan motor in freezer and also check for frost build up in freezer thanks the appliance doc
Aug 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
41 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
