Question about Philips 150S4FB 15" LCD Monitor
Philips 150S4 15" LCD Monitor Problem
My Monitor is Philips 150S4 15",I using Suddenly it 's source off ,the engine has broken down .I from Vietnam
  • 1 more comment
  • nhukhoa1109 Oct 12, 2008
    Thanks
  • Lou Ebert May 11, 2010
    Freetek, Very good solution you posted for nhukhoa1109!! I will only add that the temperature ratings of electrolytic capacitors should also have been mentioned in your post. You know, 85 deg centigrade vs 105 deg centigrade! louie12fix on fixya BYE. lmistyrel@aol.com
  • Anonymous Mar 17, 2014
    how can i fix my Philips 190CW8FB LCD Monitor's broken stand. or how can i find?
  • Philips Master
  • 5,568 Answers
If it just fails to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not likely be able to do the repair yourself.
Modern power supplies are designed to shut down if the current drawn exceeds the design level, which indicates that something the supply services or the supply itself has died.
If you are adventurous, you might pull the plug on the set, allow the set to sit overnight, gain access to the innards, and with good light, inspect any boards inside.
If you see one that has few ICs but many more larger discrete parts, this will be the power supply.
Again, before touching anything inside, especially on that board, allow at least several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
You are looking for components called electrolytic capacitors that are almost always cylindrical and mostly installed upright at 90 degrees to the board with leads passing through to the solder side.
This same type of component in smaller dimensions is still used in a horizontal package with leads bent down and passing though holes to the solder side.
The latter are becoming more rare since they don't lend themselves well to robot assembly.
Many failed caps (not all) will show signs of pregnancy when they fail, bulging unnaturally at the top when compared with others. Now and then, there may be traces of a crystalline deposit around the end where the seal failed from internal pressure.
These will have values listed on them in uFd & VDC and sometimes, a plus/minus number lying about the precision.
Some also have a date code (rarer) that will look like four digits:
2403 = 24th week of 2003
Most electronics suppliers have a stock of the various values but if they have a date code at all, try to get only those made before 2002 or after 2006.
The larger caps will probably be OK since the failure is likely related to functions other than brute-force filtering. A pretty good 'rule of thumb' is to replace any caps you see bulging of any value but especially those that are 100 uFd or less.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace it or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
If you choose to replace failed caps yourself, you will need a quality soldering iron with a small, preferably iron-plated tip, rosin core solder and a sponge which when wetted is used to frequently wipe oxidized solder from the tip this should be kept bright and clean and fresh tinning will keep it that way.
You should also buy some solder 'wick' with the iron; this is used to place on the solder you wish to remove and then heated with the iron. Properly used, the wick will absorb nearly all of the solder from the lands from which you wish to remove a component.
Posted on Oct 12, 2008
Osd main controls locked
I asked helpdesk Philips.
They think the monitor should be sent to them for repair.
If I send it. Sending, investigation and repair costs are more than a new one!
Actually nothing is broken, perfect view, and only the F**!ing massage appears every few seconds.
IS THE 2nd Philips monitor which broke down within two years. First one even inside guarantee limits.
MY SOLUTIONS:
1st: Stick a little Pin next to the button so it will stick. The Message keeps away!!! (Not a final, but a lot cheaper than send it over)
2nd: Never buy a Philips again.
Nov 27, 2011 | Philips 150S4FB 15" LCD Monitor
I have 17" LCD viewsonic
Yes you can if you can source one however it may be more cost effective to replace the monitor.
Nov 03, 2010 | Computers & Internet
I need to change the source on my tv to HDMI without my remote
Not sure if yours is the same but Philips codes work with Skyworth and if you hit the TV/AV button on the side of the TV and the table of options should come up. And then with the channel +or- go up and down till you are on HDM1 or where ever you want and then touch the TV/AV again when you are there.
Mar 27, 2010 | Philips 32PF5531D 32 in. LCD Television
42fd9925/01 screen not turning on
does unplugging it for 5 mins and plugging it back in help?
i'd call philips support, might have to get it repaired.
Jul 14, 2009 | Philips 170S5FB 17" LCD Monitor
Philips 170S6 backlight goes down after 1 sec
I have also a problem with this mains/inverter board i have found that one component trafo IT E19 nb4004b was damaged from the upper ccfl measured 0 ohms the other it e19nb 4005b from the bottom ccfl measured 0.512kohm was good.
Jul 08, 2009 | Philips 170S5FB 17" LCD Monitor
Not sure how to connect other devices
Unfortunately, the Westinghouse monitor has a bunch of inputs available, but completely lacks the audio output connection you need that would make life simple. Your Philips HTS only a single auxiliary audio input, but it does offer video and audio output connections to a monitor.
About the only solution I see available is to buy an A/V selector switch (available from Radio Shack and probably stores like Best Buy). Run the audio connections from the HD receiver and XBox through it, and send the output from the selector switch to the auxiliary audio input on the HTS6500. (You could use RCA Y-adapters to connect the audio to the monitor as well as to the selector switch if you really want to.) Send the video from these sources directly to the monitor.
You would need to select the source on the monitor, A/V switch and HTS to get the result you want, but it would be workable. (Now, why didn't Westinghouse simply include a set of audio output jacks with all those sources available?)
If this solution has gotten you going, please take a moment to rate it. And thanks for asking here!
Feb 25, 2009 | Philips HTS-6500/37 System
Philips monitor 190b6cb/175
Same problem OSD main controls locked the 5 seconds later OSD main controls unlocked then system closes down sayingproblem with atkdisp, what does all this mean? Can still operate my computer but thid damned flashing OSD message continues.
Aug 10, 2008 | Philips 150S4FB 15" LCD Monitor
Crt monitor problem
try to check the pincusion...
Jun 27, 2008 | AOC LM729 17" LCD Monitor
Screen split into 2 colours - vertical split
I think it is degaussing problem if any thing is lying which has magnet please remove it. &then put of monitor for 15 minutes & then put on again.do not move when it is on. please let me if it gets ok good luck
Sep 09, 2007 | Philips 170B4MG 17" LCD Monitor
Philips 150S4FB 15" LCD Monitor Logo
491 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
