Question about Canon MP520 All-In-One InkJet Photo Printer
MP520 ERROR 5700
Cannon have come back with"check there are no objects inside printer" but how can there be if this is a new machine? The problem is because the machine cannot read the ink.But i have installed them as stated.
  • cms5567 Nov 24, 2008
    Do I really need to unassemble the entire printer to get it to work.
    Surely you gest..
  • parkba Mar 27, 2009
    I have the same problem error 5700 alternating with error 6a80. I want to perform the steps mentioned but I don't understand how to remove the left and right covers and the main case unit.
    How does one perform Step 1 : remove left and right covers and the main case unit?
  • 1,029 Answers
5700 is a ASF cam error most likely. Here the Canon proceedure for fixing it!
DESCRIPTION: 5 Alternating Blinks (SFP) / ##356 (MFP) - ASF Cam Sensor Error
SOLUTION(S): Adjust the Screws & Main Case Unit
Movement (i.e. from shipping) may cause the plastic guide to move away from the chassis. When this
occurs, the gears cannot rotate properly causing a grinding noise and 5 alternating blinks (SFP) or ##356
(MFP) - ASF Cam Sensor Error.
Procedures
Step 1: Remove the Left and Right Covers and the Main Case Unit (main cover).
Step 2: Remove the 4 mounting screws from the Chassis.
Step 3: Remove the Main Unit from the Bottom Case.
Step 4: Turn the Main Unit over (upside down) and place on work surface.
Step 5: Inspect the ASF section of the Main Unit for a gap between the white plastic guide and the Chassis.
Note: The size of the gap varies. Even if the gap is not visible, complete the steps
below.
Step 6: Disconnect the appropriate cables and remove the Logic Board from the Chassis.
Step 7: Loosen (do not remove) the 4 mounting screws (the mounting screws can be found behind the
logic board) on the Chassis.
Step 8: Re-seat the white plastic guide so it sits flush against the Chassis. The tip of the white plastic
guide should sit slightly inside the
mounting screw hole. When seated correctly, the gap will no longer be present.
Step 9: Tighten the 4 mounting screws without
causing the plastic guide to shift.
Step 10: Reassemble the printer and retest.
hope this helps
Posted on Oct 12, 2008
  • 4 Answers
Although you can't see something, I believe there is something stuck, i had the same problem and manage to find and earring and £5 note!!!!
Please email me and i'll explain how i found and got them out :-)
Davinia.uk@gmail.com
Posted on Apr 01, 2010
  • 446 Answers
Chances are there is still some packaging strip or materials left inside your printer, nor any obstruction in the paper path, or the sensor device isnt tripped off
What is error code 5700?
I have seen this error a few times through the use of our inklink products.
The error 5700 is as follows:
This error takes place when feeding paper
from the ASF after an error occurred in the
ASF cam sensor.
Make sure that there is no paper jammed in the printer and nothing is blocking the paper path.
Oct 15, 2013 | Canon PIXMA MP520 InkJet Printer
Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
Sep 02, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
I HAVE ERORR CODE 5700 ON MY CANNON MX700 , HOW TO FIX IT
5700 is a sheet feeder error, if there is not something caught inside like a ink pen, paper clip, or kids toy, you might need a new feed assembly. Not too expensive, but a shop repair only.
Aug 03, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Error 5700 on lcd screen tried turning it on and off problems not resolved,its only 6months old
5700 is an error in the paper feeder unit, could be a broken gear, or sensor. The only repair is to replace the sheet feed unit. Canon gives a one year warranty, should be repaired at no charge to you. 1800-OKCanon
Jul 09, 2009 | Canon PIXMA MP520 InkJet Printer
5700 in mp520
Canon is fairly standard with their error codes no matter the model. Error Code 5700 basically means the paper sensor is not working properly. If this is the case then you will need to buy another printer. Most repair shops will charge more to fix the old one then you would spend on a new one. Sorry for the bad news. Although, I would strongly suggest you contact Canon Tech Support to validate this information. You can reach them at the number below between 8AM and 12 Midnight EST. Good Luck!
Canon Tech Support: 800-828-4040
Jun 08, 2009 | Canon MP520 All-In-One InkJet Photo...
Error 5c00
check in inside the fusing unit by the roller.
May 12, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Error cannon pixma mp520
Turned it on, off many times as instructions suggest,
etc no dice. Reinstalled software, did everything including giving it a few taps.I was very seriously ready to buy a new one and trash this one, even checking flyers. I read where so my are having this same problem.
In my anger I started pushing all the buttons randomly and suddenly the green light stayed on.
Voila the crazy thing works fine again. Must have reset the glych somehow ?(I have no idea how)
Give it a try before giving up, who knows!!
Jun 03, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Cannon PIXMA MP520 Problem: Error code
I had this problem with the ink carriage jammed at the left hand side of the printer. I operated the lever in a hole on the top left hand side and eased the carriage along to the middle and pushed it back onto it's runners. All OK now.
Apr 12, 2008 | Canon PIXMA MP510 All-In-One InkJet...
PRINTER FAULT
I,m not 100% sure on this. But A 5700 error on canon printers.
Would mean that the paper sensor has failed, or is not working.
Hope this Helps.
Regards Mike@Compurepair.
Feb 20, 2008 | Office Equipment & Supplies
ERROR 5700 ON MP520 PRINTER
Hello Sir,
Just re-install the printer driver of the software. U have the printer software cd. Just reinstall it. It will solve the problem. ok
Thanks
Good luck
Feb 20, 2008 | Canon MP520 All-In-One InkJet Photo...
Canon MP520 All-In-One InkJet Photo Printer Logo
2,583 people viewed this question
old marine
old marine
Corne Viljoen
