Question about Sunlight Supply 400 Watt Hps Sunsystem I Sun Gro Plant Grow Light
400 watt HPS
I have a 400 watt hps, now the light just went out so i tried a new bulb, it didn't work in it either so it's def the ballast, I need to find out which part went bad, now a 400 watt MH conversion bulb will light up in it a little but the 400 watt HPS won't come on at all. All I hear when I plug it up is a humming coming from the ballast. I mean its only got three parts in it right? So there should be someway to test it. Oh I have a digital multimeter if you could tell me what the settings should be set to on it to test the transformer, ignitor, resistor. Thank you so much for your time and effort in helping me whatever the outcome. Peace :) Roger.
  • rogerthebull Oct 13, 2008
    Roger.
  • jonzjan Nov 20, 2008
    I unplugged my 400 w ballast while it was running. I switched timers on the power strip then plugged back up. Immediately I noticed that my bulb was not firing. I have since found out that it was not the bulb, but my ballast. My ballast hums like it is running but no fire. I am currently looking to get it repaired, but I am having no luck.
    Josh
The ballast may not be the problem. The problem may be the ignitor (starter). If the fixture humms, then the ballast is most likely working. Ballasts (transformers) do not go bad very often.
Posted on Nov 17, 2008
    Scholar:
  • 132 Answers
Roger last time a ballast stopped working on me i simply replaced it on the grounds i might become a fire hazard do you no what i mean they are not that expensive
Posted on Nov 09, 2008
My ballast making a humming noise but will not light up my 600w hps bulb?? small bit of purple light in the bulb when turned on but not lighting up?? tried a 400w bulb in hood with the 6oow ballast and...
NANOLUX BALLAST 400W-1000W
NANOLUX HPS and MH electronic ballasts can be light up
E-MAIL :cly@sznumber.com
Skype:sznumberballast
May 18, 2013 | Sunlight Supply 400 Watt Hps Sunsystem I...
Just bought 4 new 1000W Super high output HPS bulbs. Only one of them is really bright. The others are about 80% by eye. The brightest one is nearest to the transformer stack but the others don't...
A ballast for a 1000 240 volt fixture will lose a small amount of output over time , but should nt be too noticeable . I suggest you take one of the dimmer bulbs and install it into the fixture that has the brightest bulb in it now . If the new bulb is now the brightest of all , then you know your other ballasts have lost some intensity . I have also seen on some bulbs depending on the gas inside the glass( ex. HPS or Metal Halide) which gives off the different color , will take a while on initial start up , to burn at full intensity . It is also possible that you were given used bulbs which would explain the 20 percent loss in intensity . Good luck
May 30, 2011 | Sunmaster 1000w Hps Grow Light Bulb 1000...
One of my two hps bulbs is brighter than the other one the bulbs and one of the ballast are new the other ballast is a year old
Hi .. it could be the ballast .. an easy thing to do to troubleshoot this would be to swap the lamps. If the problem follows the lamp. then that is the problem. If the pronblem stays with the fixture, then I would replace the ballast in that fixture.
May 03, 2010 | Sun System 600 Hps Cool Grow Light System...
400 watt grow light
ballast is weak ,or the bulb. i would never by the combo lights /use a hi pressure sodium for both vegative state and flowering.you dont necessarily need a MH..
Jan 03, 2010 | Garden
''UV'' light not working!!
I`ve always used one ballast to one light.i.e if your bulb is a 400 you need a 400 ballast only and feeding no more off it. Try this
Sep 29, 2009 | Sunmaster Conversion Lamp HPS Ballast
Hello...need help.. replaced 600mh bulb then
Have you tried the switch yet? The plastic switches inside some ballast boxes don't do well with the heat produced by the ballast. You can try to simply bypass the switch and hard wire the ballast to the plug to test whether or not that might be your issue. If you need a new switch, just call Sunlight Supply directly http://www.sunlightsupply.com/hort/contact.aspx they should be able to send you a replacement switch.
Feb 18, 2009 | Sunlight Supply 400 Watt Hps Sunsystem I...
Hid light output?
MH lamps are available in 175,200, 400 and 1000 watt sizes. HPS lamps come in 50, 75, 150, 400 and 1000 watt sizes. San Agro comes in 430w only, but it works with a 400w HPS ballast. Each lamp requires its own ballast, which comes with the fixtures that are designed to use these lamps, and are also available separately.
Aug 27, 2008 | Hydrofarm Agrosun Dayspot 60w Grow Light...
Sunlight Supply 400 Watt Hps Sunsystem I Sun Gro Plant Grow Light Logo
1,611 people viewed this question
Top Sunlight Supply Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Sunlight Supply Garden Expert? Answer questions, earn points and help others
