Question about Sony KP-61V85 61" Rear Projection Television
I have a Sony KP-61v85 projection set that wyou help meon't turn on
If I unplug it, wait and plug it in again it makes a clicking sound and the red light in the fron blinks 4 times, pauses than blinks again. I took the back off but I do not see any fans. Can you help me? Not sure what needs to be done!
  • ersaloongirl Oct 12, 2008
    Any idea how much this would cost to fix???
  • 10,594 Answers
4 blinks is error code in KP-61V85 and shows problem as follows...
IC1509(V out) is broken.
Q1505(V Pulse Buffer) is broken.
If you have no experience, don't put your hands in TV because TV has high voltage inside and electric shock risk involve.
Posted on Oct 12, 2008
How to change the brightes
A fairly old model is listed here(KP-61v85) this answer is based on that model number:
If the set has not been serviced for a long time with set unplugged remove rear cover and locate (hard to miss) the three large black lens at top of chassis--clean the lens with a lens cloth or a paper towel with glass cleaner sprayed on the towel.
If the lens are dusty/dirty they will diminish the brightness and clarity of the the picture---they are the light source for the picture in this set.
Apr 11, 2012 | Sony KP-61V85 61" Rear Projection...
Picture is very red and slightly distorted
A very red picture is usually related to the Red CRT or red CRT drive board being defective. The convergence will only mess the alignment up and cause the picture to appear 3D it wont make the Picture take on alot of red tint.
Aug 28, 2009 | Sony KP-61V85 61" Rear Projection...
My sony tv Comes on some times but then some times does not
On most of your rear projections you got GUNS and if there out of allignment or overheat you will get this error and it will need to be serviced.
Apr 22, 2009 | Sony KP-61V85 61" Rear Projection...
Sony KP-61V80 wont turn on
This is a very easy fix actually all you need to do is replace that cap and the set should be fine, this is a very common problem on your model. If you look on the board and give me the location of the cap I will be happy to look up a part number for you.
Tim
Experttv@comcast.net
Sep 10, 2008 | Sony KP-61V85 61" Rear Projection...
Sony rear projection 61in TV
Is there any incidents happen before the problem occur, like powersurge, or sudden electrical failure on your area..?
Jul 26, 2008 | Sony KP-61V85 61" Rear Projection...
SONY KP-61XBR38
Power supply . I would check for shorted Horizontal output transistor first then low voltage regulators. You will need some trouble shooting experience and a service manual for sure. You can get on at this link. http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=kp61xbr38 let me know if i can help you further.
Jan 10, 2008 | Televison & Video
Picture went off still had sound then i turned off at panel now only red timer/standy stays lit sony 61" projection
First plug in again and look at led light, the amount it blinks tells what is wrong. Then if it stays lite it tells something also. You can try Display-channel 5-volume +- Power(service mode). Then Channel 8-enter(test reset). If this doesn't work then you will have to replace somethings like F601, R607, Q601, IC601, R612, VDR601.
Oct 05, 2007 | Sony KP-61V85 61" Rear Projection...
Sony KP-53S75 Makes Clicking Sound But Wont Turn On HELP!!!
Good Day, menudude;
The Sony your friend gave you is a 2000 Model and cost about $2,000.00 and you don't want to spend $400.00 to get it repaired? GET THE TV REPAIRED FOR THE MONEY.
Good night & Luck, big IRISH.
Oct 01, 2007 | Sony KP-53S75 53" Rear Projection...
Sony KP-61V85 61" Rear Projection Television Logo
269 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
