Question about JVC AV-32260 32" TV
JVC D SERIES TV NO PICTURE AND SOUND
JVC D SERIES TV NO PICTURE AND STEADY SLEEP TIMER LIGHT ON FRONT DISPLAY.
  • 1 more comment
  • cp12912 Nov 05, 2008
    I have the same problem with mine. JVC AV 32D305 set. PLEASE HELP!
  • valwal Nov 08, 2008
    tv won't turn on but has on timer light blinking
  • Anonymous Dec 09, 2008
    My JVC had the same problem this morning. Green light glowing, no response to power button or remote, no picture, no sound.
    I unplugged it and plugged it in again. It works now. I wonder for how long?
premtech
  • 934 Answers
SOURCE: JVC TV - No Pic or Sound-Blinking Red Timer Light
I believe I've answered this one or one identical to it:: If not, No sir... Nothing short... The red blinking timer light indicates the the protect circuit has it shutdown. That's happened because something has probably shorted along the B+ line. If it were here in the shop I would be checking the following: IC911 Str-G6624 regulator PC921 Tlp421 F905 5a Pico Fuse C931 160v/100uf cap and the HOT of course 2Sc2539 One or more of these parts has probably failed but usually not all of them.. So it's not an expensive repair. Now, while you're having that done also have them do the following modifications for greater reliability if it hasn't been done already: Remove D701 you don't need it. Install C705 (47uf/16v) in space provided (near Ic701 Pin 22 ) Replace jumper W122 with ferrite bead (Qqr0582-001z) Add a cap(47uf/16v)between pins 61 and 64 of Ic701 neg to pin 64 and pos to pin 61 This is per a JVC bulletin that the shop you take it to may or may not have. It's a simple and inexpensive modification and will add a measure of reliability to the years this set has left. As a footnote, take the set into the shop yourself and pick it up when it's done. This will help keep the cost down. All-in-all should be less than $150 if all the parts above got replaced. If you have any questions don't hesitate to ask. Hope this helps Bill 360-642-4993
Posted on Jun 07, 2007
redcrx
  • 7 Answers
SOURCE: JVC tv "stuck" on sleep timer
I think you would have to turn off the sleep timer mode completely or increase its ON time span, say to 4 hours or so
or the lenth of time you have the TV on for. If that does not fix it then it sounds like a STANDBY MODE fault problem.
Hope this helps.
Posted on Feb 06, 2008
  • 1011 Answers
SOURCE: JVC N Series TV "stuck' in sleep/timer mode, won't wake up
dear,
switch off the pulg from the wall socket and leave it off for half hour then try it again..
if not try to operate it with its tv panel buttons
regards,
dont rate it until u satisfied with the solution
Posted on Sep 26, 2008
  • 142 Answers
SOURCE: jvc tv av-32d502 timer light is flashing will not turn on
Hello, I am a tv tech. I worked on a JVC AV-32D502 today. Problem: led flashes / no power or picture at all. Same as trobertson52's set. The microprocessor is bad in my machine. trobertson52, if your sets' relay does not click when the power button is depressed you most likely have the same problem or the standby power circuit is at fault. That circuit supplies +5 volts to the micro.
Edtal you have a different problem with your machine. Your machine is going into shutdown. A number of circuits could cause this and would need to be looked at by a technician to determine exactly which circuit is at fault. High voltage transformer (HOT) \ Vertical Circuit \ Power supply are the most likely causes.
barneyinNC
Posted on Sep 30, 2008
i can turn on my t.v. because it has a timer on, what can i do.
Posted on Oct 05, 2008
I need to know the service mode of JVC TV flat screen
With TV powered ON press: [DISPLAY] and [VIDEO STATUS] on the remote at the same time.
-or- Press the [SLEEP TIMER] key and set the SLEEP TIMER for "0" MIN. While the SLEEP TIMER information is still on screen, press the [DISPLAY] key and [VIDEO STATUS] key of the remote control unit at the same time to enter the SERVICE MENU.
Exit the service menu by twice pressing the [EXIT] key on the remote.
Mar 18, 2011 | JVC AV-32S575 32" TV
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
Blinking timer light, No picture or sound.
Ur high voltage is dead,the FBT,the flyback transformer,the big black block of plastic with a red wire with a cap hook to the CRT(tv tube).That is dead.
Sep 27, 2009 | JVC AV-36D302 36" TV
JVC AV-32F476 on timer green no picture no sound
Power supply failure, expect to pay $100-150. worth the investment JVC made some good tvs Julio milleniumtvsvc@gmail.com
Jul 22, 2009 | JVC AV-32F476 32 in. Television
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
JVC AV48WP74 Service mode
Press SLEEP TIMER and, while the indication of (SLEEP TIMER 0 MIN) is being displayed.
press DISPLAY and VIDEO STATUS on the RC simultaneously. Exit: EXIT.
Jul 04, 2009 | JVC AV-48WP74 48" Rear Projection...
JVC 27" D series
there is another problem that requires a tv repairmans expertise when the timer light flashes continuosly ,and the power is not restored.
Apr 21, 2008 | JVC AV-27D502 27" TV
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
JVC Vertical Problem
You need to adjust the vertical height in the Service menu.Press the SLEEP TIMER key and set the SLEEP TIMER for 「0 MIN」. Then press the DISPLAY key and VIDEO STATUS key of the remote control unit at the same time to enter the Service menu.In SERVICE MENU, press the FUNCTION ▼/▲ key to select any of the SUB MENU items. (The letters of the selected items are displayed in yellow.)You want #2 DEF - go to sub-menu and look for the height adj. FUNCTION / key Setting (adjust) the SETTING VALUE of the SETTING ITEM. When the key is released the SETTING VALUE will be stored (memorized). EXIT key Returns to the previous screen.
Aug 22, 2007 | JVC AV-27320 27" TV
JVC AV-32260 32" TV Logo
433 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
