Question about Lands Phones
I have a phillips dual phone voip 433. i have been away for a week and when i have returned, the phone could not connect. it is stated 'Search Base' and I get an engaged tone when i pick up the phone. what should i do?
I know this message come 2 yrs later but... I still have the same problem. Do you remember how did you solve it ?
Thx
Theo
Posted on Apr 09, 2011
  • 156 Answers
Check the base supply adapter(power)and Phone line.
Posted on Oct 12, 2008
I need software for rtx3045 dual phone compatible with windows xp
goto google search. type your software program. click if you see your software compatible xp. and download it
Oct 20, 2011 | SKYPE RTX Cordless DUALphone VOIP...
I have broadband cable service. My cable modem ic connected to a Linksys Dual band wireless router. My computer is then connected to the wireless router on USB port 2. My Link sys VOIP is connected to the...
First unplug your router, then unplug your modem and for 10 seconds. Next plug the modem back in and wait it to reboot(on mine this a series of 4 lights that light up in sequence, when the 4th light stops flashing, reboot is complete). Finally plug your router back in.
Sep 09, 2009 | Linksys Ultra RangePlus Dual-Band...
How do i connect my voip phone when it says unregistered?
Hello playballgolf,
There should be a menu option on the handset to allow you to register the handset to a base station. If it's not mentioned in the user manual then the Phillips support web site has a helpful link:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=VOIP3212G/37&slg=en&scy=US
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
martyshaw562
Jul 27, 2009 | Philips VOIP3212 IP Wireless Phone
Want to unlock Siemens Dual Phone DP450
How To Unlock Tesco Internet Phone Siemans DP450
Unlock your Tesco DP450 IP Phone to use this with other VoIP providers.
Gigaset Communications have created a process that enables Tesco Internet Phone subscribers with Siemens Dual-Phone DP450 to unlock the phone from the Tesco Internet Phone service. This will enable the phone to be used with other Internet Telephone services. This follows the recent news that the Tesco Internet Phone service is to be ceased from April 26th, 2010.
This is an approved method for unlocking the Siemens Dual-Phone DP450 defined and released by Gigaset Communications, the original supplier of the phone to Tesco. If this procedure is not followed exactly your phone might not work anymore. In this case Gigaset Communications cannot accept any warranty claims.
Unlock procedure
Your Phone should have the latest released Tesco software version, else this unlock procedure will not work.
On your handset:
BASE > SETTINGS > SOFTWARE UPDATE
Select and press OK Enter the system PIN (0000) and press OK
The base station establishes a connection to the internet or a local PC.
YES Press the display key to start the firmware update. If no update is needed, this will be displayed.
To unlock the WEB interface of the DP450, you need to enter the following service code. Please use the exact code as is described below, else your phone will not work anymore.
SETTINGS > BASE 94762001 (Now "Eeprom" must be displayed)
Insert the following number sequence: 01778 06183 06191 Press OK to finish the programming. "Saved" must be displayed on the Handset.
Then release the phone to be able to upgrade it with the latest Retail firmware version.
SETTING > BASE 94762001 (Now "Eeprom" must be displayed)
Now insert this number sequence: 04850 04351 04864 Press OK to finish the programming. "Saved" must be displayed on the Handset.
After this procedure you can upgrade your phone to use the latest retail firmware version.
SETTINGS > BASE > SOFTWARE UPGRADE
Please Note: The firmware update can last up to 3 minutes.
Your Phone is by default configured to use the Internet Telephone service, if you want to change this to set the default to the land line you need to change this in the web interface from your phone. How to do this, download the Gigaset S450 IP manual from the Gigaset web-site URL: http://gigaset.com/uk/en/cms/PageCustom ... nuals.html
Regards,
Smith Online
Apr 11, 2009 | Lands Phones
Phillips voip 841 mac driver
i use this phone via a mac. i don't recall any driver being necessary. but check philips website. type 841 into search box and then click software and drivers. link below.
good luck
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=CA&slg=ENG&cat=INTERNET_TELEPHONY_DEVICES_CA&sct=DUAL_PHONES_SU&session=20090612180105_70.79.183.10&grp=PHONES_GR&ctn=VOIP8411B/37&mid=Link_Software&hlt=Link_Software
Mar 24, 2009 | Philips VOIP8411B/37 IP Phone
Philips voip 841: no sound on skype calls, but fixed line works f
We have had this issue recently as well with both our parents and now our own.phone.
Simple solve I found here:
1. Remove batterys
2. unplug base
3. replug in base
4. Put batteries back in
Worked for us - must be a virus or something
Feb 16, 2009 | Philips VOIP8411B/37 IP Phone
Philips VOIP 3212
The VOIP321 from Phillips does NOT connect to your wireless router. It requires to be plugged into a USB port on a WINDOWS ONLY desktop computer, which needs to be left on/logged-in with Skype running to send and receive calls. It wont work with Vista either.
Additionally Since Skype Version 3.8.0.188 (Release date: November 19, 2008) and all later versions (including Skype 4 Betas) the software Phillips supply no longer works with Skype and the VOIP321 phone. The latest VOIP321 <a href="http://tinyurl.com/6b2xrp" rel="nofollow">driver from their website</a> suffers the same issue, even though it states "The VOIP321 USB Phone Driver V 3.8.3 which can be downloaded from Philips web site is compatible with Skype software version from V2.0.0.x until V3.8.0.x". This is plainly no longer correct with the latest stable release of Skype, V3.8.0.188.
Skype developers are <a href="https://developer.skype.com/jira/browse/SPA-599" rel="nofollow">unable to do anything about it</a> and Phillips wont update their driver (Quote "... no more development/fixes are being incorporated into the VOIP321.EXE file"). Phillips would probably rather sell you a newer bit of hardware.
Don't waste your time on Phillips Skype phone devices, as their driver support is lacking when Skype is updated, so you buy a product for a few hundred dollars and it becomes useless 12 months later.
Another reason to not purchase the Phillips Skype phones is that it is Windows Only. No Mac or Linux support or drivers offered.
Dec 16, 2008 | Philips VOIP3212 IP Wireless Phone
Base not able to connect to handset.
I successfully reset Radio Shack (Uniden) 5561 handset by reconnecting the battery while holding the '*' and '#' key, then press the right upper soft key near the LCD window. The display will indicate "EEPROM/RAM cleared!!" and will return the handset to the factory default condition - looking for a base to register to.
Dec 22, 2007 | Uniden 5.8GHz Cordless Phone
VOIP will not connect to Skype
pl go to computer oip icon will be displayed right click presson autoplay it will say interference by other device press ok you are in business all the best ramram
Oct 01, 2007 | Philips VOIP3212 IP Wireless Phone
Lands Phones Logo
107 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
