Savin 2513 Jam
This 2513 has a paper jam "A" that doesn't want to clear. I have removed all paper, shut the door, and it still shows paper jam. I turned power off at the red switch, opened the door again, shut it, and turned power on again. Still have the paper jam error on for door "A".
Any help would be highly appretiated!
Thanks,
Dan Krueger
    Problem Solver:
  • 52 Answers
Many printers have a paper jam alert.But you need to remove the jam the correct way. You can't just pull the paper from the machine. If you have the manual--look up the proper procedure to un jam the paper. The machine can detect if the paper is stuck and it will not know it is fixed if the proper method isn't used. The system has a mechanism that loosens the rollers to allow the paper to be removed without damaging the wheels.
Posted on Oct 13, 2008
How do I reset fuser code on savin 2513 with a sc544. I have checked the fuser lamp thermal fuses etc. From the power source in cable unplugged. The thermistor reads about 390 k ohms at room temp. It had a...
When reading the thermistor, grasp the sensing part between thumb and forefinger, if reading drops quickly the thermistor is probably goid, if so , unfortunately you may need a power supply board
Feb 12, 2015 | Savin Office Equipment & Supplies
Paper jam reset
make sure all access covers are closed...if they are then there is still paper somewhere inside the machine
Jan 19, 2014 | Savin Office Equipment & Supplies
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
Printer says to clear paper jam and press OK there is no paper jam
If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not
in the rear rollers, check the top door.
To clear a paper jam from the rear door
1. Turn off the HP All-in-One.
2. Press in the tab on the rear door to release the door. Remove the door by pulling it
away from the HP All-in-One.
CAUTION: Trying to clear a paper jam from the front of the HP All-in-One can
damage the print mechanism. Always access and clear paper jams through the
rear door.
Page 148 of manual here will show you more info as well as photos on hoto.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
May 01, 2010 | HP Photosmart C8180 All-in-One InkJet...
I have a Savin 2015 DP and it says that there is a paper jam. there is not, i have already cleared it and the light wont go off, therefore, my machine is out of service. any advice?
There is a sensor lever that gets stuck on these models. The sensor is located just below the drum . (might be on its own door cant remember) it should move freely if it is stuck in the jam position the jam wont clear.
If you still nee help reply and I will try and assist futher.
Good Luck
Apr 09, 2010 | Savin 9935DP Laser Printer
Says jam 2 check inside but there is no paper inside
make sure all paper is removed from paper cassettes. check all doors covers it is telling you to check. check fuser. you may have a swithc broken, bad or knocked out of position.
Oct 19, 2009 | Savin Office Equipment & Supplies
Sharp 5316 showing paper jam sign at right door but no paper
Shut it off, wait 30 seconds, turn it back on. If the path IS clear, the error will be gone.
Feb 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
Paper jam
Solution one: Clear the jam from the back of the All-in-One Follow these steps to clear a paper jam from the back of the product. Step one: Remove any loose paper Remove any loose paper from the input tray. CAUTION: Do not remove jammed paper at this stage. Step two: Clear the jam from the back CAUTION: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the product slowly and gently. Avoid touching the internal components of the product.
  1. Disconnect the power cord from the back of the product.
  2. Remove the rear door. Push in the two release tabs, and then pull the door toward you.
Feb 01, 2009 | Lexmark P6250 All-In-One InkJet Photo...
RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Jan 24, 2009 | Ricoh Aficio 150 Copier
253 people viewed this question
k24674
