Question about Whirlpool Washing Machines
The machine flashes f1 - Whirlpool Washing Machines
  • 750 Answers
Hello madelinezak
Welcome
F1
“F##” code
Press PAUSE/CANCEL once to clear code. Press START. If
code appears again, call for service.
Thank you, Huuum
Please remember to leave a rating
Posted on Oct 12, 2008
What's code F1?
It Means: Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
See Accessing & Removing the Electronic Assemblies.
Jan 23, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My kenmore elite washer, model #110.27092600 flashes an f1 error code when filling
F1 code = Primary Control Failure. Replace the machine/motor control assembly.
Call 1-800-659-7026. That machine has a recall for the control board and if your machine is in the recall they will fix it for free.
Jul 30, 2011 | Kenmore Washing Machines
What is code F1 mean on the Whilrpool Cabrio. The washer stops about 5 seconds when I first put it on.
Ok the Cabrios have alot of problems. In your owners manual there is a big page where it gives you errors codes and what to do it also givees you a diagnostic feature which helps determine the problem. This site gives you the fault codes and what to replace. F1 means primary control failure. Also sometimes when the control board is bad something else could also be wrong. Good Luck
F1 (F60-68)
See Accessing & Removing the Electronic Assemblies. F1 (F60-68)
See Accessing & Removing the Electronic Assemblies.http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Jun 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool Cabrio top load washer. When I load the clothes and start the washer and it begins to run I hear an alarm, it stops and a F1 flashes on the display. What does this mean?
F1 (F60-68)
F1 flashing on the display indicates a primary control failure.
"F then 1 flashes when there is a primary control failure. Replace the machine control assembly."
The link below lists Cabrio failre codes.
Dec 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 comes up everytime you wash a load of laundry.
F1 = Primary Control Failure
Thank you
Sep 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Alert F1 when starting wash cycle
Thank You
Sep 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
How to shut off dishwasher? F1 is flashing on control panel.
Hi now F1 mean that your machine has triggered the flood alarm. there are two reasons this happens-- 1st-- there is a leak on one or both of your drawers. they leak because you might have a hole in one of the hoses or your lid is not shutting properly etc. the 2nd reason is that some water or soap suds escaped from the overflow. now i would like you to turn the machine off at the wall and leave it off for a couple of days to dry it out. then turn it on and use the lower drawer for one cycle. if it does not go F1 then try the top drawer for one cycle and see how it goes. if it continues to flash F1 then reply back for further help. good luck.
Jun 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher keeps flashing F1
F1 on your dishwasher is the fault code for leaking inside the machine. the water has caused the flood switch to activate. have you put any detergent rather than your normal dishwasher detergent into the machine? if you have, the water probably leaked out of your overflow, if not, then you have a leak on the top drawer or bottom drawer. the easiest way to check is to leave the machine off for a couple of days until it drys then turn on the bottom drawer to go thru a cycle.if the F1 comes up again then the problem is on your bottom drawer. if F1 does not come up then try the top drawer. please reply if you require further help.
May 28, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
What does f1 mean and can it be fixed?
F1 means Primary Control Failure.F then 1 flashes when there is a
primary control failure.Replace the machine control assembly and
see accessing and removing the Electronic Assemblies.
Apr 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 fault is flashing and machine is stoping
Code F1 means the central electrical control unit, i.e. the onboard computer, has fatally failed
Widespread problem, lots of machines have had this issue. I think there is a recall on this machine. Check it out-
Whirlpool Cust Svc. 1-866-698-2538 Have the model & serial off the back handy
Dec 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
55 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
