Polaroid FLM-373B Television Problem: When I turn the t.v. on the red light goes from red to blue but the picture does not come on. To get the pic to come on I must unplug the power cord and replug then turn the t.v. on again. That's how it started. Next while still needing to use that same procedure to get a picture the picture became distorted in a small band across the screen. After that the picture got worse in stages until now it will not come on at all. Help.
  • jamesadkins Oct 12, 2008
    I don't know yet. I just unplugged it. I will try to let you know if it works out but thanks for the suggestion one way or the other.
    Genius:
  • 1,011 Answers
Dear,
can u handle the inside electronics, if so, then can u tell me the model and chassis no..
regards,
dont rate it until it helps or fix it
Posted on Oct 12, 2008
    Master:
  • 505 Answers
The one color problem could be either your color wheel or your DMD board. The DMD board controls the colorwheel RPM in order to create the vibrant exact colors that you see. You also need to make sure the fuse is OK
You will require a technician for the same.
Thanks.
    Sergeant:
  • 352 Answers
This is not my solution, but, some insight into your problem provided by an electrical engineer, maybe it will help you.
Out Sourced Answer:
I noticed that you asked this question previously and should already have the service manual. And that the manual was not able to help you resolve your problem. These Polaroid TVs don't have very good service information for us technicians. And we tend to avoid that brand whenever possible.
I know this won't help you solve your problem, but I wanted to explain why your having so much difficultly getting an answer. I don't think you're going to get any better help than what that service manual gives.
anaanymous
  • 10,594 Answers
Digital video processing board seems defective.
  • Shahid Electronics
    Shahid Electronics Oct 12, 2008
    Its part number is
    899-D01-JK401XA and available at Shop Jimmy on $150
    sorry, Shop Jimmy link was not in above reply.
  • 19,396 Answers
The TV is going in protect mode because it detects an internal problem, try leaving it unplugged for a longer time, let say one hour or two.
  • Ginko
    Ginko Oct 12, 2008
    Basically, what happens is that the TV does not start because it detects that there is an internal problem, such as a wrong voltage, a bad component, overheating etc.
    When you unplug power and restart it, you reset the internal circuit, and the TV will restart, not detecting the internal problem.
    As soon as the TV gets hot, after staying on for a while, the defective part start giving troubles, as the defective component (probably an IC, starts overheating).
    As already pointed by the other expert, from description, the digital processing board. can be cause for the problem, as you told us picture shrinks to a small band and you lose convergence after TV stays on for a while.
    However all the following parts can be involved.
    Parts involved can be
    Polaroid digital processing board.
    Polaroid replacement ballast.
    Polaroid Replacement LCD controller
JVC HD-56FN97 when turned on blue light is solid,red ligt blinks a few times and goes out. My picture is very dark despite adjustments I make in the menu, any help or feed back apreciated.
The set does use a lamp for a light source and average life is 2 years or 2000 hours---many lamps before they actually fail get to be darker.
Dec 04, 2012 | JVC HD-56FN97 56" Television
Turns on for 30 sec then goes bright blue and goes back into standby. turn back on it does it agian
This is blue CRT problem in tv as it is rear projection tv that has three CRTs red-green-blue inside to project color picture on front screen.
Blue CRT (tube) will be replaced to fix the issue and it is job of Pro because lots of adjustments are required after replacement of tube.
Local tv repair shop will help you for that.
Thanks
Oct 02, 2010 | Sony KP-51WS500 51" Rear Projection...
Flm-373b lcd tv will not turn on. red light turns to blue but wont come on.
There is a guy who fixes that tv at www.mikecampagna.com/Polaroid
Jun 10, 2008 | Televison & Video
37" LCD TELEVISION WITH NTSC/ATSC TUNERS FLM-3732 THIS UNIT IS JUST OVER ONE YEAR OLD. WHEN ON BUTTON ON TV OR REMOTE IS TURNED ON NO PICTURE IS RECEIVED BLUE ON LIGHT COMES ON./ WHEN TURNED OFF BY...
This is a Polaroid brand.
The failure on these TV sets is originating from the power supply assembly not providing a clean DC voltage to the main board.
The power supply will need to be repair since there aren't service parts available.
I could fix the power supply for you.
Send me an email to jah2mil@hotmail.com for more info.
May 06, 2008 | Televison & Video
FLM-373B Polaroid tv will not come on. The blue light comes on and when you turn it off the red light shows up. The screen of the tv is black and no sound. Can you solve this problem without calling a...
Same problem here. Polaroid Tech Support says that it is the control box.
It is a little over a year old so it is out of warranty with Polaroid.
Except, I bought the two year plan when I bought it at Walmart. So I called them and they are sending me a box and a shipping label to mail it back for repair. I tried to tell tham that is a little big to mail but they insist. This should be fun.
May 02, 2008 | Televison & Video
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
