Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Drip/moisture tray inside base of kitchenaid superba refridgerator
Is this a removeable tray for cleaning? If so how to?
  • JLGLois Oct 12, 2008
    No water, just doing maintenance type cleaning, and want to remove the moisture tray from inside base to clean as well as expand area reachable by vaccum tool for dust removal
    Genius:
  • 1,122 Answers
Need mor info,is there water in the bottom of your frig. or freezer,let me know more-mike
Posted on Oct 12, 2008
  • MIKE major Oct 12, 2008
    THE DRIAN PAN IS LOCATED ON THE BACK BOTTOM OF FRIG.,SOME ARE BUILT IN,MOST PEOPLE CLEAN THEM AND PUT A SMALL SPONGE IN THE BOTTOM,ALSO USE YOUR VAC TO REMOVE DUST FROM CONDENSER COIL UNDER FRIG.,LET ME KNOW HOW YOU MAKE OUT-MIKE
I have a Kitchenaid Superba side-by-side refrigerator that is 14 years old. I noticed water on the floor tonight and the tray below the freezer was full of water. I emptied out the tray but water seems...
There is a hose that runs from under the evaporator coil inside the freezer (it is connected to the inside drain pan) to the outside to deposit the defrost water into the outside drain pan. That hose may be cracket, broken, or maybe when you put the outside pan back somehow the hose did not wind up above the pan so the water would go into the pan. Check the location of the pan. If you need more help, just write back.
Aug 09, 2011 | KitchenAid Refrigerators
Can this refridgerator be unplugged for extended periods without ill effects?
Yes, but be sure to clean the insides very well before doing so, and make sure to leave the door proped open.
Jun 21, 2010 | KitchenAid Superba Architect KSCS25INSS...
The drip pan that sits under the freezer side of our Kitchenaid Superba side by side refrigerator is full of nasty looking black water that I wanted to clean out but I can't figure out how to get it out of...
well to take that out ? which isn't normal part of it the drip pan catches water from the fridge / freezer and is caught in the pan while the evaporator generates heat to dry the pan out!! so if you really must remove it then you have to remove the wire in front of it to get it out other wise you just unplug it and reach in there with a brush to clean it
Jan 20, 2010 | KitchenAid Superba Architect KSCS25INSS...
Describe your Kitchenaid Superba sidebyside refridgerator thermostaI need help with how to access the refrigerator slide thermostat - for a Kitchenaid Superba KSRB22fkss - I have removed the two screws...
here is the web site that shows you a daigram to get to the device you want.http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265743
Sep 05, 2009 | Refrigerators
Drip tray full of water, don't know how to get it out to dump
How to remove drain pan on a kitchenAid side by side with water filter .
Nov 11, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Superba Model KSRS22D
Hi-
The Kitchenaid Superba KSRS22D has 14.4 cu.ft. refrigerator space and 7.1 cu.ft. freezer space for a total of 21.5 cu.ft. Hope this helps... -Syren
Jul 02, 2008 | Refrigerators
Fridge
Clean the door seal and ensure that there are no gaps between the sealing surfaces of the door seal and the refrigerator, if there is, relatively warm moist air will continually feed condensible moisture to the cold gap in the seal and the condensed water will drip on the floor. If the door seal its self is broken or torn it will have to be replaced to stop the drip.
Hope this helps.
Mar 16, 2008 | Refrigerators
Drain pan leaking?
there is a drip pan located underneath you ref but most likely your prob is a plugged drain line coming from the freezer. when you ref goes into automatic def the water doesnt run out into the drip pan but instead onto your floor..
you can clean the drain line by removing the rear cover in the freezer compartment and using hot water to thaw the drain below the evap coil.
Dec 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
240 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
