Connect pc with moniter by DVI cable?
I have done this before connected me laptop to my moniter by DVI withoutany cds i cant remember how i did it can ne 1 help pleasee
    Problem Solver:
  • 6 Answers
If you already have a cable, usually it's a hotkey on your laptop. Its Fn+F5 just look for the little monitor screen on your function keys, remember, it's two keys and press them until video is transfered to the Monitor. Usually have to press twice or three times.
Posted on Oct 15, 2008
How can i connect my hp pavillion s5610y to my bravia tv
This is a bit complicated since there is no HDMI output capability to the PC, only VGA and DVI. First, check to see if the Bravia has one of its HDMI ports listed as DVI capable. If it does, it should have accompanying audio jacks (red/white) for it. What you would need to get is two different cables for interface. The first is a DVI-to HDMI cable to run from the PC DVI port to the Bravia DVI-compatible HDMI port. You cannot run the DVI to a regular HDMI port because if you do you will get only picture and no sound. DVI outputs, unlike HDMI outputs, do not carry the audio signal. A DVI-compatible HDMI port on a TV set will connect the video from the HDMI port and the audio from the reserved audio port accompanying it. The second cable you need will be a mini stereo audio plug to RCA jacks. This will connect between the PC audio out (green), and the DVI audio plugs on the set. See pictures for cables below
Once you have this done, selecting the appropriate HDMI port on the set should result in audio and video getting to the unit. If you only need the video (you are going to use the PC speakers), then you don't need the audio cable and you can use any HDMI port, but you cannot control the volume using the TV set remote. You would need to use the PC volume settings. (Just as an afterthought if the set has no DVI-compatible HDMI port).
Jan 26, 2016 | HP Computers & Internet
Connect wii to vga moniter Hp s2031
Hi Dear Friend,
You have a monitor with in-built VGA Port and you have laptop in-built VGA Port then why you are not using simple VGA cable to both port, Please don't use any other type to Adapter.
Thanks to Visit on Fixya
Sep 13, 2012 | HP S2031 20-inch Diagonal Lcd Monitor -...
I have a del latitude E6410 laptop and would like to know how to connect it to a pansonic 42 flatscreen hdtv to use it as a moniter
Dell Latitude E6410 does not offer HDMI or DV. Only VGA Port is available. Therefore in order to connect the laptop with the TV, you can use VGA cable.
But if the VGA input is not available on the TV, you need to get VGA-to-DVI or VGA-to-HDMI Adapter, depending upon the type of port available on the TV.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Aug 18, 2011 | Panasonic Computers & Internet
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
I cant connect my acer aspire 5810 tg with my samsung lcd tv.the tv say "NO SIGNAL"
So here's a quick walk-through of all the methods that I know (if you know any more, please comment) to connect a laptop or PC to your TV:
1. S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You'll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC's are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won't find a VGA port on regular TV's though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with "digital" being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI - Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Here's a graphic I created with some pictures of the various cables:
Hope this helps someone! If you have any other ideas or suggestions, please feel free to comment!!! Thanks!
Nov 13, 2010 | Acer Computers & Internet
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
How do I connect my Sony viao to my philips LCD
If your PC has a DVI port( ihope u have one) purchase a DVI cable and connect it to your TVs DVI port
DVI port
dvi cable
If your tv has no DVI port and only VGA port buy a vga cable and dvi to vga converter and connect to pc and use it
vga cable
you can also get a svideo to avi converter cable and use it to connect to your tv
svideo converter
Nov 27, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
What dvi cable do i need?
Any bog standard dvi cable should work. As should a dvi to vga converter. Dvi is by far the better interface, and I would highly recommend using it, without any converters. I don't believe you can up convert vga to dvi, but you can certainly downgrade a dvi signal to vga, but i can't see why you would want to...
Oct 17, 2008 | Computers & Internet
Moniter
First please check whether the Monitor powering ON or not
the see the colour of light of the monitor i.e, its green or orange or not glowing next see that all the lights showing but constantly flickering or else just see u r VGA or DVI Cable which is connected properly to the CPU if it is ok then remove the cable connect only the monitor to different machine in case still not comming then finally it is a monitor problem or else just check all the connections inside the CPU
In case its monitor problem either it will not power ON or else all the lights will blink constantly that means the refresh rate or the Resolution of the monitor has been changed in case if it is done just connect a different monitor boot in the safe mode by pressing F8 button after entering there change the resolution which will be in the display properties apply and reboot the machine or else turn off u r PC and connect u r Old Monitor and Boot the Machine
Jul 30, 2008 | E-Machines eMachines Desktop PC
Moniter Vga cable
You need a vga to dvi cable, your local PC shop should be able to help.
Oct 06, 2007 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
496 people viewed this question
David Payne
David Payne
