.failed to find an appropriate
    Genius:
  • 1,605 Answers
Defaul back to vga. go to contrl panel and dispaly. make sure the video frequency is not over spec. (60Hz, 70Hz or 72HZ) max. try to insatll the video driver again.
don't try to install video software the monitor or the video card can't handle
Posted on Oct 12, 2008
How to stop Windows 10 from automatically restarting after idle for around 5-15 minutes.
The kernel power event ID 41 error occurs when the computer is shut down, or it restarts unexpectedly. When a computer that is running Windows starts, a check is performed to determine whether the computer was shut down cleanly. If the computer was not shut down cleanly, a Kernel Power Event 41 message is generated.
Before we proceed with the troubleshooting steps, please answer the questions given below.
a)Do you remember making any changes prior to this issue?
b)Did you check if all the drivers are up to date?
Let us follow the methods given below.
Method 1: Run System maintenance troubleshooter.
Follow these steps:
a) Press Windows key + W on the keyboard
b) Type Troubleshooter then click on Settings under the Search field
c) In Settings click on Find and Fix Problems
d) Click on System and security
e) Click System maintenance follow the prompts from there.
Method 2: Try booting the computer in safe mode and perform a clean boot.
Step 1: Perform Safe Mode
Click the link and follow the steps "Windows Startup Settings (including safe mode)"
http://windows.microsoft.com/en-US/windows-8/windows-startup-settings-including-safe-mode
Check if you face the same issue in safe mode. If the issue doesn't persists in safe mode, the place the computer in clean boot and check.
Step 2: Perform Clean Boot.
To help troubleshoot error messages and other issues, you can start Windows 8 by using a minimal set of drivers and startup programs. This kind of startup is known as a "clean boot." A clean boot helps eliminate software conflicts.
http://support.microsoft.com/kb/929135
Important: Reset the computer to start as usual.
Note: After you have finished troubleshooting, follow these steps to boot to normal startup.
a) Press the 'Windows + R' key on the keyboard.
b) In the 'Run' windows type 'MSCONFIG' and click 'Ok'.
c) On the 'General' tab, click the 'Normal Startup' option, and then click 'OK'.
d) When you are prompted to restart the computer, click 'Restart'.
If the issue persists, I would suggest you to perform a system restore and check if it helps.
Method 3: Perform a system restore.
Refer to the link given below and follow the instructions for system restore.
How to restore, refresh, or reset your PC
http://windows.microsoft.com/en-US/windows-8/restore-refresh-reset-pc
Also refer to the article given below.
Windows Kernel event ID 41 error "The system has rebooted without cleanly shutting down first" in Windows 8, Windows Server 2012, Windows 7, or Windows Server 2008 R2
http://support.microsoft.com/kb/2028504
hope this helps
Jan 13, 2016 | Computers & Internet
How to reset a playstation 3
- first you need to enter safe mode:
How do I access Safe Mode?
  • Check that the power indicator on the PlayStation 3 system is solid red.
  • Press and hold the PlayStation 3 system's power button for ten seconds. The PlayStation 3 system will shut down.
  • Release the power button.
  • Press and hold the power button for seven seconds. Two short beeps will be emitted and a message will be displayed on-screen.
  • Press the PS button on the wireless controller to start the PlayStation 3 system in Safe Mode.
- once in safe mode you will have the option to
Restore Default Settings,Restore File System,or Restore PS3 System (warning: the last option will erase all of your data from the ps3 hard disk drive so if you choose this option I suggest you backup your data first) for instructions on how to do that please visit this page :
https://www.playstation.com/en-au/get-help/help-library/system---hardware/storage---data/back-up-the-playstation-3-hard-disk-drive--hdd-/
Aug 12, 2015 | Sony Playstation 3 (PS3) Console
I am unable to access the internet from sleep mode Can only get on internet from shut down mode
Three possible causes of sleep mode. first, an extensive screensaver with password lock prevents display. A condition that is observable as a blankscreen also known as sleep mode. Second, a computer power saver settings that shutsdown during idleness. Third, An improper shut down of the computer would have caused a sleep mode to save the system data files.
Restoring the computer to regular functionalioty
First solving predictable sleep mode settings
1. A movement of mouse pointer across the screen should reestablish unprotected password modes
a. password protected sleep mode would display an promp message requiring key code soon after the mouse pointer has changed direction
sloving unpredictable sleep mode settings
1.A computer power saver, screen saver, or splash screen displays prevnting programs acess would require manually powering off the computer system.
a. A manual power back on of the system should restore to program functionality mode
important notes
1. contact expert technical assistance
Dec 20, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
Hi, My desktop 5100 has just developed a problem in that it shuts down without warning and then reboots up nad then shutdown. my wife saw the [Ithr] Checkpiont failed flash across the screen - do you...
plz. again restart ur pc then press F8 key just use safe mode then u receive a restore msg. plz close it and then tust go to start menu then all programs then accessories then just go to system setting after that u seen system restore program then please open it and then choose ur last good configeration date and then u restore ur window!!!
bye & good luck!!!
Sep 23, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
COD 1.3 build win-x86 Mar 2 2004 -----
For this you have to back up your file and they it can work or you can restore the computer that day when it was good . Just cilcke on Strat then click on programmes and accress and system tools and and at last clike on system restore ...
Jul 11, 2009 | Computers & Internet
Default printer factory settings Lexmark X8350
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Apr 27, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Change default ptr setting for lexmark x8350
4. Press "Select."
7. Press "Select."
Opengl drivers needed &'' Q_strncpyz: NULL src '' error
Hi, had similar problem myself, the problems are either you don't have a sufficient graphics or video card or you don't have or are not up to date with OpenGL drivers. The trio 32/64 graphic card is not one that is most likely to run with this game, because i had one for my old machine and came up with exactly the same problem, i will give you OpenGL updates but my solution is get yourself a better graphics card for Quake III Arena
http://www.versiontracker.com/dyn/moreinfo/win/18800 - This is the site for the update, scroll until you see 'Download' should be under Additional Requierments
This is the minimum in Graphics cards that will run with Quake III
All 3dfx chips and higher
nVIDIA Riva 128 and 128ZX and higher
Matrox G200 & G400and higher
ATI Rage Pro & Rage128 and higher
nVIDIA Riva TNT and TNT2 and higher
Intel i740and higher
nVIDIA GeForce 256 and higher
Hope This Helps
Nov 21, 2008 | Video Game Consoles & Games
HE tratado de instalar CALL OF DUTY , Y PIDE ARCHIVO OPENGL
you need to uninstall the game and reinstall and make sure your disk is clean i have had this myself
Nov 16, 2008 | Tablets & eReaders
Computers & Internet Logo
David Payne
David Payne
