Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Blurry, AF not working
I've had my Nikon D40 for over a year and just encountered my first problem. I can only focus on objects close up, everything more than 6' away is blurry. I've changed settings, charged it and lenses, but it still won't focus. Is there something I'm missing or should I take it into a shop?
    Master:
  • 383 Answers
Try resetting the camera to it factory condition ..... also open lens and clean the contacts...and then try
Posted on Oct 12, 2008
The auto focus does not work properly with this lens on either my Nikon D5000 or D7000. I have tried all possible combinations of AF settings. Typicaly, when I use single point to focus, the subject I...
Hi, It wouldn't autofocus on the D5000 as the body doesn't have an auto focus motor in the body and since that lens is AF, not AF-S, it won't autofocus. It should autofocus on the D7000 though, how far away are you from the object you're trying to photograph?
Aug 28, 2011 | Tamron SP AF 17-50mm f/2.8 XR Di II LD...
Nikon Cameras specification.
Some charts are on the web. Search for your model of camera and compatible lenses.
Sep 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
D40 Autofocus problem
The auto focus on modern cameras is pretty intense, I would recommend taking it in for repair.
Aug 11, 2009 | Nikon D40x Digital Camera
Nikon d40 not working and focusing
I have similar problem on my D40. I think there is something mechanical with the camera's shutter button, some connections, I guess... The only solution I've found is to go to Menu > Custom Settings Menu > "AE-L/AF-L" and set to "AF". Now you can focus by AF-L button. Focusing works then perfectly. The WORST thing is that I can't lock exposure now and that's sad :( Maybe I can try to fix this in the camera center later, we'll see. But it takes months in Ukraine to do the fixing... Hate that!
Jun 22, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Best Auto focus Tele For Nikon D40
hi ! iam too a D40 holder,u can opt for AF-s versions or HSM sigma,both of them autofocus on d40,can go for 18-200 AFs VR or if u need still longer end go for 70-300 but it is costly than the sigms 70-300APO DG HSM MACRO..,its a much better reviewed lens and dont forget the cost..anyway do some research before considering..good luck
Mar 14, 2009 | Sigma f/NIKON- 28-90/3.5-5.6 Aspherical...
Nikon d40 wont autofocus
Your 28-90 AF-D lens can't autofocus with the D40, which requires AF-S lenses with a focus motor in the lens. Sigma lenses with "HSM" (HyperSonic Motor) in the name also have the focus motor.
Feb 23, 2009 | Sigma f/NIKON- 28-90/3.5-5.6 Aspherical...
My d40 won`t take pictures
Try Blow cleaning the Memory card slot ... sometimes dust does that
Oct 05, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40 autofocus
Look on the left side of the lens. Make sure the button is on A for auto focus and not M for manual. OR not stuck in the middle. Hopefully that will solve the problem.
Jul 11, 2008 | Nikon D40x Digital Camera
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Apr 19, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Sigma 55-200mm F4-5.6 DC
The D40 will only AF with lenses that have their own focusing motor (Nikon AF-S and Sigma HSM). This lens will not focus.
Aug 10, 2007 | Sigma 55-200mm f4-5.6 DC Lens
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
62 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
