Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Laser 73 ee 2
I keep getting ee 2. I reprime the pump and then the stove kicks in and runs fine but then the error comes on again so I reprime again. Do I need a new pump?
  • 57 Answers
Try this site....
http://www.rural-energy.com/publications/catalog/category/101
How long has it been since you've cleaned your stove? If it's been a while the flame sensor (the part with the metal rod) may be building up a chain of carbon blocking the igniter from igniting the flame. A temp fix is to jiggle the sssensor but what is needed is a cleaning. Also you may need a new burner ring. That solved my problem last winter.
Posted on Oct 19, 2008
I have had a few issues with my toyo stove lately, first off, I have been getting an ee 6 error, which is a mis ignition, I just manually reset, and it works, it does this every few hours. Yesterday, I...
As you have mentioned that you hear a ticking or thumping noise, means the fuel isn't getting to the fuel sump. It could be caused by an air bubble in the fuel line, a clogged filter at the tank (if you use an outside tank), or a clogged fuel strainer in the fuel sump.This can be caused by several things. Most commonly a fuel flow problem or out of fuel. If you are out of fuel or the fuel just isn't making the fuel pump, the pump will make a loud ticking or thumping sound. You should check your filter at the oil tank, if you use an external tank. You should also check the strainer in the fuel sump located on the right side of the heater. Two screws hold the cover on. You need to turn off the fuel valve at the tank and have some rags to soak up the kerosene that will come out when you remove the two screws. Take the top off the fuel sump and inspect it also. Kerosene sometimes gels up after sitting a while. The fuel nozzle also gets clogged with carbon from time to time. You can clear this by removing the fuel line from the combustion chamber and inserting a piece of wire into the hole about 2 inches. Another possibilty is a dirty flame rod. You can clean it with some steelwool.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 16, 2011 | Heating & Cooling
Toyo stove laser 73 throws a EE 2 code and back fan will not come on.
EE 2 can be caused by a couple of things but is usually a fuel issue or a flame rod problem. The circulation fan will not come on until the burner has warmed up. The combustion blower should start almost as soon as you turn the heater on. Turn the heater on and listen for the combustion blower. If it doesn\'t start, do you get an error code? If the blower started wait for the fuel pump to come on. It will start when the burner lights come on. If the fuel pump makes a loud ticking or thumping sound, it isn\'t getting any fuel. Check the fuel filter and the strainer in the fuel sump. Make sure the valve is turned off at the barrel before removing the fuel strainer. If the fuel pump is working normally, does the heater light up. If it doesn\'t, check the igniter. You can check that first if you want and have a clamp on ammeter. Place it around one of the igniter leads and you should read 2 to 4 amps when you turn the heater on. If the heater does light but then cuts off after about a minute, clean the flame rod. Unplug the heater before removing the flame rod because it may kill the circuit board if the heater is plugged in and the flame rod touches ground. Let me know what you find.
Jan 18, 2011 | Rinnai Toyostove Direct Vent Heater:...
Stove shuts down and code ee 2 or ee6 comes up , what is my promblem.
Probably a fuel flow problem. Does the pump start making a loud thumping sound before the heater cuts off. Check the fuel filter and the strainer in the fue sump. Turn off the fuel at the barrel before removing the fuel strainer. Also check the flame sensor. Unplug the heater before attempting to remove the flame rod because it may burn out the circuit board if it touches metal with the heater plugged in. Use some steelwool or fine sandpaper to clean it if it is dirty. Another possibility with the EE-6 is that it is overheating, however, since you are getting EE-2 also I would suspect that fuel is the problem. Another thing to check would be the fuel nozzle. It can sometimes get clogged with carbon deposits. Let me know what you find if this doesn't fix it.
Dec 27, 2010 | Rinnai Toyostove Direct Vent Heater:...
On l-56 stove an error code EE 8. what is this and can it be repaired?
The blower motor is not working properly. Turn the stove off and remove the front cover. Remove the lower baffle in the front. Remove the black hose that is about 1 1/2" in dia. If it breaks don't be surprised. Stick a pencil in the hole and spin the fan. Keep trying until it spins freely. If it spins freely from the start the motor is burned. Put the black hose back on and try to start. IF the hose broke you will need a new one. For now put some electrical tape around the break to get you going.
Keep us posted.
Tom
Oct 14, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyo stove laser 56 error EE56 what to do
I don't see an error code EE 56 in the service manual. Please verify the error code. What I do see is EE 6. This can be caused by several things. Most commonly a fuel flow problem or out of fuel. If you are out of fuel or the fuel just isn't making the fuel pump, the pump will make a loud ticking or thumping sound. You should check your filter at the oil tank, if you use an external tank. You should also check the strainer in the fuel sump located on the right side of the heater. Two screws hold the cover on. You need to turn off the fuel valve at the tank and have some rags to soak up the kerosene that will come out when you remove the two screws. Take the top off the fuel sump and inspect it also. Kerosene sometimes gels up after sitting a while. The fuel nozzle also gets clogged with carbon from time to time. You can clear this by removing the fuel line from the combustion chamber and inserting a piece of wire into the hole about 2 inches. Another possibilty is a dirty flame rod. You can clean it with some steelwool. Let me know what you find if this doesn't help.
Sep 21, 2010 | Heating & Cooling
Toyostove Laser 73 EE2
Not having a cleaning in the last couple years may be the problem. Carbon build up in the burner pot and on the flame rod (a chain of carbon) will cause the flame to not be sensed. Then the flame will burn out. A temp solution would be to unplug the stove, then unscrew and jiggle the flame rod to break the chain. When tightening the screws do not over tighten. You could also try hitting the edge of the pot to see if you can knock the carbon loose. You could also have a warped burner ring which would cause problems keeping the stove running.
Nov 03, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove Laser 56 EE 2 error
Tim,
I have been working on Toyo's for 14 years now. During this time I have never seen a flame rod that was bad except ones that people have broken themselves. The rod is just a piece of heavy wire that is insulated against the pot. It is almost impossible to mess it up. Now, that being said, you can have a problem with the flame rod being dirty or sooted. Since your stove is so new I would look at the fuel system. If it is clean I would go after the burner mat. There have been mats lately on new stoves that have caused them to soot up. When this happens the flame rod gets covered with soot and gives the EE2 message. A new stove that has a burner mat problem would be covered by the warranty. Bad fuel that causes a problem will not be covered. The other thing that is not covered is a stove that has had an iced up the exhaust pipe. A good dealer should be able to help you get the stove going and explain the warranty.
Tom Hawkins
hawkins111@gci.net
Jan 06, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove laser 73 heater with a EE 2 error
replace the flame rod. or it could be the computer board for the flame rod. flame rod detects the presence of a flame.
Dec 01, 2007 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
335 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
blender719
Level 1 Expert
Kenneth Wilson
Kenneth Wilson
Level 1 Expert
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
