Question about ViewSonic G220f (Beige) 21" CRT Monitor
Images are blurry. icons, everything - ViewSonic G220f (Beige) 21" CRT Monitor
    New Friend:
  • 62 Answers
1. remove the monitor dome. adjust the LOT Focus. ( lot top side preset)
2. remove the G4 wire focus ( neck base ) cleen and fixed.
3. replaced the neck base.
4. last and final replaced the lot.
Posted on Oct 13, 2008
Hp 5550dn prints text fine but pictures are blurry?
Don't replace but verify the condition of fuser assembly, if you found any cracks or folds on teflon roller or pressure roller causes the same thing, just verify get back to us...
Feb 01, 2012 | HP LaserJet 5550DN Printer
Tip
If you have blurry "melted" images RECALL until 9/30/2008
One day my camera started looking very blurry, images looked like everything was melting. This is a know issue with this model.
Go to Sony's web site, type in model of camera and call the number to Support ASAP. Sony is offering a fix until 9/30/2008.
on Sep 05, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
It's all blurry, and i don't know how to refocus it.. i don't even know if you CAN refocus it.
Try different resolutions. LCD screens have a native resolution that they look best at. Setting the screen to something else can make the screen images/icons/text seem blurry.
Right click on the desk, choose Properties, choose Seetings, and try some of the other resolutions.
Apr 04, 2011 | Computers & Internet
How do I shrink desktop icons, window tabs, font?
try to higher your resolution(right click, properties),if it does not solve your prob. i think you mess with the video card installer. install the video card installer again. About your icon dont worry it will return to its place after you get back your resolution.
Mar 30, 2010 | Microsoft Windows XP Professional
Icons are blurry
Did it happen all of a sudden? In other words, was it OK before?
Try going to screen preferences, settings, and look at the resolution slider - is it set to the native resolution of your monitor (1280x1024)? If not, correct and accept changes.
If the resolution is set OK, then multiple other things might have happened, but not knowing a bit more about the situation it's hard to advise anything...
Nov 08, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
The images on my computer are blurred
if you use the default dell settings you may experience the problem with blurry images in Internet Explorer. This effect is due to the automatic scaling in IE6 and above. IE tries to resize the images so that everything looks the same as when everything is at smaller dpi, but does a terrible job at it, resulting in blurry and unreadable images. Change the following registry setting from 1 to 0 in order to disable this "feature":
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\UseHR
[1] Adjusting Scale to Higher DPI Screens (MSDN)
good luck with this. please do this, and get back if u run into a problem. also, if this fixes the problem please rate my answer. thanks so much, Joe
Feb 02, 2009 | Dell Inspiron 1501 Notebook
I have just got this 22'lcd Samsung 225ms. I cannot seam to fix the problem of blurry letters. This can be very hard to read even at a distance. I have searched for updates online for my nvidia g force...
This monitor will only have a sharp image at a resolution of 1680 x 1050. Any lower setting will result in blurry images.
In an LCD the pixels are fixed, and using any resolution lower than the optimal will cause blurry images. This is called Image Scaling:
http://en.wikipedia.org/wiki/Image_scaling
If that resolution causes the icons to be too small, you can change the DPI setting to 120 from 96, that will make them larger
Jun 09, 2008 | Computers & Internet
Fuzzy images
Hey jjbeanwink,
This is a very nice lens, and is unlikely that your blurry images are caused by the lens. The most common cause of blurry pictures is that the shutter speed is set to low. A general rule would be your shutter speed should be at least 1/60th of a second while handholding the camera. The bigger the lens, and the higher the magnification of the subject you are using the faster the shutter speed you should use. If camera shake is the cause of your blurry pictures you could also try using a tripod. Another common cause of blurry images is subject movement, and one solution would also be setting a faster shutter speed. Another solution is using the flash to stop the action instead of the shutter speed. Of course manufacturers do occasionally make a bad product and that is why there are manufacturers’ warranties. If you just purchased this lens you could have an authorized service technician look at the lens and see if there is anything wrong with it. I these suggestions help!
Sincerely,
Allan
Go Ahead. Use Us.
May 12, 2008 | Canon 24-70mm f/2.8 Lens
Hitachi 50UX22B
Look inside the lens while the set is on. If you see things floating around inside the glass, the fluid will need to be changed inside of each tube. I will post a link on how this is done if this is a Magnavox TV set. Good luck
Feb 14, 2008 | Philips Magnavox 51MP392H Rear Projection...
Everything blurry
This sounds like it might be a defective CCD imager. If so, Sony should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/11/sony-konica-minolta-cameras.html
Applicable cameras include:
Cyber-shot DSC-F717, F88, P10, M1, P12, P2, P31, P32, P51, P52, P7, P71, P72, P8, P92, T1, T11, T3, T33, U10, U20, U30, U40, U50, U60, V1
CD Mavica MVC-CD250, CD400, CD500, and FD Mavica MVC-FD100, FD200
Feb 07, 2008 | Sony Cyber-Shot DSC-P10 Digital Camera
ViewSonic G220f (Beige) 21" CRT Monitor Logo
186 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
