Question about Amana ATB1935HR Top Freezer Refrigerator
Freezing problem food in the refrigerator are freezing(milk, salad, condiments etc.) food in the freezer are not completely frozen (soft icecream, frozen meats are a little soft) but the ice cubes are frozen. Maybe the take a little longer to freeze. Should I just throw this refrigerator away?
  • helga27 Nov 02, 2008
    It's set on the lowest cold setting and things still freeze. Coil have been cleaned. Also, the light is not not working and new light bulbs do not solve the problem.
  • 943 Answers
HI thanks for your question. try turning the thermostat to a lower, number. and clean all the coils at the back by the compressor. it might be all you have to do/ thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 12, 2008
I have a Maytag refrigerator with above freezer. Model # MTB1956AEB. All of a sudden, the freezer doesn't keep the food frozen. It still works, icecubes are frozen, but icecream is very soft, as if the...
It sounds like your defrost assembly has ceased to function and you have ice build up on the thermostat telling the freezer it is cold enough. Pull power. Take the food out of the freezer, remove shelves and bins, remove inside back cover. IF there is a lot of ice build up behind it then you can either leave the door open so that it will defrost or use a hair dryer to speed the process up.
Once the ice is cleared out, you can plug it up and see if things start working again. At least the freezing and getting cold part. If this worked then you will need to order the defrost assembly using the information from the information plate inside your refrigerator, then install it.
Jun 04, 2011 | Maytag Refrigerators
Fridge compartment keeps freezing contents, despite being on lowest setting
Most likely a faulty thermostat, not turning the unit off correctly or at all. My guess is your freezer food is rock solid....do you need a jackhammer to scoop icecream?you dont have icecream??? <gasp> bread, which would normally be frozen, would be stiff like roofing tiles, or if a thermometer is handy, it would read will below -5°F in freezer. that would be the problem on 90% of refrigerator freezers. If ytou have a GE, side by side, it could be something else entirel.
Visit: www.FixMyFridge.net for Chicagoland Refrigerator Repair Service or read our FAQ and Tips.
Mar 22, 2010 | Refrigerators
Fridge compartment is freezing food/milk etc
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 06, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Ice Cream and frozen waffles won't freeze.
LOL ! SO in other words in plain english your repair man told you needed a brand new refrigerator - Ok from your description here we can rule out low refrigerant or compressor problems, defrost timer and controlboard issues. I too have waffles and they DO get frozen although not as hard as ice - the less water molecules they have the less they are frozen hard. but nonetheless, my waffles are NOT soft, neither is ice cream
What I would ike you to do is put one of those refrigerator/freezer type thermostats, you can get those round ones, place it in your freezer leave it there 24 hours and look again - Optimal freezer temps is 0F once compression cycles off - if you areusing the extra cold setting, -10F - For refrigerator don't go over 40F - optimal temp of 36-38F.
Another method you can place a bowl of water and use one of those probes and measure the temp of the water in your fridge. If your temps are within safety levels do not worry - your ice is frozen and your frozen food is frozen - Some ice cream tend to be softer, especially the extra creamy type. If your refrigerator has a dial to adjust temps, raise it slightly and wait 24 hours and check your temps again you might need to bump down the temps a bit - if you have a control panel and 2 settings they are usually COLD or COLDER, set it to COLDER and check again - in the COLDER setting your compressor will shut down once your freezer hits -10F that should be quite enough to have even your waffles and extra creamy icecream frozen - if some of the liquids in your refrigerator is too cold or freezes, set it back to COLD or re-adjust the dial. Once you determined that your freezer AND refrigerator are within SAFETY levels as per the food safety guidelines and using the proper methods of testing, then you have nothing to worry about. Make sure your fridge and freezer are not leaking cold air by checking your door gaskets using the famous dollar bill technique by closing the door on the dollar bill and trying to pull it out - if there is no resistence and can easily come out, you have a gasket leak - check in different places on the gasket. As long as you can determine that your freezer and fridge temps are SAFE don't spend a dime ! If your temps are NOT in the safe range you probably have leaky gaskets - if the compressor seems to run all the time, you probably have dirty condenser coils that need to be vacuumed cleaned or dusted off using a condenser brush.
Aug 17, 2009 | Amana Refrigerators
Freezer not freezing ice cream and milk
Icecream is a tough call. Some brands have to many artaficial ingredients and that doesnt get solid. What temps are you getting in the freezer? Is everything else frozen solid?
Jul 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Food not totally frozen, icecream melted
if it a frost free freezer then chances are it is a defrost hearter, fan motor or defrost timer
if it is not frost free then it will either be the compressor or a gas leak ( which should be under warranty)
Apr 29, 2009 | Frigidaire 16.8 cu. ft. Upright Freezer...
Freezer does not freeze fast enough, icecream gets soft
Faulty Cold control (Temperature Control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
This is usually not a do it your selfer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 25, 2009 | GE GTS22KBP Top Freezer Refrigerator
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not keeping things frozen
Ice cream requires a significantly lower freezing point than other foods. Keep it near the blowers or coils in most freezers and you'll be OK. Turn up the freezer a bit, and if it is all the way then move it away from the wall a bit more hope this helps!
Jul 26, 2007 | True GDM-49FC Refrigerator Commercial
Amana ATB1935HR Top Freezer Refrigerator Logo
335 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
