Question about Garden
Chainsaw won't keep running except on full throttle?
I have a craftsman chainsaw that will start but only keeps running on full throttle. What would cause this?
  • 1 more comment
  • table70 Oct 14, 2008
    I have Poulan 3416 it will not idle anymore looks like maybe a screw is missing. how do i find out?
  • Anonymous Mar 13, 2014
    replacement of a throttle cable on a 16 inch craftsman chainsaw
  • Anonymous Mar 26, 2014
    s310 chainsaw chain runs when not being used just idling
    Novelist:
  • 99 Answers
Running at full throttle but not at idle would probably be caused by not enough air getting through to the cylinder with the fuel. This could be caused by blocked/dirty air filter, air leak or worn/damaged piston or cylinder. The higher the revs are the less air to fuel ratio is needed so it will run at these speeds. First check your air filter, if that is fine take the spark plug out and examine the inside of the cylinder. You will need to check here with the piston down. If you want to be a bit more thorough you can remove the exhaust and check the piston face and inside the cylinder from here aswell. You don't want to see any scoring or solid lumps of anything in here. While you have the exhaust off give it a few firm taps to make sure there is no major carbon build up and clean the spark arrestor if it has one. The arrestor is normally a small gause found on or near the exaust outlet pipe. If that all seems fine then get some soapy water and squirt it around the carb gaskets and pipe that runs from the carb to the cylinder. If you see bubbles appearing here when the machine is running then you have air escaping and it will need investigating. Failing this you could have worn piston rings or crank seals. Ideally to test this area you need proper pressure testing equipment.
Posted on Oct 27, 2008
Chainsaw runs fine than goes full throttle all by its self and cannot shut it off with switch.
Kill switch is broken or disconnected. Throttle linkage is broken or disconnected or idle is set way too high.
Oct 26, 2013 | Craftsman 2.5 Turbo Chainsaw Throttle...
Starts with starting fluid runs for a few seconds then shuts down
Good test. Do not keep doing that.
Make a new and accurate gas/oil mixture. Empty and refill. Secure cap. Be sure to flood system during start attempt. Can you smell gas? Oops, too much, better wait 30 seconds for full evaporation.
Two little screws near carb. Both are actually needles and probably have a visible spring which keeps them from vibrating to a new position while in use. One fuel/air mixture at low idle (start). One fuel/air mixture at high RPM.
Try 1 1/2 full turns open from fully closed. Once to get it to idle roughly, adjust to a smooth idle. Do the same at full throttle. You will notice that the more you shut the full throttle down, the higher the RPM will go (assuming that it is near correct). Do not run it to lean. The mechanics of the motor needs the oil from the gas.
Smile always.
Jun 03, 2011 | Garden
210 2 stroke leaf blower it starts when choked and idles when choked but when i pull the throttle trigger it cuts off. I cleaned the air filter and replaced the plug.
hi mike. most likely problem is junk in the carburator. Get a can of starter fluid and an assistant. Remove the air filter. Start it up and before you pull the throttle have your assistant squirt the starter fluid into the air intake. Use more starter fluid as needed to keep it running for about 2 minutes to clear it. Joe
Apr 14, 2011 | Craftsman Garden
Carb adjustments/ rule of thumb
Assuming that the adjustment screws 'H' and 'L' have slotted heads, turn both CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on. Turn H CW until the engine starts to speed-up, but still 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW for fairly smooth running, yet allows the engine to 'follow the throttle'. Adjust idle speed so that the chain stops turning, but the engine keeps running.
May 21, 2010 | Husqvarna Chain Saw 20" Bar
Won,t run full throttle
The problem could be a plugged fuel filter located inside the gas tank itself. Drain the gas. You can fish it out by using a hook of some sort. Then Replace with FRESH gas. If thats not the problem you have yourself a gummed up carb. Possibly from leaving fuel in it when out of season. Take apart the carb and spray with carb cleaner. Check all holes and screens on the top as well as the metering lever and diaphram on the bottom. They make model specific rebuild kit based on the model of the carb itself.
Sep 14, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Need carberator settings for a sears craftsman chainsaw model#358.354831
You don't want to tighten them down just turn them in until the are just snug and then turn them out.
Start with the low at 2 full turns out and the high at about 1 full turn out. Start the saw and let it idle adjust the low idle to where it runs smooth. Adjust the high until the saw runs as much rpm as you can get at w.o.t. (Wide Open Throttle).
Jul 11, 2008 | Electrical Supplies
Garden Logo
1,847 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
